leewaytoo Posted December 29, 2011 Share Posted December 29, 2011 Hi, I have forgetten how to dodge or burn an image using layers. the link i had saved is no longer good. any help would be great tks in adavance Quote Link to comment Share on other sites More sharing options...
leewaytoo Posted December 29, 2011 Author Share Posted December 29, 2011 This ? http://forums.getpai...dodgeburn-tool/ tks for the reply, although i read this and this is something else. it involved using layers and then filling the new layer with the colour 888888 which is grey, then using the brush to either darken or lighten on the original layer ?? Quote Link to comment Share on other sites More sharing options...
leewaytoo Posted December 29, 2011 Author Share Posted December 29, 2011 tks for the reply, although i read this and this is something else. it involved using layers and then filling the new layer with the colour 888888 which is grey, then using the brush to either darken or lighten on the original layer ?? ok i remember.... first open up the photo you want to dodge or burn click on the "add new layer" unclick the check box for "background" ....make sure the "layer" is highlighted in blue. open up the colour window by clicking "window" then "colour" then "more" place your cursor next to the "0" in "hex" now delete the "0's . now type in 888888, that will give you grey now click on the "paint bucket" in the tools section..... click and fill the layer with grey.... now type F4 ..... then the drop arrow for "blending mode" then click on "overlay" then "ok" now recheck the box for "background" you original image will appear.... go to the colour window and depending on what you wish to do.. change the "V" lower numbers for darker and higher for lighter. also, change the "transparency-alpha to about 8 for subtle dodging or burning, less harsh edges.... now click on the "paint brush" in "tools" and then select the size "width" .. so.... after using the brush ....... click on merge i found the above technique somewhere and it works for me.. Quote Link to comment Share on other sites More sharing options...
