cooldood Posted December 15, 2011 Share Posted December 15, 2011 I have had a request to edit an animated gif. I have done so in the past using the agif plugin. The issue I am having is the text is so small that it gets blurry when I paste it in. I would like to put GMC on https://lh6.googleusercontent.com/-DTo0C9g1j6g/TuoGCo3JGtI/AAAAAAAAB7o/aB0AhRxowmQ/s160/blonde%252520bounce.gif to look like this https://lh6.googleusercontent.com/-Iu36Fisd724/Tunzl6v9PyI/AAAAAAAAB7g/ffOZMD-daGY/s171/yamaha8pk18kwqi9.gif thanks for any help in advance. Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted December 15, 2011 Share Posted December 15, 2011 I haven't ever had issues with text of that size, but if it isn't working for you, you may wish to try a different font. Quote No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
cooldood Posted December 15, 2011 Author Share Posted December 15, 2011 I can type in a small font and it will be close but If I try to shrink down an acutal GMC logo or a Ford logo it does not. Especially ford since their font is quite different Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted December 15, 2011 Share Posted December 15, 2011 Ahh. I didn't realize you were trying to paste in the logo instead of typing it. I think the best way to do this is to paste it in and shrink it, then add a new layer and go over the lines with a brush with low opacity (adjust opacity of brush in the expanded color window). Quote No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
HyReZ Posted December 16, 2011 Share Posted December 16, 2011 (edited) I have had a request to edit an animated gif. I have done so in the past using the agif plugin. The issue I am having is the text is so small that it gets blurry when I paste it in. I do a lot of cartoon characters in fine line markers or technical drawing pens on printer paper and then scan them into the computer as 2bit black&white bmp files and covert them to svg files so that they can be rescaled to whatever size I need them to be for the various scenes. I was thinking the you can use svg files for the same purpose. So to get to the point, here is a link to a svg file of the GMC logo: http://en.wikipedia....le:GMC-Logo.svg You can go to the link, right click and copy the svg file and paste it into PDN and rescale it to your needs. The logo will scaledown fine, but pixellates when scaled up so it is not a true vector graphic. Edited December 16, 2011 by Ego Eram Reputo Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted December 16, 2011 Share Posted December 16, 2011 Well if you're using svg files, just resize it to small and export as a .png right? Quote No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
HyReZ Posted December 16, 2011 Share Posted December 16, 2011 (edited) Oops Edited December 16, 2011 by HyReZ Quote Link to comment Share on other sites More sharing options...
cooldood Posted December 16, 2011 Author Share Posted December 16, 2011 That did the trick. I did not think of the SVG. Quote Link to comment Share on other sites More sharing options...
HyReZ Posted December 16, 2011 Share Posted December 16, 2011 That did the trick. I did not think of the SVG. PDN works with both raster and vector files. Like McDonald's, I'm lovin' it! Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted December 16, 2011 Share Posted December 16, 2011 O wait...I didn't realize it was two different people posting xD PDN actually doesn't work with vector files, but if you open a vector file in something like inkscape or irfanview, you can adjust it to your needs. Quote No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
HyReZ Posted December 16, 2011 Share Posted December 16, 2011 (edited) O wait...I didn't realize it was two different people posting xD PDN actually doesn't work with vector files, but if you open a vector file in something like inkscape or irfanview, you can adjust it to your needs. Thanks for the heads-up. I did not know that PDN did not work with vector graphics. We all are learning here. That may explain why the GMC and Ford logos fell apart when I tried to upscale them. I will do the test again in Inkscape. Edited December 16, 2011 by HyReZ Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted December 16, 2011 Share Posted December 16, 2011 OK, the images are just a little bit much for this forum. We have allowed the links to remain. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
