Another Problem, while writing plugins with code lap
Hello,
I've been writing plugins with Code Lap , to learn more and to practice.. any way i wrote these Lines To Render Gird lines..
#region UICode
int Amount1 = 10; // [0,100] Width
int Amount2 = 10; // [0,100] Height
ColorBgra Amount3 = ColorBgra.FromBgr(0,0,0); // Color
#endregion
   // Declerations
   Graphics g = new RenderArgs(dst).Graphics;
   System.Drawing.Pen mypen= new System.Drawing.Pen(Amount3);
   //Grid Lines
           for (int w=0; w<rect.Right; w+=Amount1)
       g.DrawLine(mypen,w,0,w,rect.Bottom);
               for (int h=0; h<rect.Bottom; h+=Amount2)
       g.DrawLine(mypen,0,h,rect.Right,h);
Simple code, Any way it renders fine , for the first time , but when i edit the Settings it renders again above the old one, and so on
What i need is to render these lines only once, when the user edits the settings it shall only edit the current lines not render other lines, Got me?
I know this may be a stupid question , but please be patient with me .. i'm just a beggener learning :)
Thanks
Ahmed
You need to review the section on text: http://boltbait.com/pdn/CodeLab/help/tutorial4.asp
Specifically the first part...
The first thing we need to do is make sure that all pixels are copied from the source canvas to the destination canvas. We can do that with a single line of code. Just use CopySurface
#region UICode
#endregion
   dst.CopySurface(src,rect.Location,rect);
   // rest of code goes here
Click to play:
Think of the canvas as a whiteboard. You're drawing multiple times on it (each time you change the settings) without erasing the old stuff first.
As BoltBait said, you need to copy the source surface to the destination surface before rendering anything new to the destination. This effectively erases any previous renderings your plugin may have done.
BoltBait's suggested use of CopySurface is much more elegant than the way I used to do it:
// Clear the canvas by copying existing image (source) to destination
	dst[x,y] = src[x,y];
