jakemoore Posted November 16, 2011 Share Posted November 16, 2011 Hey everybody, I've got an image with two types of sand in it (light and dark), and I need to try and quantify the quantities of each for a project. Using the threshold tool seems to isolate the two (luminosity, black = 150), but I can't figure out how to tell how much of each color (white and black) there are. Does anybody have any ideas? I'm going through the list of plugins, but I'm not seeing anything (perhaps I don't know what to look for though). Thanks, and much appreciated. Quote Link to comment Share on other sites More sharing options...
mountnman Posted November 16, 2011 Share Posted November 16, 2011 so what your sayingis you need to find either the percentage of the picture made up of dark sand or the ratio of dark to light? Quote SARCASM- Just one of the many services I offer free to the public. Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted November 16, 2011 Share Posted November 16, 2011 Color Count. There has been some discussion over the accuracy of the plugin. The alternative is to use the magic wand withthe tolerance set to zero and simultaneously holding down the shift key. This will select all the occurances of the color of the pixel you click on. Check the status bar for the pixel count. Repeat for the other color. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
