power5000 Posted November 10, 2011 Share Posted November 10, 2011 Hey okay so when I move my brush quickly and it's somewhat transparent i get this Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted November 10, 2011 Share Posted November 10, 2011 Some things to try: 1. move brush slowly 2. use line/curve tool instead 3. use a semi-transparent layer instead of a semi-transparent brush Quote No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
power5000 Posted November 10, 2011 Author Share Posted November 10, 2011 Some things to try: 1. move brush slowly 2. use line/curve tool instead 3. use a semi-transparent layer instead of a semi-transparent brush 1. The second one (going from top left to bottom right) is moving very slowly 2.I do use curve tool a lot just for shading it would be hard. 3. i do know know what the semi-transparent layer is please explain. Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted November 10, 2011 Share Posted November 10, 2011 1. I meant really REALLY slowly 2. I do agree. It was just a suggestion. I never use it myself... 3. Add a new layer (ctrl+shift+n), go to the layer properties (f4), and lower the opacity. You don't need the hotkeys to do this. All the buttons are in the layers window. I didn't realize you were just shading things. Shading is a whole lot easier to explain than just getting a semi-transparent line If you could tell us what exactly you are trying to shade, we could figure out the best way to get the shading done to match the style. Quote No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
BoltBait Posted November 10, 2011 Share Posted November 10, 2011 You might also try changing the brush technique from Normal Blending :BlendingEnabled: to Overwrite :BlendingOverwrite: . Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
power5000 Posted November 11, 2011 Author Share Posted November 11, 2011 This is my most recent work and it just doesn't look very good http://s369.photobucket.com/albums/oo136/power5000/anime/?action=view¤t=kallen-1.png without highlights/ shading. @bolt bait I've tryed that and it doesn't do what I want, I want to be able to do more like this Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted November 11, 2011 Share Posted November 11, 2011 Layers are your friends. Learn to use them and this task would be as easy as finding fresh apples in a supermarket. Quote No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
