How do I fill in block text with an actual photograph?
There are two ways to do this. The ugly way and the pretty way.
#1(ugly):
Create text on its own layer. Paste photo into new layer on top of text. Use the magic wand selection tool with tolerance set to "0" to select the area around the text on the text layer, then switch to the photo layer and hit delete. Very ugly!
#2(pretty):
**Alpha Mask Import Plugin needed.**
Open new image(not your photo) in Paint.NET. Fill Background with black. Create white text on same layer as black background. Save this image as "textmask.png". Open photo in Paint.NET. Use the Alpha Mask effect on the photo and browse for "textmask.png". Pretty...
#3 On a layer write your text with an Alpha (Transparency) of 0, and Alpha Blending disable (on 3.0 Alpha it's named overwrite mode).
Put your photo on a new layer behing the one you wrote the text.
Tada.
No. Way. I've just seen Bob. And... *poof!*—just like that—he disappears into the mist again. ~Helio
Like this ?
Guess that is the picture !
(French country)
#4 (other way)
Open your picture. Add a new layer on which you add the text. Move the text accordingly to the text/pictured you want to have. You could resize the text also. Then use the magic wand and Shift on the text to "create" a selection area. Click on the first layer (picture). Then you have it. Copy and paste. Or Ctrl+I and Delete to erase outside texte....
Tada.
I must be missing something, because this is not working for me.
EDIT: Never mind. I got it. But this is not antialiased.
