Paint Shop Pro FileType (2023-06-01)
null54
26 minutes ago, ByteMarx said:
Can I do that with your library?
No, but you may be able to reuse parts of this plugin's PSP format parsing code. This library is only designed for loading and saving PSP images in Paint.NET, not as a general purpose PSP library for C# applications.
What's the best way?
The PSP format stores thumbnails in one of 2 optional sections depending on the format version, either the thumbnail block or the composite image bank block. Refer to the PSP file format specification for more details.
