King Universe Posted October 1, 2011 Share Posted October 1, 2011 i have got paint.net 3.5.6. cant update due to my windows installer and a endpoint mapper database entry not being created..so im stuck with this version and even my portalble version of paint.net does the same thing...i cant do a system restore due to other problem...what could be causing the paint.net errors...and if u know how to fix the others as well that would be greatly appriciated i have attached the crash report..just in case an admin finds this and can help paintdotnetcrash.txt Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted October 1, 2011 Share Posted October 1, 2011 Two things: 1. The latest version is 3.5.8. Make sure you update from 3.5.6. 2. Looks like you're behind on Windows Updates as well. http://blog.getpaint.net/2011/03/17/fix-for-paint-net-textfont-crashes-after-installing-windows-update-kb2505438/ Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
King Universe Posted October 2, 2011 Author Share Posted October 2, 2011 Hmm..seems likely..u see my pc keeps saying "new updates available" when i boot it up even after i shutdown with the update....but would that cause the popup as well for the Endpoint mapper database not being created?..if so then what is the method for fixing...if theres a newer update or something or an un-microsoft microsoft update?...u know an update for the OS not from microsoft but works well....im needing this fixed so i can finish a job that i use paint.net for and im the best at it and if its updates that thats kinda a relief..thought it might be a trojan or worm..or anything else virus related Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted October 2, 2011 Share Posted October 2, 2011 The fix is in the link I posted: install the Windows Updates. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
