Bobby99z Posted September 23, 2011 Share Posted September 23, 2011 I have been trying to make a forum signature, and I am using an effect that as a "side effect" makes the background black. Is it is possible to turn the black background into transparency using a PDN feature or a plugin? Quote Link to comment Share on other sites More sharing options...
Red ochre Posted September 23, 2011 Share Posted September 23, 2011 Try: 1. 'magic wand' to select the black. - the black should be highlighted pale blue. (Magic wand is 4th down R.H.S in the tools window.) 2. Edit/Erase selection. - should leave the 'checkerboard' pattern. 3. save as .png type file or something that saves transparency. Quote Red ochre Plugin pack.............. Diabolical Drawings ................Real Paintings Link to comment Share on other sites More sharing options...
Bobby99z Posted September 24, 2011 Author Share Posted September 24, 2011 Are you freakin' serious THATS whats thats for -_______- Kudos Quote Link to comment Share on other sites More sharing options...
Red ochre Posted September 24, 2011 Share Posted September 24, 2011 (edited) What exactly did I say to deserve that -<snip> asking for 'help' - oh, please, will someone that isn't a ...... help me. Well no point in trying then - I hope it all comes back. It's a dim question. If you really wanted an answer you would explain what you meant. Edited September 25, 2011 by Ego Eram Reputo Relax - lets not start a flame war. Quote Red ochre Plugin pack.............. Diabolical Drawings ................Real Paintings Link to comment Share on other sites More sharing options...
W@@dy Posted September 24, 2011 Share Posted September 24, 2011 (edited) He wasn't yelling at you mate. He was exclaiming how obvious the answer was and how he couldn't figure it out on his own. It was a giant facepalm but in words. Also, something better than the "Magic Wand tool" is a plugin called "Grim color reaper" which can change any selected color into pure transparency. Edited September 24, 2011 by W@@dy 1 Quote Link to comment Share on other sites More sharing options...
Bobby99z Posted September 24, 2011 Author Share Posted September 24, 2011 (edited) He wasn't yelling at you mate. He was exclaiming how obvious the answer was and how he couldn't figure it out on his own. It was a giant facepalm but in words. Also, something better than the "Magic Wand tool" is a plugin called "Grim color reaper" which can change any selected color into pure transparency. This What exactly did I say to deserve that -<snip> 't be asking for 'help' - oh, please, will someone that isn't a ...... help me. Well no point in trying then - I hope it all comes back. It's a dim question. If you really wanted an answer you would explain what you meant. Not This Now that you mention it, I do realise how that could be perceived as sarcasm but it wasnt Edited September 25, 2011 by Ego Eram Reputo Quote Link to comment Share on other sites More sharing options...
Red ochre Posted September 24, 2011 Share Posted September 24, 2011 I'm sorry - Just took it the wrong way, - never know how 'deep' the question is. (I was only trying to be helpful?) thank you W&&dy - for brokering the peace! - I'm very simple myself and assumed this was a rant against my simple answer - then found Bobby 99z had marked me as a friend and thought it some sort of nasty trolling. My mistake and sorry for the awkward welcome! Cheers Bobby - sorry for being hypersensitive and I'm glad you're not what what I thought you were - I was thinking of leaving the forum myself! -W@@ndy - grim color reaper - I'm sure that's good - many ways - I just thought I'd pile in early to get the job done - I know what it's like when you're starting and can't find how to do stuff and want a quick reply. Once again - sorry! Quote Red ochre Plugin pack.............. Diabolical Drawings ................Real Paintings Link to comment Share on other sites More sharing options...
W@@dy Posted September 24, 2011 Share Posted September 24, 2011 You're absolutely right to give a quick answer that gets the job done. It was always my experience/desire to have something that worked and looked professional though, not like the sharp jagginess the magic wand sometimes leaves. Magic wand can be really good, if used right. That's something that takes a bit of experience to figure out. Simply over time you just learn how to use it best by adjusting the "Acceptance" value (I forget the true name sorry, it's the blue bar at the top) Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted September 25, 2011 Share Posted September 25, 2011 Cleaned the offending words from the above posts. I'm glad we're all friends again! Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
