JohnW Posted September 16, 2011 Share Posted September 16, 2011 hi there I am new to Paint.net. I am trying, but failing, to install it on my works laptop - Windows XP SP3. Have tried several times to run the EXE file - but when it tries to install Microsoft.Net 3.5 SP1 the installation (client?) hangs at 10% then just disappears and nothing else happens. Someone suggested I install .Net 4 being a smaller installation file - 40ishMb - so I did that. But when I ran the Paint.net EXE again, the same thing happened. Is it possible to install both Microsoft.Net and Paint.net SEPERATELY? This is giving me a headache! Thanks John, UK Quote Link to comment Share on other sites More sharing options...
JohnW Posted September 16, 2011 Author Share Posted September 16, 2011 hi there I am new to Paint.net. I am trying, but failing, to install it on my works laptop - Windows XP SP3. Have tried several times to run the EXE file - but when it tries to install Microsoft.Net 3.5 SP1 the installation (client?) hangs at 10% then just disappears and nothing else happens. Someone suggested I install .Net 4 being a smaller installation file - 40ishMb - so I did that. But when I ran the Paint.net EXE again, the same thing happened. Is it possible to install both Microsoft.Net and Paint.net SEPERATELY? This is giving me a headache! Thanks John, UK Looks like I have installed Paint.net. Required me to install a standalone version of Microsoft.Net 3.5 SP1 and then run Paint.Net EXE. Thanks John Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 16, 2011 Share Posted September 16, 2011 .NET's versioning system is counter-intuitive. Installing .NET 4.0 does not enable you to run .NET 3.5 SP1 applications. Thus, you have to install .NET 3.5 SP1 even if you already have 4.0. From an end-user's standpoint, it's weird. From a developer's standpoint, it does have some very important merits. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
