simpson7647 Posted September 6, 2011 Share Posted September 6, 2011 Hi all, im after a quick little bit of help. I would like to mix an orange and black colour so that half is each and it blends into each but how do i do this? Im sure ive done it before but cant find out how thanks Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted September 6, 2011 Share Posted September 6, 2011 A few ways to do it depending on the circumstances: 1. If you are just looking for a darker orange that you can paint with, click on the "more" button in the color window and adjust the V slider 2. If you are trying to darken some orange in a picture, you can either use conditional hue/saturation or add a new layer, color with the black, then adjust the layer properties (especially the layer opacity) Quote No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
simpson7647 Posted September 6, 2011 Author Share Posted September 6, 2011 (edited) thanks for the reply. Im simply trying to do a background in a mixed orange and black colour. So i want black fading into orange Ive just had a go at your instructions but haven't suceeded, just shows the one colour. Please help thanks Edited September 6, 2011 by simpson7647 Quote Link to comment Share on other sites More sharing options...
BoltBait Posted September 6, 2011 Share Posted September 6, 2011 What you want to do is pick orange for primary color and black for secondary color. Then choose the gradient tool and start drawing. 1 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
simpson7647 Posted September 6, 2011 Author Share Posted September 6, 2011 got it! the gradient tool was was i was after Many thanks Indeed to you both for your time and help Quote Link to comment Share on other sites More sharing options...
