Red ochre plug-in pack V9 (updated 30th July 2014)
Red ochre
  • 2 months later...
  • 4 months later...
Sorry, No! :lol:
That sounds blunt! - the way that those two draw lines is completely different to the way that most effects work (it doesn't use the 'G.D.I+')*.
An effect could be made using the 'G.D.I.+' with variable width lines but it would be more of a render (using the source image colours) than a blur. Also, lines drawn with the 'G.D.I.+' tend to go a bit 'crazy' with short lengths and high widths - and it's slower too. :(
Thanks for enquiring though! - I see you have made good use of Furblur in some of your images. ;)
* A premade library of commands to 'draw' shapes and lines.
