Kayreeed Caliburn Posted August 21, 2011 Share Posted August 21, 2011 I am currently trying to make an image: a knife covered with blood stains. I've tried the tutorial "metal pipes, balls covered in blood etc" (can't remember the actual name) and the effect is not what I wanted. So is there a way to create blood stains? Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted August 21, 2011 Share Posted August 21, 2011 How realistic of an effect are you going for? There is a "bloody tentacles" tutorial here in which K_I_N_G uses some brushes and layer blend modes to do what you appear to be looking for. Quote No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted August 21, 2011 Share Posted August 21, 2011 Try Splatter with your primary color set to 7F0000 (once installed, Splatter resides in the Effects > Artistic submenu) Repeat some 'splattering' with color of 5B0000. Now play with a large diameter brush with the Smudge plugin (found in Effects > Tools) Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Kayreeed Caliburn Posted August 21, 2011 Author Share Posted August 21, 2011 Hey guys thanks a lot. Quote Link to comment Share on other sites More sharing options...
Kayreeed Caliburn Posted August 21, 2011 Author Share Posted August 21, 2011 I'm looking for dried blood stains, and they look a bit like rust as well Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted August 22, 2011 Share Posted August 22, 2011 Use this as a base to get you started. It's a wonderful rust effect, which without the metal plate texture, would make an excellent dried bloodstain. http://forums.getpai...rust-corrosion/ Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
