yellowman Posted August 18, 2011 Share Posted August 18, 2011 Why whenever I draw an ellipse with Draw Shape Outline mode I got a small lump on the right edge of the ellipse or circle. It is more noticeable on a large canvas, like 1500 x 1500 or larger, with Bush width of 150 pix or wider. I don't remember that I have this bug before. Thanks. Quote My GalleryMy YouTube Channel "PDN Tutorials" Link to comment Share on other sites More sharing options...
minners71 Posted August 18, 2011 Share Posted August 18, 2011 I have also noticed this, it seems to only of happened in the last few days. Quote Link to comment Share on other sites More sharing options...
Zagna Posted August 18, 2011 Share Posted August 18, 2011 Repros for me, easiest to see bigger the outline but it happens even at size 10, just difficult to see. And there's also 2 other kinds of artifacts... Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted August 18, 2011 Share Posted August 18, 2011 Yeah, I can repro this too. I have also noticed this, it seems to only of happened in the last few days. Are you sure it only started happening recently? Maybe there was a change to gdiplus.dll in the last batch of Windows Updates. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Zagna Posted August 18, 2011 Share Posted August 18, 2011 Couple more artifacts Quote Link to comment Share on other sites More sharing options...
minners71 Posted August 19, 2011 Share Posted August 19, 2011 Yeah, I can repro this too. Are you sure it only started happening recently? Maybe there was a change to gdiplus.dll in the last batch of Windows Updates. I can't be 100% sure, but I have been using it a lot on my avatar and the first one was Ok ( this was made a few days ago but the more recent one had the lump ) So went back to the old avatar. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted August 19, 2011 Share Posted August 19, 2011 Apparently GDI+ has cancer ("small lump") Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
yellowman Posted August 19, 2011 Author Share Posted August 19, 2011 I remembered last night that I still have the 3.3.6 version on may old XP-SP3 computer And when I tested it, it really does the same thing, looks like I didn't pay attention on this before, I didn't deal with large files because of the small memory. Quote My GalleryMy YouTube Channel "PDN Tutorials" Link to comment Share on other sites More sharing options...
Alsen Posted September 8, 2011 Share Posted September 8, 2011 (edited) Artifacts created with line/curve, rectangle, rounded rectangle, ellipse: The "expected shapes" were created in Visual Studio: http://i.imgur.com/JsBT2.png http://i.imgur.com/5osWQ.png http://i.imgur.com/JOLxk.png http://i.imgur.com/7TyCh.png Edited September 8, 2011 by Alsen Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 8, 2011 Share Posted September 8, 2011 Well, hopefully all this silliness goes away when the shapes are rendered using Direct2D instead of GDI+. GDI+ has been such a thorn in my side ... Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Alsen Posted September 9, 2011 Share Posted September 9, 2011 (edited) The artifacts that appear on the outside of the Line/Curve, Ellipse and Rounded Rectangle can be removed by setting the pen's LineJoin property to Round. I think this will get rid of the "small lump" too. Before: http://i.imgur.com/tQD9R.png After: http://i.imgur.com/j02m0.png Unfortunately I don't know how to remove the artifacts that appear inside the shapes. Edited September 9, 2011 by Alsen Quote Link to comment Share on other sites More sharing options...
