ineedhelpplease Posted July 10, 2011 Share Posted July 10, 2011 (edited) When ever I have a layer open and I open a new one(using import from file) that is bigger then the original layer it stretches the original layer, this is quite annoying when trying to add a edited text or something I always have to open it in a new window and re-size it. Is there anyway to stop it from stretching the layer? EDIT: Oh now I see the trouble shooting forum and I just read the desc of this forum sorry mods/staff can you move this? ._. Edited July 10, 2011 by ineedhelpplease Quote Link to comment Share on other sites More sharing options...
mountnman Posted July 10, 2011 Share Posted July 10, 2011 i would say this is the correct forum for this, because PDN is acting how its supposed to. you ask it to import a file and it does that- the whole file. if it automaticly scaled it down you could lose details that you wanted to keep- when it imports it, it comes up with the Move Selected Pixels tool engaged- hold shift>grab a corner node, then scale it ot where you want it,crop to selection(Ctrl/Shift/X) Quote SARCASM- Just one of the many services I offer free to the public. Link to comment Share on other sites More sharing options...
ineedhelpplease Posted July 10, 2011 Author Share Posted July 10, 2011 What If I need the image to be at a certain pixel size? Because currently I am makings advert's for a game I play and the template needs to be a certain size or it won't upload right. Won't cropping it lose some size or leave a little to much? Also if I re-size it I lose the quality so that doesn't work either. Quote Link to comment Share on other sites More sharing options...
mountnman Posted July 10, 2011 Share Posted July 10, 2011 hmmm you can set rectangle select at a certain pixel size or you can use the arrow keys to scale an image in a selection to a certain size- as for losing detail if it resized during import you would lose the same detail and a manual resize- unless its just part of the imported fiel you want, then your better off using copy/paste than import Quote SARCASM- Just one of the many services I offer free to the public. Link to comment Share on other sites More sharing options...
