xPlayers Posted June 23, 2011 Share Posted June 23, 2011 I got a problem with PyroChild's Splatter because everytime Copy Then paste it to the effects bar, it always says SPLATTER WAS NOT FOUND HELP ME!! Link to comment Share on other sites More sharing options...
Goonfella Posted June 23, 2011 Share Posted June 23, 2011 (edited) I got a problem with PyroChild's Splatter because everytime Copy Then paste it to the effects bar, it always says SPLATTER WAS NOT FOUND HELP ME!! It would help if you could describe your problem a bit better. For example you say you are trying to paste it to the Effects bar? Do you mean the Effects folder or what? Oh and also a tip - if I were you I would ask this question in the appropriate plug in thread as any plug in questions are supposed to be asked there.You are more likely to get an answer to your question as well. Good luck. Edited June 23, 2011 by Goonfella Please feel free to visit my Gallery on PDNFans And my Alternatives to PDN Link to comment Share on other sites More sharing options...
BoltBait Posted June 23, 2011 Share Posted June 23, 2011 Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
