vinyl cutting
Yellowman is correct. Vinyl cutters use EPS & I am fairly certain, AI too.
Pyro, a vinyl cutter is used most frequently by signwriters to cut out letters & shapes from rolls of thin, adhesive vinyl, & then applied to substrates such as glass, aluminium panel, etc. Darned sight quicker than the old way of painting it on by hand.
April Jones, 2012
