madkore Posted June 6, 2011 Share Posted June 6, 2011 I have tried to reinstall Paint.Net several times after I had some computer problems. I have read the forums, and tried to: 1. Remove Paint.Net entirely and reinstall Paint.Net. 2. Repair Net 4.0 I keep getting this message from my ZoneAlarm Firewall, and I never got it before. "Paint.net Setup Front End is trying to launch C:\Microsoft.NET\Framework62\v2.0.50727\dw20.exe" It doesn't matter if I hit accept or deny, I get this warning next: "Paint.Net Setup Front End has stopped working" Then I get this error message: "Error opening file for writing:" "C:\Users\KOREAN~1\AppData\Local\Temp\pdnsetup\PaintDotNet.Resources.dll" Can anyone tell me what to do? I love using Paint.net. I am using Gimp right now because I can't get Paint.net to install, but I much prefer Paint.net. How do I get Paint.net to install? Anybody? Thank you! Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted June 6, 2011 Share Posted June 6, 2011 Read the solutions provided in this thread: Note item #9: 9) Disable your antivirus Some antivirus or "internet security" software may interfere with software installations, including Paint.NET's. If you have problems, try turning off your AV software. Don't forget to turn it back on once Paint.NET is installed! Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 6, 2011 Share Posted June 6, 2011 Yes, please turn off those firewalls and antivirus. They are over protective and do more to make your computer crash than actually protect it. dw20.exe is the Error Reporting Shim. If you see that, then something's already crashed. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
