gr8 0 Posted May 17, 2011 Report Share Posted May 17, 2011 (edited) hello i have a gadget on my windows 7 desktop . now i changed the background to transparent using paint.net, latest version. for some reason some of the colors (/text and icons) became a sort of rosa color . can anybody give me some advice, why this happens and how i can get rid of it? many thank for your help. edit: i have the same problem with another gadget edit1: here is what i did... 1. open the picture in paint.net 2. changed in the layerproperties the opacity from 255 to 122 3. saved the picture as 32-bit png file Edited May 17, 2011 by gr8 Quote Link to post Share on other sites
mountnman 11 Posted May 17, 2011 Report Share Posted May 17, 2011 im no expert, but are you running the 64 bit version? it would make sense that colours in a 64 bit pic would change if saved to 32 bit Quote SARCASM- Just one of the many services I offer free to the public. Link to post Share on other sites
gr8 0 Posted May 17, 2011 Author Report Share Posted May 17, 2011 thanks your reply. nop, im running windows 7-32 bit. any other ideas? Quote Link to post Share on other sites
Rick Brewster 1,757 Posted May 17, 2011 Report Share Posted May 17, 2011 im no expert, but are you running the 64 bit version? it would make sense that colours in a 64 bit pic would change if saved to 32 bit That doesn't make any sense whatsoever. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to post Share on other sites
Rick Brewster 1,757 Posted May 17, 2011 Report Share Posted May 17, 2011 My hypothesis is that the gadget program is expecting the PNG to be stored in "premultiplied alpha" format. Paint.NET -- and in fact the PNG specification itself -- only uses "straight alpha". I'd look into the documentation (wherever that is) for the gadget stuff to see if it mentions anything like that. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to post Share on other sites
gr8 0 Posted May 19, 2011 Author Report Share Posted May 19, 2011 thanks for your answers. it seems that the problem lies with the gadget itself and how they are build (how the background pic is shown). i'will investigate and if i find a solution, i will post it here. c u. Quote Link to post Share on other sites
