mikehende Posted April 20, 2011 Share Posted April 20, 2011 Hey guys, I am new here, was referred to this software, tried it out but can't get my desired results so just thought I'd ask here for help? I have about 16 images of website screenshots, meaning I took full page screenshots of different sites to use in my Portfolio page so I need the dimensions of all 16 site's screenshots to be the exact same size which is 192x115, problem is I am not allowed to type in those exact dimensions before resizing. Is there any I can get my desired results please? Quote Link to comment Share on other sites More sharing options...
barbieq25 Posted April 20, 2011 Share Posted April 20, 2011 If your images are all the same size originally, open them in Paint.NET. You can then remove any part you don't need. Crop to selection would work. Resize the image to what you want BUT be sure to untick/uncheck the "Maintain aspect ratio" & it will let you type in those exact dimensions. Quote Knowledge is no burden to carry. April Jones, 2012 Gallery My DA Gallery Link to comment Share on other sites More sharing options...
mikehende Posted April 20, 2011 Author Share Posted April 20, 2011 I got it done using Irfanview's batch conversion feature but problem is still that it looks distorted. Is there any way I can get the images to not look distorted resizing down to those dimensions? Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted April 20, 2011 Share Posted April 20, 2011 The only way to keep the image from being distorted when you resize to a different aspect ratio than the original is to crop it. Check "maintain aspect ratio" and make one of the dimensions match the desired dimension, then resize canvas to crop it to the desired size. Quote No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
