Help with paint.net
Hi, I just started using paint.net and I'm having a bit of trouble. There are some times when I cannot bucket fill or use the paint brush or even erase sometimes. I notice sometimes it's after I use the magic wand tool. It appears in the history but nothing happens. Thnx in advance!
Most likely you are trying to bucket fill, use the paint brush,
or erase outside of the selection area.
Sometimes the Magic Wand will select only a very tiny space.
The rest of the canvas will be unselected, and can't be acted on by any tools.
Pressing the Esc key on your keyboard will remove
the selection so that the tools can be used again.
Please edit the title of your post to be something other than "Help with paint.net," as per the rules (#6 in particular). Also, this thread does not belong in Troubleshooting.
Moved to GD&Q
