D1Collum Posted February 26, 2011 Share Posted February 26, 2011 I downloaded the most current "Custom Brushes Mini" plugin, and every time I select it, it says the following message: "This plugin has encountered an error, and must be closed. Because of the unpredictable nature of these types of errors, it is strongly recommended that you restart Paint.NET before proceeding. Otherwise, there could be further stability problems or data corruption." It says to restart Paint.NET, and I did. It continues to do the same thing. I have viewed the forum Page http://forums.getpai...s-mini-problem/ where someone was having the same problem and I have copied SBCommon.dll to the effects folder as well as CustomBrushesMini.dll, but where as that fixed the problem for the other person, I continue to get the same message The plugin error details are File: C:\Program Files\Paint.NET\Effects\CustomBrushesMini.dll Effect Name: CustomBrushesMini.CustomBrushesMiniEffect Full error message: System.IO.DirectoryNotFoundException: The system cannot find the path specified. (Exception from HRESULT: 0x80070003) at PaintDotNet.SystemLayer.NativeMethods.SHGetFolderPathW(IntPtr hwndOwner, Int32 nFolder, IntPtr hToken, UInt32 dwFlags, StringBuilder lpszPath) at PaintDotNet.SystemLayer.Shell.GetCSIDLPath(Int32 csidl, Boolean tryCreateIfAbsent) in D:\src\pdn\pdn_35x\src\SystemLayer\Shell.cs:line 925 at PaintDotNet.SystemLayer.Shell.GetVirtualPath(VirtualFolderName folderName, Boolean tryCreateIfAbsent) in D:\src\pdn\pdn_35x\src\SystemLayer\Shell.cs:line 955 at PaintDotNet.PdnInfo.get_UserDataPath2() in D:\src\pdn\pdn_35x\src\Resources\PdnInfo.cs:line 65 at PaintDotNet.AppModel.AppInfoService.get_UserDataDirectory() in D:\src\pdn\pdn_35x\src\PaintDotNet\AppModel\AppInfoService.cs:line 44 at CustomBrushesMini.CustomBrushesMiniEffect.CreateConfigDialog() in D:\co\custombrushesmini\CustomBrushes\CustomBrushes\EffectPlugin.cs:line 22 at PaintDotNet.Menus.EffectMenuBase.RunEffectImpl(Type effectType) in D:\src\pdn\pdn_35x\src\PaintDotNet\Menus\EffectMenuBase.cs:line 799 Also i have read that there is supposed to be a location "C:\Users\<username>\Documents\Paint.NET User Files" which I do (did) not have I created this folder and put a few brushes in but didn't help anything Please Help Link to comment Share on other sites More sharing options...
VeroSwing Posted February 26, 2011 Share Posted February 26, 2011 I seem to be having a similar problem as the person above. I've tried to follow the instructions in this tutorial, but after copying the appropriate files to the User Files, the tutorial mentions that opening Paint.net should create a folder called "Custom Brushes" under User\Documents\Paint.Net User Files. This does not happen. Then when I open Paint.net and try to open the Custom Brushes Mini effects, it gives me the same type of error as mentioned above, but the error details are as follows: File: C:\Program Files\Paint.NET\Effects\CustomBrushesMini.dll Effect Name: CustomBrushesMini.CustomBrushesMiniEffect Full error message: System.MissingMethodException: Method not found: 'System.IServiceProvider PaintDotNet.Effects.Effect.get_Services()'. at CustomBrushesMini.CustomBrushesMiniEffect.CreateConfigDialog() at PaintDotNet.Menus.EffectMenuBase.RunEffect(Type effectType) There seems to be something missing there, but I don't quite understand it, and don't know how to fix it... I'd love some help! Thanks! -V Link to comment Share on other sites More sharing options...
VeroSwing Posted February 26, 2011 Share Posted February 26, 2011 I finally made it work, but I'm not sure how. I completely uninstalled Paint.net then reinstalled it. Perhaps I didn't have a recent enough version of the software? When I reinstalled it, Custom Brushes Mini was magically already installed, not sure why, because I thought I had erased all files. Anyway, I can't offer much input, but perhaps this can help...! -V Link to comment Share on other sites More sharing options...
Rick Brewster Posted February 26, 2011 Share Posted February 26, 2011 Please report this in the thread for CustomBrushes Mini. Thread Closed The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
