Golden Kumquat Posted February 16, 2011 Share Posted February 16, 2011 I am currently working with a very large (~3000x2000 with about 25 layers) image, which I need to save as multiple PNGs with various layer configurations. Unfortunately, whenever I go to undo after the image flattens, the memory usage increases by about the original image size. After about three flattens and undos, Paint.NET will typically be taking up about 3 GBs worth of memory. It looked like it was fixed with version 3.5.2, but I'm currently using 3.5.6 and I'm having issues. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted February 16, 2011 Share Posted February 16, 2011 Read this: If this proves to be the problem, you may need to split the image into a couple of smaller work units to make things manageable (think: fewer layers in multiple image files should do it). Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Golden Kumquat Posted February 16, 2011 Author Share Posted February 16, 2011 Read this: http://forums.getpai...ead-this-first/ If this proves to be the problem, you may need to split the image into a couple of smaller work units to make things manageable (think: fewer layers in multiple image files should do it). I looked at it, but the issue is that if I flatten, undo, flatten again, and then undo again, it's trying to store the full image three times. Quote Link to comment Share on other sites More sharing options...
BoltBait Posted February 16, 2011 Share Posted February 16, 2011 Are you just concerned that it is over utilizing a resource available to it? Or, have you actually had Paint.NET run out of memory? Until this happens, I wouldn't worry too much about it. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Golden Kumquat Posted February 16, 2011 Author Share Posted February 16, 2011 It actually does run out of memory, since after about three iterations of saves and undos, Paint.NET is taking up about 3 GB of memory and basically crashes. Quote Link to comment Share on other sites More sharing options...
BoltBait Posted February 16, 2011 Share Posted February 16, 2011 Go ahead and post the crash log. Thanks. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Golden Kumquat Posted February 19, 2011 Author Share Posted February 19, 2011 It's not posting a crash log; it just takes up more and more memory until it basically stops running because it's taking up all of my computer's memory. Quote Link to comment Share on other sites More sharing options...
Sarkut Posted February 19, 2011 Share Posted February 19, 2011 If you don't actually need to preserve the session History, this might reduce memory usage build-up. Go to the PDN file and change it to read-only. (To protect it from accidentally being lost.) Open the file, make changes, save as PNG with new name. Close file. Again, open the original PDN file, change, save as differently arranged renamed PNG. Close file. Repeat as needed. You never have to unflatten, shouldn't be any memory use build-up, and is probably as fast as waiting for the unflatten to run. If you need to save some of the changes as you go, save as PDN with rename, flatten, save as PNG and close, re-open latest PDN file. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted February 20, 2011 Share Posted February 20, 2011 I'm not seeing a continued leak of memory. I am, however, seeing a leak when you close the image. I created a 3k x 2k image, and then added 24 layers. I did flatten followed by undo, and repeated several times. Memory usage was parked at almost 700MB, but never great past that except momentarily while undoing. Then, after closing the image, memory usage stayed about 650mb. I'll check this out. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
