PlainoldTony Posted February 10, 2011 Share Posted February 10, 2011 Hello Everybody, I'm new to Paint.Net so I'm probably asking a very basic question. Even though I come from an IT background I'm a bit confused about this and lots of other things in here. So I'll just stick to this one for now, in the belief that I'll solve the others myself. (Yeah right!) I've downloaded some plugins. I've expanded them. I've copied the .dll files to C:\Proram Files\Paint.Net\effects. Well, that should do it shouldn't it? I've read an article in a forum that suggests some plugins do not appear in Effects drop-down menu. Some of these certainly do not. So, please will some kind soul enlighten this idiot on how to access them within the program. I can't seem to get to grips with Photoshop Elements so I'm having a go with Paint.Net. I think I'm doing quite well really, but don't expect to be seeing any wondrous works of art from me - for a while. Best regards to all Quote plainoldtony Link to comment Share on other sites More sharing options...
Sarkut Posted February 10, 2011 Share Posted February 10, 2011 (edited) Some plugins installed in the Effects folder may show in sub-menus of the Effects menu, some may show in the Adjustments menu. Edited February 10, 2011 by Sarkut Quote Link to comment Share on other sites More sharing options...
PlainoldTony Posted February 10, 2011 Author Share Posted February 10, 2011 Some plugins installed in the Effects folder may show in sub-menus of the Effects menu, some may show in the Adjustments menu. Quote plainoldtony Link to comment Share on other sites More sharing options...
PlainoldTony Posted February 10, 2011 Author Share Posted February 10, 2011 My word Sarkut! That was quick. Thank you for you very prompt reply. I can see them now. I'm also new to forums, (is that correct for the plural case?). I got my reply wrong and I think I just sent your reply back to you. I hope you don't think I was being rude. Quote plainoldtony Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted February 10, 2011 Share Posted February 10, 2011 Some plugins extend the types of files that can be loaded and saved. We generally call these plugins 'filetypes'. Filetype plugins should be placed in the /Filetypes folder rather than /Effects (that makes sense when you think about it doesn't it?). These plugins do not show up in the ususal menus. They show up in the filetype dropdown list in the load/save dialogs, allowing you to select the new type of file when loading or saving an image. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
