niwax 3 Posted February 7, 2011 Report Share Posted February 7, 2011 (edited) Scroll down to see the result This is the picture we want to edit: Copy the background layer: And maximize its contrast using Brightness/Contrast: Then select the whole black area with the magic wand and remove it: * Run a gaussian blur: Copy the blurred layer and run zoom blur: You can now change the transparency for a better result: At the point marked with * you can also use the original image instead of white: Edited February 8, 2011 by niwax Huge image removed. PlugIns Made in Germany Link to post Share on other sites
ventor1 15 Posted February 7, 2011 Report Share Posted February 7, 2011 (edited) Very nice result... so simple and yet so effective! Perhaps enter your croissant into the "inner light" comp? <br><br>Cheers, V Edited February 8, 2011 by ventor1 Link to post Share on other sites
Ego Eram Reputo 2,754 Posted February 7, 2011 Report Share Posted February 7, 2011 *sigh* one image 5150pixels high. What part of Tutorial Guidelines 1a "less than 800 pixels at their largest dimension" don't you understand? <Image removed.> Now you have the option of reposting this tut with much smaller images, or I can lock it. ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to post Share on other sites
gekkoutora23 0 Posted February 8, 2011 Report Share Posted February 8, 2011 you need to put the image back up there. Link to post Share on other sites
niwax 3 Posted February 8, 2011 Author Report Share Posted February 8, 2011 (edited) I'm sorry, i did this offline so i couldn't see the rules. I'll put some new pictures there. //EDIT: done Edited February 8, 2011 by niwax PlugIns Made in Germany Link to post Share on other sites
Ego Eram Reputo 2,754 Posted February 8, 2011 Report Share Posted February 8, 2011 Much better! Thanks for sorting out the images. Nice effect - reminds me of the Alien egg (you know the one in the promo pics with the crack & the green light spilling out?). ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to post Share on other sites
