devubha Posted January 31, 2011 Share Posted January 31, 2011 Hello Team, I have downloaded source code from site and build it using visual studio .net 2010 and it started working but when i have opened "color window" and click on "Primary color" OR "Secondary color" not switching i have to manually select it from Dropdown than it working else directly click is not working and click on Palette is also working. I can not change color from Palette. Please help me where and what thing would i have to change to get it working . Which event i have change to complete this task. I have attached sample image. Link to comment Share on other sites More sharing options...
Simon Brown Posted January 31, 2011 Share Posted January 31, 2011 The source code for the current version isn't available. The code you downloaded is probably for an older version. Link to comment Share on other sites More sharing options...
Rick Brewster Posted January 31, 2011 Share Posted January 31, 2011 Do not ask questions about the source code here, which by the way isn't available anymore partly because I don't want to be bothered with stupid questions like this. I'm not Professor C#, so stop it already. And shouldn't it be obvious? By the way this is the forum section for PLUGIN DEVELOPMENT. You aren't working on a PLUGIN, therefore why did you post HERE? Thread Closed The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
