Swagg422 Posted January 30, 2011 Share Posted January 30, 2011 im trying to make/ add text that changes color to a image was wondering if there were any plugins or tuts that explain how to do this. Quote Link to comment Share on other sites More sharing options...
DarylRunco Posted January 30, 2011 Share Posted January 30, 2011 (edited) Paint.net is not (to my knowledge) a gif editor, which means it's not meant to create pictures that changes upon time. You could try Gimp (go to gimp.org to download it), then yahoo/google/bing "gimp gif animation tutorial". You should find everything you need there. Edited January 30, 2011 by DarylRunco Quote Link to comment Share on other sites More sharing options...
Swagg422 Posted January 30, 2011 Author Share Posted January 30, 2011 figured it out sorta gonna use paint .net to make all the images then use plugin i jus found. if that doesn work ill jus do it the old way with a seperate gif animator program Quote Link to comment Share on other sites More sharing options...
DarylRunco Posted January 30, 2011 Share Posted January 30, 2011 What plugin are you talking about, exactly? Quote Link to comment Share on other sites More sharing options...
mountnman Posted January 31, 2011 Share Posted January 31, 2011 (edited) yes there is a plugin to make animated gifs or .agif- it also makes .apgn(animated pgn files), or you can save individual gif images and use the free program unfreez http://www.isimonbro...uk/plugin-pack/ <the plugin http://forums.getpai...e-23-agif-apng/ <the thread for the plugin, has basic how to and what others have commented Edited January 31, 2011 by mountnman Quote SARCASM- Just one of the many services I offer free to the public. Link to comment Share on other sites More sharing options...
