Whiterock 0 Posted January 9, 2011 Report Share Posted January 9, 2011 Hello community, I've just tried to make a simple box blur effect in pdn. My code is: #region UICode #endregion void Render(Surface dst, Surface src, Rectangle rect) { // Delete any of these lines you don't need Rectangle selection = this.EnvironmentParameters.GetSelection(src.Bounds).GetBoundsInt(); int CenterX = ((selection.Right - selection.Left) / 2)+selection.Left; int CenterY = ((selection.Bottom - selection.Top) / 2)+selection.Top; ColorBgra PrimaryColor = (ColorBgra)EnvironmentParameters.PrimaryColor; ColorBgra SecondaryColor = (ColorBgra)EnvironmentParameters.SecondaryColor; int BrushWidth = (int)EnvironmentParameters.BrushWidth; ColorBgra CurrentPixel; ColorBgra LeftPixel; ColorBgra RightPixel; ColorBgra AbovePixel; ColorBgra BelowPixel; for (int y = rect.Top + 1; y < rect.Bottom - 1; y++) { for (int x = rect.Left + 1; x < rect.Right - 1; x++) { CurrentPixel = src[x,y]; LeftPixel = src[x-1,y]; AbovePixel = src[x,y-1]; BelowPixel = src[x,y+1]; RightPixel = src[x+1,y]; CurrentPixel.R = (byte)((LeftPixel.R+AbovePixel.R+BelowPixel.R+RightPixel.R)/4); CurrentPixel.G = (byte)((LeftPixel.G+AbovePixel.G+BelowPixel.G+RightPixel.G)/4); CurrentPixel.B = (byte)((LeftPixel.B+AbovePixel.B+BelowPixel.B+RightPixel.B)/4); CurrentPixel.A = (byte)((LeftPixel.A+AbovePixel.A+BelowPixel.A+RightPixel.A)/4); dst[x,y] = CurrentPixel; } } } But i don't know the reason, why it doesn't work correctly. It's so strange, because it's just working every 2y-coords. I hope someone or BoltBait can help me:roll: MfG whiterock p.s: I'm from Austria Quote Link to post Share on other sites
Cookies 6 Posted January 9, 2011 Report Share Posted January 9, 2011 (edited) for (int y = rect.Top + 1; y < rect.Bottom - 1; y++) { for (int x = rect.Left + 1; x < rect.Right - 1; x++) { should be for (int y = rect.Top; y < rect.Bottom; y++) { for (int x = rect.Left; x < rect.Right; x++) { Edited January 9, 2011 by Cookies Quote Link to post Share on other sites
Tanel 7 Posted January 9, 2011 Report Share Posted January 9, 2011 Render rect's coordinates don't always match those of canvas. Thererefore y loop starting at y = rect.Top + 1 will cause unpredictable results. You could work around though, by using coordinates from Rectangle selection : for (int y = selection.Top + 1; y < selection.Bottom - 1; y++) Someone will sure present a better solution. Quote Link to post Share on other sites
Whiterock 0 Posted January 9, 2011 Author Report Share Posted January 9, 2011 Ok, lets see: Why can do a "+1" say the program, that it it should calucate each second y-coord/x coord ? (strange) I will try it and infomate (? does this word exist) you if its working or not;) MfG Whiterock ("MfG" menas in Austria, something like "With friendly Greetings") Quote Link to post Share on other sites
Cookies 6 Posted January 11, 2011 Report Share Posted January 11, 2011 (edited) Render rect's coordinates don't always match those of canvas. Thererefore y loop starting at y = rect.Top + 1 will cause unpredictable results. You could work around though, by using coordinates from Rectangle selection : for (int y = selection.Top + 1; y < selection.Bottom - 1; y++) Someone will sure present a better solution. I wouldn't do that, if its in an irregular selection (round, shaped) it will do it outside the selection that way Ok, lets see: Why can do a "+1" say the program, that it it should calucate each second y-coord/x coord ? (strange) I will try it and infomate (? does this word exist) you if its working or not;) MfG Whiterock ("MfG" menas in Austria, something like "With friendly Greetings") read this: http://www.boltbait....lp/tutorial.asp it explains it edit: I guess your trying to avoid going "outside" the image, if so use src.GetBilinearSampleClamped(x, y); Edited January 11, 2011 by Cookies Quote Link to post Share on other sites
skyoxZ 0 Posted January 11, 2011 Report Share Posted January 11, 2011 src[x+0,y+0] should also be in the Box. Quote Link to post Share on other sites
Whiterock 0 Posted January 28, 2011 Author Report Share Posted January 28, 2011 src.GetBilinearSampleClamped(x, y); How can i use ist? Quote Link to post Share on other sites
Cookies 6 Posted January 29, 2011 Report Share Posted January 29, 2011 like this CurrentPixel = src.GetBilinearSampleClamped(x, y); Quote Link to post Share on other sites
