gotube Posted September 16 Share Posted September 16 (edited) Is this still the best way to view images side-by-side? I'm recreating pixel art based on imperfect screen shots from YouTube. Having to resize the canvas and add/remove layers for each new image (30-40 per day) is so cumbersome. I also need to look at my new copy much more zoomed in than the reference piece, so pasting it into the canvas isn't a great solution. Further, I need to sample colours from the original and use them in my new copy, but you can't use the dropper through layers, so I have to switch layers every time I sample from the original. Is there really no way to simply view multiple canvases side-by-side? Paint Shop Pro does it with one click ever, rather than all this twiddling. PSP is rubbish though, so I'm giving PDN a spin, and hoping a similar feature has been added. Thanks for the help! Edited September 17 by gotube Quote Link to comment Share on other sites More sharing options...
Tactilis Posted September 17 Share Posted September 17 (edited) On 9/17/2023 at 12:41 AM, gotube said: Further, I need to sample colours from the original and use them in my new copy, but you can't use the dropper through layers, so I have to switch layers every time I sample from the original From the Documentation at https://www.getpaint.net/doc/latest/ColorPicker.html Quote The Color Picker Tool has two sampling modes, Image and Layer . These dictate which pixels will be sampled when picking a color. ... Tip: The keyboard shortcut for the Image mode is to hold down the Ctrl key when clicking. Does Image mode make your task easier? On 9/17/2023 at 12:41 AM, gotube said: I also need to look at my new copy much more zoomed in than the reference piece, so pasting it into the canvas isn't a great solution. Pasting into the canvas isn't a great solution for what? Could you describe your workflow please? Does pressing Ctrl+B (i.e. View | Zoom to Window) help? Ctrl+B will toggle between your zoomed in view and a full image view. Edited September 20 by Tactilis Typo fixed Quote Link to comment Share on other sites More sharing options...
gotube Posted September 19 Share Posted September 19 (edited) On 9/17/2023 at 3:18 AM, Tactilis said: From the Documentarian at https://www.getpaint.net/doc/latest/ColorPicker.html Does Image mode make your task easier? Thanks! That solves that particular problem entirely. On 9/17/2023 at 3:18 AM, Tactilis said: Pasting into the canvas isn't a great solution for what? Could you describe your workflow please By "pasting into the canvas", I meant the instructions in this tutorial: expand the canvas, create a new layer, and paste the source image into the new layer, onto the new, empty part of the canvas. Thanks too for the Ctrl-B shortcut. It's handy to know about, but I work way zoomed into both layers, one 3x more than the other, like I might be zoomed in 30x on the original, and 90x on my new version. Can I easily pan and zoom the layers independently without one covering the other? Edited September 19 by gotube Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted September 20 Share Posted September 20 3 hours ago, gotube said: I meant the instructions in this tutorial: expand the canvas, create a new layer, and paste the source image into the new layer, onto the new, empty part of the canvas. Tried Ctrl + Shift + V (paste into new layer)? The option to Expand Canvas is the default, so you can hit enter to resize the canvas to the large dimension clipboard image. 1 Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
