bit depth and file size problems with tga
I need to output .tga files 800x600 16bit colour and end up with a file size of 938KB - and I can't find a way of doing it - I'd welcome any hints.
I can import just such a .tga and SaveAs - but I can't find an option to make the right file-size.
Is this linked to a minimum 24bit depth or similar?
If it's just not possible then so be it - but what a shame because PdN is just brilliant even for a light-user like me.
  • 3 weeks later...
Please excuse Bumping this thread: I'll attach an existing 800x600 16bit file (938KB) zipped to 2K.
I'd like to modify it and save it AND keep the filesize at 938KB.
Every time I try, PdN saves the file with size 1407KB - what do I need to do or set in the Save dialog?
Again, I'll welcome any hints (I'm guessing that it is a default 24bit or something like that).
(I'll launch this and leggit to the pub so please forgive delayed or deluded responses later)
PlainBackground.zip
