trickman Posted October 20, 2006 Share Posted October 20, 2006 When you do what happens above... BEFORE: AFTER: See the last pixels? I guess this's a simple bug... Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted October 20, 2006 Share Posted October 20, 2006 I need some exact repro steps. "Crop" doesn't work on individual layers, it crops the whole document, so I don't understand what you're referring to. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
trickman Posted October 20, 2006 Author Share Posted October 20, 2006 OK, this is the base image. 1. Select the white background. 2. Invert the selection. 3. Crop. 4. Paste. Tcha-daa! Quote Link to comment Share on other sites More sharing options...
BoltBait Posted October 20, 2006 Share Posted October 20, 2006 3. Crop. I think you mean "Cut", as in Ctrl-X or Edit>Cut. Image>Crop would shrink the border down to your selection. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
trickman Posted October 20, 2006 Author Share Posted October 20, 2006 3. Crop. I think you mean "Cut", as in Ctrl-X or Edit>Cut. Image>Crop would shrink the border down to your selection. Yeah I meant that. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted October 20, 2006 Share Posted October 20, 2006 There's another piece to the puzzle: you're using Nearest Neighbor in the toolbar. Took me a few seconds to figure that out. Bilinear works just fine here. So yeah I"ll file a bug on this. Good catch. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
barkbark00 Posted October 20, 2006 Share Posted October 20, 2006 I know this is the wrong place to ask, but how do you invert a selection??? this would be extremely helpful for me.... Quote  Take responsibility for your own intelligence. -Rick Brewster Link to comment Share on other sites More sharing options...
Rick Brewster Posted October 20, 2006 Share Posted October 20, 2006 Edit -> Invert Selection. Ctrl+I Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
barkbark00 Posted October 20, 2006 Share Posted October 20, 2006 WOW. I can't believe I missed that all this time! Quote  Take responsibility for your own intelligence. -Rick Brewster Link to comment Share on other sites More sharing options...
mickiscoole Posted October 21, 2006 Share Posted October 21, 2006 Dunno if this is a bug or not, but when you make a selection, then rotate it 180 or 360 degrees manually, there is a line of pixels missing , never rotates perfectly Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted October 21, 2006 Share Posted October 21, 2006 Post a screenshot, sample image, and specific repro steps. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Picc84 Posted October 21, 2006 Share Posted October 21, 2006 WOW. I can't believe I missed that all this time! Ctrl-I is used constantly but a lot of people.... it helps tons! Quote Link to comment Share on other sites More sharing options...
Born2killx Posted October 21, 2006 Share Posted October 21, 2006 I use Ctrl-Shift-X more. Quote I built my first computer at age 11! Link to comment Share on other sites More sharing options...
Rick Brewster Posted November 8, 2006 Share Posted November 8, 2006 BTW this should be fixed in Alpha 3, trickman. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
trickman Posted November 8, 2006 Author Share Posted November 8, 2006 ok, thanks! Quote Link to comment Share on other sites More sharing options...
