tickleseed Posted December 4, 2010 Share Posted December 4, 2010 hey all, i'm not too experienced with pdn, so this is probably a dumb question with a simple answer, but i'll ask it anyways. i just installed the "light rays" render plugin, and i have a general idea of what all the sliders do. what i can't figure out is how to end the rays with a gradient to white...can anybody help me? cheers! Quote Link to comment Share on other sites More sharing options...
Sarkut Posted December 4, 2010 Share Posted December 4, 2010 You can fill a new layer with white above the LightRays layer. Then do a transparent radial gradient on the white layer. Use the right mouse button, and drag from the center of the canvas out towards the edge. Quote Link to comment Share on other sites More sharing options...
tickleseed Posted December 7, 2010 Author Share Posted December 7, 2010 thanks, that worked great! Quote Link to comment Share on other sites More sharing options...
