Owen N Posted November 27, 2010 Share Posted November 27, 2010 I can't find the most basic tut that shows how to read image files into layers. I end up creating empty layers and multiple backgrounds. Which is a good tut for this? Also, can I stretch an image - widen or squash down, or skew? -- Owen N Quote Link to comment Share on other sites More sharing options...
Owen N Posted November 27, 2010 Author Share Posted November 27, 2010 Clarification. There doesn't seem to be a basic tut (that I can find) that explains how to select and manage layers. Selection is not obvious! I found how to create new layers, and how to display the layer window. None of the icons on the layer window allow selection of the layer. Where is the current layer number displayed? -- Owen N Quote Link to comment Share on other sites More sharing options...
Sarkut Posted November 27, 2010 Share Posted November 27, 2010 The current active layer will be highlighted in the Layers window. Clicking on a different layer in the Layers window will make it the active layer. To bring image files in as layers: Layers > Import from File... (In the menu at the top) Copying and pasting can also be used. Quote Link to comment Share on other sites More sharing options...
Owen N Posted November 27, 2010 Author Share Posted November 27, 2010 -Sort of figured it. 1. create new layer. 2. turn off background to see the checker pattern. 3. open image file. 4 select all. 5 cut. 6 paste in to new layer. 6. deselect. Any of these steps redundant? Way to do this quicker? If I do this again, it obliterates my previous image. How do I avoid this?? Ahah! This creates an entirely new stack, not just a layer. How about: 1. create a new layer. 2. turn off other layers. 3. click on new layer in layer manager. 4. Import from file. 5. select all 6. cut. 7. select new layer. 8. paste. 9. deselect. 10. turn off new layer. 11. select new background. 12. delete layer. - then carry on. This looks better, but probably still redundant operations. Any suggestions? -- Owen N Quote Link to comment Share on other sites More sharing options...
Sarkut Posted November 27, 2010 Share Posted November 27, 2010 (edited) Probably is unnecessarily complicated, but I don't know specifically what you want to accomplish so I can't make a better suggestion. ----------------------------- Is it that you'd like to bring a multi-layer .pdn file in as a single layer? ----------------------------- If so, with the file that you want to add something to open, open a new file, and import the file to be added, as layers. Layers > Import From File... then Image > Flatten Copy the flattened image. Ctrl + C Go back to the original file that you want to add to: Edit > Paste in to New Layer ---------------------------- http://www.getpaint.net/doc/latest/WorkingWithLayers.html . Edited November 27, 2010 by Sarkut Quote Link to comment Share on other sites More sharing options...
Owen N Posted November 27, 2010 Author Share Posted November 27, 2010 Probably is unnecessarily complicated, but I don't know specifically what you want to accomplish so I can't make a better suggestion. ----------------------------- Is it that you'd like to bring a multi-layer .pdn file in as a single layer? ----------------------------- If so, with the file that you want to add something to open, open a new file, and import the file to be added, as layers. Layers > Import From File... then Image > Flatten Copy the flattened image. Ctrl + C Go back to the original file that you want to add to: Edit > Paste in to New Layer ---------------------------- http://www.getpaint....WithLayers.html . Owen: I just want to bring in a jpeg and insert it into a layer. There must be a shorter method. -- Owen N Quote Link to comment Share on other sites More sharing options...
Sarkut Posted November 27, 2010 Share Posted November 27, 2010 Drag-and-Drop > Add Layer Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted November 30, 2010 Share Posted November 30, 2010 Moved to GD & Q as this was incorrectly posted in the tutorial section. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
