can somebody please help with my setting for saving
OK. Start over.
With your image project open in Paint.NET, press PrintScrn.
In Paint.NET, hold down Ctrl and Alt keys, and press V.
This will copy the screenshot into a new file in Paint.NET.
Save the file as PNG (the default), then upload it to ImageShack.
Edited by Sarkut
OK. The two are in separate files.
The two pictures at the top-right are thumbnailed tabs.
Click on the flag tab to switch to that file.
(If that file has more than one layer: Image > Flatten )
Next:
Ctrl + A
Ctrl + C
Copies the flag into the clipboard.
Click on the tab for the girl.
Ctrl + Shift + V
Pastes into a new layer.
You should be able to move the flag with the mouse now.
Edited by Sarkut
fantastic !!!!!!! done in 10 seconds !! you really are a star sarkut, i really can't thank you enough for standing by me and helping me out!!
outstanding my friend!!
if ever i can help you with anything please feel free to contact me at stephen@stephenjamieson.com
just a quick one !! is that the way i should do further images or is that the wrong way?
thanks again sarkut
kind regards
stephen :)
