can somebody please help with my setting for saving
Hi there can somebody please tell me where i am going wrong,
After taking a free image from bing images or similar and saving to my folder i then upload it to paint where i add txt and overlay another smaller image in the bottom corner i then save it as a jpeg
all i want to do is to be able to upload it to my website and have it be the same size as the original one
But when i open the new image it is a lot smaller in size but as expected the file is bigger
can somebody please advise as to what i am doing wrong
Thanks for any advice
Stephen
Open the Union Jack image.
Next, import the original.
Layers > Import From File
It will import already selected, so you can do this:
Image > Crop to Selection
Now, delete the imported layer.
The edit is now correctly cropped.
Save.
sorry not sure what you mean, i would like to start from scratch, so i will import the original yeh? (do i need to set the size of the layer?) then i will add the txt yeh? then i add another layer and import the union jack yeh? and then what?
thanks for all your help sarkut
stephen
If you start from scratch, open the original instead of importing it.
File > Open
It will be sized correctly that way.
If the union jack is a big image, resize it separately before bring it in.
Otherwise it will expand the canvas when it's brought in.
I don't know what size your source image for the union jack is.
(pixel dimensions)
Heh Sarkut thanks for all the help , i have managed to do what you said and the picture with the txt in it is saving to a perfect size, can i ask you one more question please?
I have done what you said and i have the picture with the txt in it and i have resized the union jack and brought that in on a seperate layer but i cant get the picture of the jack to merge in with the picture of the girl, can you explain the best way for me to do that
thanks again for all your help
Stephen
done that and both layers are in seperate windows in the layers panel, but how exactly do i merge the 2 together? the merge option box does not highlight when my curser goes over it!
can you explain exactly how to go about it as i am starting to pull my hair out now!!
thanks again for all your kind help Sarkut
stephen
A layer is always merged down, into a layer below it.
If you have only two layers, make the top one the active layer.
Merging layers is done one layer at a time.
The menu option of Image > Flatten will combine all layers into one simultaneously,
whether you have two layers or a hundred layers. Which layer is active doesn't matter.
We are probably having a problem with semantics around the word
"merge" which has a specific jargon meaning in image editing.
Could you post a link to a full screenshot of the open file in Paint.NET?
Showing the full Paint.NET user interface with all floating windows?
http://www.take-a-screenshot.org/
http://imageshack.us/
Edited by Sarkut
If there is a Direct Link showing on the left near the bottom,right-click
the words Direct Link, copy link location, paste into the forum post.
Internet Explorer's right-click will say Copy Shortcut.
It varies with different browsers.
Edited by Sarkut
i have tried saving it in a word doc now and saved it on the desktop but when i try to upload it it tells me the file is invalid
thanks sarkut but i am really struggling here now !! its obvious that i am missing something silly but i really have tried everything!!
