Help Please!
Hi. My name is Jay, and i need help!!! I need a link to a plugin that lets you save as .PSD In paint.net I found one, and the link is http://psdplugin.codeplex.com I downloaded it, and then dragged the DLL file to the file in C:/Paint.net called FileTypes, but nothing happened. Can anyone help me!?! Or another way you could help is if I gave you a mediafire link with the .pdn and you converted it to a PSD or a gimp file. Please respond ASAP :) The link to the PDN file is http://www.mediafire.com/?3mw583j32zdc1fd Sorry if your not aloud to do ads D:
If the .dll was correctly installed in the File Types folder, restart Paint.Net.
With your .pdn file open, do:
File > Save As...
Photoshop .psd should now be an option in the Save as type: drop down menu of the Save As ... dialogue.
Edited by Sarkut
By restart, I mean close the program, then open it. Nothing more than that.
To install the file simply download the zip to Desktop or Downloads folder,
open the zip by left-click, copy/paste the .dll into the File Types folder.
Do you have 32 bit or 64 bit Windows?
Rick wasn't joking about the thread title. It's specifically mentioned in the Forum Rules
<locked>
