simmo Posted August 31, 2010 Share Posted August 31, 2010 Hi, I have .net 4.0 installed - yet anytime i go to run the install file for paint.net it tries to connect to download .net 3.5. I'm working on a testbed network with which has no internet connectivity - is there a paint.net install that just installs the application and doesnt try and install .net as well? So frustrating. Simon Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted August 31, 2010 Share Posted August 31, 2010 Install .NET 3.5 SP1 first. .NET 4 is only used if it's the only framework installed. If you're on Vista then you will always have .NET 2 and 3 installed, and Paint.NET cannot use .NET 4 in that case. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
simmo Posted August 31, 2010 Author Share Posted August 31, 2010 I'm actually using win 7 enterprise. anyway - thanks i'll give it a shot and let you know how it goes. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted August 31, 2010 Share Posted August 31, 2010 Win7 should have .NET 3.5 SP1 installed already. If you've removed it, then ... well ... un-remove it I guess. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
