mszlazak Posted August 17, 2010 Share Posted August 17, 2010 (edited) Is there a way to get 3d effects as in the following YouTube video: The images used can be found on Google Images but they are being "twisted" and distorted in 3d. Does Paint.net have this capability or do I need another tool ... preferably free. Also, there is a 2D effect where an image is blurred and then moved around. Again, is this something for paint.net or better left for another tool? If Paint.net is adequate then I was going to import the images/animations into windows movie maker. Thank you. Edited August 17, 2010 by mszlazak Quote Link to comment Share on other sites More sharing options...
Frontcannon Posted August 17, 2010 Share Posted August 17, 2010 I think Layers -> Rotate / Zoom (Ctrl+Shift+Z) does exactly what you want. Quote Night Vision Text Effect Tutorial Gallery reddit.com/r/futurebeats | My Mixcloud Link to comment Share on other sites More sharing options...
BoltBait Posted August 17, 2010 Share Posted August 17, 2010 You're better off using your video editing software's transitions. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
strass Posted August 18, 2010 Share Posted August 18, 2010 Theres no 3-d animating plugins but theres a plugin called "Shape 3-d" Quote Link to comment Share on other sites More sharing options...
