Ragged edge plugin?
Hi, everyone. I am creating documentation for a piece of software I've written. In this documentation I need to show reports listings (they are included as images in resulting .DOC file). The problem I have is I would need a plugin that creates ragged bottom edge to suggest the listing is longer but the paper was just torn apart.
I am currently doing it by hand by free selecting the bottom area of image and deleting the selection, but I am pretty sure there is a plugin somewhere that does that automatically.
I searched the forums and found an Image that looks pretty similar with what I need. I hope the tutorial creator will forgive me for using his image as sample:
I am talking about the left edge of the "upper" layer. Is there any plugin that "cuts" the edge in that way?
Thank you guys.
Maybe this will work:
Make several mostly transparent templates, like the image on the left.
Store them in a special .pdn file that you keep open while working on the other image files.
Tab over and copy a layer from the template pdn file,
switch back and paste into a new layer above your image for the document.
Giving a result like the right half of this picture.
http://a.imageshack.us/img217/558/17259840.png
Regards,
S.S. :)
