Kalagaraz Posted August 3, 2010 Share Posted August 3, 2010 I'm trying to create a game based on InkBall, but I'm not very artistic. I want to create a hole image similar to the one in this image: http://upload.wikimedia.org/wikipedia/en/2/22/InkBall_Vista.png but I only need it to be 32x32 instead of 128x128 and I only need the hole, not that fancy metal looking stuff around it. I've tried just creating a black circle and applying relief to it, but I just can't get a good hole look . I have no artistic ability what so ever. Quote Link to comment Share on other sites More sharing options...
Kalagaraz Posted August 3, 2010 Author Share Posted August 3, 2010 I had an idea to do a black-white gradient over an circle to do it. But I'm not sure how to apply a gradient to a circular selection, and I want to just darken/lighten the colors, not completely override them. Quote Link to comment Share on other sites More sharing options...
Kalagaraz Posted August 3, 2010 Author Share Posted August 3, 2010 You can use the to make a circle on a new layer then put your gradient in that. Holding shift while you draw will keep it a perfect circle Doing it on a new layer will allow you to lower opacity to your choice Made 2 circles and applied a gradient in between them and got this: I'm happy with it Quote Link to comment Share on other sites More sharing options...
Sozo Posted August 3, 2010 Share Posted August 3, 2010 Isn't there already a game called Inkball? With holes that look almost exactly like that? Quote Link to comment Share on other sites More sharing options...
Kalagaraz Posted August 3, 2010 Author Share Posted August 3, 2010 Isn't there already a game called Inkball? With holes that look almost exactly like that? Hence the first line of the first post "I'm creating a game based on InkBall" Quote Link to comment Share on other sites More sharing options...
Sozo Posted August 4, 2010 Share Posted August 4, 2010 (edited) Ahhh, forgive my poor eyesight. I thought it said a game called Inkball. Edited August 4, 2010 by CommanderSozo Quote Link to comment Share on other sites More sharing options...
Kalagaraz Posted August 4, 2010 Author Share Posted August 4, 2010 Ahhh, forgive my poor eyesight. I thought it said a game called Inkball. Na. Making a game pretty similar. Different scoring system and such, and more puzzleish. But still the same concept. I don't think I can get sued for that since it has a different scoring system and such and the overall "Win" condition is different so it's not the same game. Just the same principle, get colored balls into colored holes. Quote Link to comment Share on other sites More sharing options...
