ahmadyk23 Posted July 26, 2010 Share Posted July 26, 2010 Hello guys, I have just finished constructing an ID template for my company, it is measured at 3.375x2.125 inches (3.8x2.13), in order to print it out, what i do is i open a new blank white page measuring 8.5x11(normal printing paper), and then copy and paste the ID template from the other page to the new blank... On the blank sheet the ID still measures to 3.375x2.125, BUT, when i print it out, it is about 1 milimeter small on each side, why is this, and what can i do to fix it? Please and Thank you for your help PS: the pixels per inch is the same on both pages before i copy and paste so i know it has nothing to do with that Quote Link to comment Share on other sites More sharing options...
Sarkut Posted July 26, 2010 Share Posted July 26, 2010 ahmadyk23, Please try the following and report back whether it works or not. Paste the template into a file with an 8" X 10" canvas. Print at the 8x10 in. setting. Quote Link to comment Share on other sites More sharing options...
ahmadyk23 Posted July 26, 2010 Author Share Posted July 26, 2010 ahmadyk23, Please try the following and report back whether it works or not. Paste the template into a file with an 8" X 10" canvas. Print at the 8x10 in. setting. nope, it made it even smaller Quote Link to comment Share on other sites More sharing options...
ahmadyk23 Posted July 26, 2010 Author Share Posted July 26, 2010 nope, it made it even smaller check that... its the same size as previous Quote Link to comment Share on other sites More sharing options...
ahmadyk23 Posted July 27, 2010 Author Share Posted July 27, 2010 SOLVED: I used printer+ to take out the margins (set them to 0), now it is the exact size Quote Link to comment Share on other sites More sharing options...
