Help with my project
I'm trying to make a sig for another site that I am on and I can't seem to make the edges look neat and I am having a hard time merging the background and my pet together.
Here is the pic(s) I am trying to use:
When I remove the background and just leave her, the magic tool doesn't take all the stuff so I have to delete it but it looks rough, any tips for that?
And I'm trying to make a background with one of these prints:
I make this print width: 104 and the height: 100 pixels
I can't seem to make my pet and this print merge together tho. I just have to diff boxes one with my pet and one with the print. What am I doing wrong with this?
Then I am going to have a text that says "Queenie" but I have yet to get that far lol
Any help or tips would be great!!
Thank you very much
When you cut out your pet,
be sure that you don't have
a white background layer visible.
Save as PNG not .jpg.
Before saving the cut-out pet,
make a rectangular selection around it and crop to selection.
If the cut-out pet image is much larger in pixel dimensions than
the background, resize it before importing it.
Image > Resize
Edited by Sarkut
Thank you very much for your help.
I did what you said the only issue I have now is I can't place her over anything or she will delete the background behind her:
There has to be a step that I am messing up on but I don't know which one.
