W@@dy Posted June 19, 2010 Share Posted June 19, 2010 I'm trying to write effects in my spare time, very simple ones to get me started. I've been using the ones provided on boltbait.com, but some of the code is outdated Recently I've been trying to make lines at various angles This is the example provided // submenu: Render #region UICode double Amount1 = 45; // [-180,180] Angle #endregion void Render(Surface dst, Surface src, Rectangle rect) { int w = dst.Width, h = dst.Height; for (int y = rect.Top; y < rect.Bottom; y++) { for (int x = rect.Left; x < rect.Right; x++) { int u = 2 * x - w, v = 2 * y - h; dst[x, y] = ColorFunc( Math.Sqrt(u * u + v * v)+Amount1, Math.Atan2(v, u) ); } } } ColorBgra ColorFunc(double r, double t) { r /= 100; return ColorBgra.FromBgr( Utility.ClampToByte(128+127*Math.Sin(r+t)), Utility.ClampToByte(128+127*Math.Sin(Math.PI/2+r+t)), Utility.ClampToByte(128+127*Math.Sin(Math.PI+r+t)) ); } Utility.ClampToByte is no longer used by PDN apparently, so how do I rewrite the last lines? I tried on my own, but it caused several errors with converting double to int values (which I also tried to solve) Quote Link to comment Share on other sites More sharing options...
APShredder Posted June 19, 2010 Share Posted June 19, 2010 Just write your own Clamp function, it should look something like this. (I haven't tested this yet.) byte Clamp2Byte(int value) { if (value > 255) { return 255; } else if (value < 0) { return 0; } else { return (byte)value; } } EDIT: Sorry for the wierd formating. I tried to fix it but it won't format correctly. Quote BlendModes Plus | Dissolve | Extract Color Link to comment Share on other sites More sharing options...
Simon Brown Posted June 19, 2010 Share Posted June 19, 2010 Just write your own Clamp function Shorter version (not tested either): static byte ClampToByte(int input) { return (byte)Math.Max(Math.Min(input, 255), 0); } Quote Link to comment Share on other sites More sharing options...
pyrochild Posted June 19, 2010 Share Posted June 19, 2010 Shorter version (not tested either): static byte ClampToByte(int input) { return (byte)Math.Max(Math.Min(input, 0), 255); } Switch the max & min. I think.... really tired........ zzzzzzzzzzzzzzzz Quote http://i.imgur.com/xZYt6wl.png ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 19, 2010 Share Posted June 19, 2010 Umm, guys, Utility.ClampToByte's obsolete tag also includes a message telling you precisely what to do instead. It says, "Use Int32Util.ClampToByte() instead." Ergo, my guess is that Int32Util.ClampToByte() might be useful. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 20, 2010 Share Posted June 20, 2010 Is the obsolete attribute's message not showing up in CodeLab? Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
APShredder Posted June 20, 2010 Share Posted June 20, 2010 The error it gives is: "'PaintDotNet.Utility.ClampToByte(int)' is obsolete: 'Use the ClampToByte extension method instead' (CS0619)" It does say anything about "Int32Util.ClampToByte()". Quote BlendModes Plus | Dissolve | Extract Color Link to comment Share on other sites More sharing options...
W@@dy Posted June 20, 2010 Author Share Posted June 20, 2010 Umm, guys, Utility.ClampToByte's obsolete tag also includes a message telling you precisely what to do instead. It says, "Use Int32Util.ClampToByte() instead." Ergo, my guess is that Int32Util.ClampToByte() might be useful. That's what I tried first, and then conversion errors arose. It's rather probable that I just don't know what I'm doing. I have virtually no proper knowledge in C#. I started coding on a TI-83, then started teaching myself C#. When college starts I'll get some real classes on this, but so far I only know what I've learned from online tutorials Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 20, 2010 Share Posted June 20, 2010 Ahh I must have changed the comment in the v4.0 code base then. The Utility class is being phased out, its functionality being moved into various *Util and *Extensions static classes. Extension methods are easy to use too. int x = ...; byte y = x.ClampToByte(); byte z = (int)(some expression).ClampToByte(); Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
W@@dy Posted June 21, 2010 Author Share Posted June 21, 2010 ColorBgra ColorFunc(double r, double t) { r /= 100; return ColorBgra.FromBgra( (int)(128+127*Math.Sin(r+t)).ClampToByte(), (int)(128+127*Math.Sin(r+t)).ClampToByte(), (int)(128+127*Math.Sin(Math.PI+r+t)).ClampToByte() ); } Like that? " 'double' does not contain a definition for 'ClampToByte' " Does that even make sense?... Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 21, 2010 Share Posted June 21, 2010 That's because the extension method is being applied before the typecast operator is. (int)(some double expression).ExtensionMethod(); is equivalent to (int)((some double expression).ExtensionMethod()); Notice the placement of parenthesis. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
pyrochild Posted June 21, 2010 Share Posted June 21, 2010 ColorBgra ColorFunc(double r, double t) { r /= 100; return ColorBgra.FromBgra( (int)(128+127*Math.Sin(r+t)).ClampToByte(), (int)(128+127*Math.Sin(r+t)).ClampToByte(), (int)(128+127*Math.Sin(Math.PI+r+t)).ClampToByte() ); } Like that? " 'double' does not contain a definition for 'ClampToByte' " Does that even make sense?... It makes perfect sense; you're trying to call a method called "ClampToByte" on a double, and it doesn't have one. You need to cast to an int first, since that's what the extension is defined for. ((int)(128+127*Math.Sin(r+t))).ClampToByte() Note how the .ClampToByte is now being called on the int-casted expression, instead of just "(128+127*Math.Sin(r+t))" which is a double. Quote http://i.imgur.com/xZYt6wl.png ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to comment Share on other sites More sharing options...
W@@dy Posted June 22, 2010 Author Share Posted June 22, 2010 Oh so, (int) defines it as an integer, and without placing parenthesis around it like this ((int)(128+127*Math.Sin(r+t))).ClampToByte() It's left out of the ClampToByte() Method? I didn't realize the ClampToByte() was a method. It's rather obvious now, I just tend to overlook some of the more obvious things like this haha. So now it says int doesn't have a definition in ClampToByte Ugh, I hate being so ignorant and useless Quote Link to comment Share on other sites More sharing options...
