Brush in overwrite mode looks odd with alpha=100
PDN v3.5.5
Haven't seen this one reported yet
Repro steps:
1) Active the brush tool
2) Set the size to 50 (helps for visibility of the problem)
3) Expand to "More" in the colors window and set the alpha to 100
4) Change from "Normal blending" to "Overwrite"
5) Draw
Result:
Should those white lines be there?
There are no warranties whatsoever on my plug-ins. Use them at your own risk. You may redistribute them if you'd like, but I'd prefer you just link to the download on my site. Please do not modify and redistribute.
