2464: Small Issue With New Adjustments Menu
The little icon for the Sepia adjustment has opaque edges that should be transparent. I can get a screenshot if you want.
Yeah it's been that way since 2.6 actually! I'll fix it don't worry :)
Also, it's not obvious anymore that the "Adjustments" only affect a single layer...do you think this will be a problem?
Shouldn't be any more of a problem than with the Effects menu, I'd imagine.
