Martel Posted May 24, 2010 Share Posted May 24, 2010 WinXP MCE SP3 Trying to print a pic from my digital camera the image size is 2896x1944 seemingly plenty big enough But when windows prints at 8x10 the edges get cut off I looked at PDN post Setting it to a canvas size anchored middle gives me a big white border. any help appreciated Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted May 24, 2010 Share Posted May 24, 2010 It's big enough to make an 8x10 photo, but you can't shrink it, keep the dimension ratios, and not clip off a bit of the edges all at the same time. It's too wide. Either you distort the image or you cut off the edges. Quote No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
Martel Posted May 24, 2010 Author Share Posted May 24, 2010 (edited) pdnnoob, Thanks for the reply. Do you think it would help to choose another setting in my camera menu. (Nikon D60) Choices are Large 3872 x 2592 medium 2896 x 1944 small 1936 x 1296 EDIT: I am o.k. with cutting off some edges my subjects are in the center with about an inch on the sides and more on top and bottom. ...scratching head Edited May 24, 2010 by Martel Quote Link to comment Share on other sites More sharing options...
Sarkut Posted May 24, 2010 Share Posted May 24, 2010 The image as it comes from the camera isn't in an 8X10 aspect ratio. So, cropping to an 8X10 ratio first may help. Using Rectangular Selection, change the toolbar setting from "Normal" to "Fixed Ratio". Enter 8 and 10 in the Width and Height adjustment, as appropriate. Position and size the rectangular selection, then: Image > Crop to Selection. Quote Link to comment Share on other sites More sharing options...
miller32807 Posted February 1, 2011 Share Posted February 1, 2011 Thanks so much. I knew there had to be a way to do this in paint.net, but I had never figured it out. Glad I searched it just now The image as it comes from the camera isn't in an 8X10 aspect ratio. So, cropping to an 8X10 ratio first may help. Using Rectangular Selection, change the toolbar setting from "Normal" to "Fixed Ratio". Enter 8 and 10 in the Width and Height adjustment, as appropriate. Position and size the rectangular selection, then: Image > Crop to Selection. Quote Link to comment Share on other sites More sharing options...
