Help with Layers
I see many how to's of how to do things in Layers but not how to merge them. When I flatten I end up with the checkerboard look.
I need specifics...
Do you click on all layers and merge down
or
Do you click on all layers and flatten?
Just how do you put them all together?
Thank you.
I need specifics...
It all depends on what specifically you want to accomplish.
If you have the image looking the way you want it, and want to
save it as a standard image file - PNG, JPEG, etc. then flatten it.
Using the flatten function should make no change to what appears on the canvas.
Edited by Sarkut
I try to soften the portrait in the top layer then change the opacity. That's when I get the checkerboard and it stays no matter how I flatten or merge.
What is the difference between merge (self explanatory) and flatten?
If you reduce opacity in a layer and don't want to see the checkerboard,
then you need to have a background layer with full, or at least adequate,
opacity to make up for the reduced opacity in the portrait layer.
