JimBo Posted May 16, 2010 Share Posted May 16, 2010 Hi please forgive me if this has been covered before but I am new to this forum and Paint Net and wondered if I could have some advice if it is at all possible to remove the concrete post, which is down the middle of the photograph and is it easy to do so a novice like myself could do it. Quote Link to comment Share on other sites More sharing options...
warfighter67 Posted May 16, 2010 Share Posted May 16, 2010 There is no way at all to remove that post in the picture, and seeing the missing parts of the car behind it, unless you are a really good pixel artist and spend 3 days doing it. Quote My Soundclick!--Well of Souls MMO--Gallery--Facebook--Photobucket--Cool Tile Texture! Link to comment Share on other sites More sharing options...
ptuZ Posted May 16, 2010 Share Posted May 16, 2010 yea, thats a lost cause Quote My Forum Gallery My dA Gallery Graffiti tutorial Link to comment Share on other sites More sharing options...
Sarkut Posted May 16, 2010 Share Posted May 16, 2010 (edited) JimBo, One way to fake it is as follows. Find similar looking areas in the picture. Copy and paste selections into new layer, position, merge. To make things match up, the pasted/selected bits can be rotated, stretched, compressed using the selection adjustment nodes and the Move Selected Pixels tool. When positioned right, deselect and apply feather object. Some minor brightness adjustment with Brightness / Contrast can give a smoother blend. http://img31.imageshack.us/img31/6614/carpasted01.png You'll probably need to spend some time working with it to build your skill, but it's worth knowing how to do this. Edited May 16, 2010 by Sarkut Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted May 17, 2010 Share Posted May 17, 2010 If you want to try something that is more automated, try this plugin: Fill Gaps v1.0. You'll have to delete the concrete post first (see linked post where the plugin fills in the space where models' mouth is erased). Do make a backup copy before you start! Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Sarkut Posted May 17, 2010 Share Posted May 17, 2010 Somone should create a Move-the-Post-to-the-Right plugin. http://img156.imageshack.us/img156/8612/carpasted03.png Quote Link to comment Share on other sites More sharing options...
JimBo Posted May 17, 2010 Author Share Posted May 17, 2010 Somone should create a Move-the-Post-to-the-Right plugin. http://img156.imageshack.us/img156/8612/carpasted03.png If you could tell me how you did that or even better move the post completely to the right of the car? Also thanks to all the replys, like I said I am new to Paint Net and this forum and all the help as been most appreciated. Quote Link to comment Share on other sites More sharing options...
Sarkut Posted May 17, 2010 Share Posted May 17, 2010 I just did what I described in my previous post. Added the post back in as a joke. Quote Link to comment Share on other sites More sharing options...
Sarkut Posted May 17, 2010 Share Posted May 17, 2010 I'm not sure whether you know what I was talking about previously. Keyboard shortcuts - Ctrl + C ................. Copy Ctrl + Shift + V ...... Paste into a new layer http://img218.imageshack.us/img218/302/carpasted04.png Quote Link to comment Share on other sites More sharing options...
Sarkut Posted June 7, 2010 Share Posted June 7, 2010 The method described in this tutorial will be helpful for this. The Subterranean Copy/Paste Blues Quote Link to comment Share on other sites More sharing options...
