nadea Posted September 29, 2006 Share Posted September 29, 2006 i want to use the same watermark on several paintings. do i have to create the copyright and text each time i open up paint or is there a way to reuse the watermark somehow? Quote Link to comment Share on other sites More sharing options...
t2suggas Posted September 29, 2006 Share Posted September 29, 2006 If you make your watermark on a new layer, you can select it, copy, paste into a new paint.net, then save where you can find it again. Quote Link to comment Share on other sites More sharing options...
entY8 Posted September 29, 2006 Share Posted September 29, 2006 i want to use the same watermark on several paintings. do i have to create the copyright and text each time i open up paint or is there a way to reuse the watermark somehow?Put the watermark in a separate image and everytime you need the watermark use "Layers->Import From File ..." and put the new layer on top (you might also want to adjust its opacity each time). Quote Link to comment Share on other sites More sharing options...
nadea Posted September 29, 2006 Author Share Posted September 29, 2006 ahh, so easy yet i would have never thought of it. thanks! Quote Link to comment Share on other sites More sharing options...
