null54 Posted June 5, 2018 Share Posted June 5, 2018 13 minutes ago, nickdwaters said: Dropbox giving 404 when attempting to dl the v4 zip file. Ack! @Pixey added a temporary DropBox link to the 2009 version (which still works in 4.0.x) above the 4.0 download in the first post. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
saccie Posted January 6, 2022 Share Posted January 6, 2022 Greetings, i have this error. latest paint.net This text file was created because paint.net crashed. Please e-mail this to crashlog4@getpaint.net so we can diagnose and fix the problem. Application version: paint.net 4.3.7 (Stable 4.307.8039.30451) Time of crash: 6/01/2022 3:43:35 PM Application uptime: 00:01:06.2422891 Application state: Running Working set: 368,660 KiB Handles and threads: 1019 handles, 44 threads, 205 gdi, 258 user Install type: Portable Application directory: C:\Users\SPC\Apps\pdn Current directory: C:\Users\SPC\Apps\pdn Install directory: C:\pdn OS Version: Windows 10 Pro 10.0.19041.0 x64 .NET version: .NET 6.0.1 x64 Processor: "Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz" @ ~3504MHz (4C/4T, SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, AVX, AVX2) Physical memory: 16350 MB Video card: NVIDIA GeForce GTX 970 (v:10DE, d:13C2, r:161), Microsoft Basic Render Driver (v:1414, d:8C, r:0) Hardware acceleration: True (default: True) Pointers: none UI animations: True UI DPI: 96 dpi (1.00x scale) UI theme: VisualStyleCategory=Aero, EffectiveTheme=Aero, DWM=yes, AeroColorScheme=Dark, ThemeFileName=Aero.msstyles Updates: n/a Locale: pdnr.c: en-US, hklm: n/a, hkcu: en-US, cc: en-AU, cuic: en-US Flags: Exception details: System.MissingMethodException: Method not found: 'Int32 PaintDotNet.SystemLayer.Processor.get_LogicalCpuCount()'. at EdHarvey.FastFx.FastBlurNegIntensity.AppplyHorizontalBlur(Surface src, SurfaceG8 dst, Int32 radius, Rectangle blurBounds) at EdHarvey.FastFx.PencilSketchEffect.OnRender(Rectangle[] rois, Int32 startIndex, Int32 length) in M:\EdFects-3.50\EdFects\EffectsPlus\PencilSketchEffect.cs:line 175 at PaintDotNet.Effects.Effect`1.Render(EffectConfigToken parameters, RenderArgs dstArgs, RenderArgs srcArgs, Rectangle[] rois, Int32 startIndex, Int32 length) in D:\src\pdn\src_4_3_x\Effects\Effect`1.cs:line 98 at PaintDotNet.Effects.BackgroundEffectRenderer.RenderWithClipMask(Effect effect, EffectConfigToken token, RenderArgs dstArgs, RenderArgs srcArgs, RectInt32[] rois, Result`1 lazyClipMaskRenderer) in D:\src\pdn\src_4_3_x\PaintDotNet\Effects\BackgroundEffectRenderer.cs:line 192 at PaintDotNet.Effects.BackgroundEffectRenderer.RendererContext.RenderTile(EffectConfigToken token, Int32 tileIndex) in D:\src\pdn\src_4_3_x\PaintDotNet\Effects\BackgroundEffectRenderer.cs:line 170 at PaintDotNet.Effects.BackgroundEffectRenderer.RendererContext.RenderNextTile(EffectConfigToken token) in D:\src\pdn\src_4_3_x\PaintDotNet\Effects\BackgroundEffectRenderer.cs:line 163 at PaintDotNet.Effects.BackgroundEffectRenderer.RendererContext.RenderNextTileProc(Object token) in D:\src\pdn\src_4_3_x\PaintDotNet\Effects\BackgroundEffectRenderer.cs:line 143 at PaintDotNet.Effects.BackgroundEffectRenderer.<>c__DisplayClass31_1.<ThreadFunction>b__0() in D:\src\pdn\src_4_3_x\PaintDotNet\Effects\BackgroundEffectRenderer.cs:line 283 at PaintDotNet.Effects.EffectRendererWorkItemQueue.OnExecuteNextWorkItem() in D:\src\pdn\src_4_3_x\PaintDotNet\Effects\EffectRendererWorkItemQueue.cs:line 124 at PaintDotNet.Threading.MultithreadedWorkItemDispatcher.WorkThreadProc(Object context) in D:\src\pdn\src_4_3_x\Core\Threading\MultithreadedWorkItemDispatcher.cs:line 495 at System.Threading.Thread.StartHelper.Callback(Object state) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state) --- End of stack trace from previous location --- at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.Thread.StartCallback() Managed assemblies: System.Private.CoreLib, .\System.Private.CoreLib.dll, Version=6.0.0.0, PublicKeyToken=7cec85d7bea7798e paintdotnet, .\paintdotnet.dll, Version=4.307.8039.30451 System.Runtime, .\System.Runtime.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Windows.Forms, .\System.Windows.Forms.dll, Version=6.0.1.0, PublicKeyToken=b77a5c561934e089 PaintDotNet.Base, .\PaintDotNet.Base.dll, Version=4.307.8039.30451 System.Diagnostics.Process, .\System.Diagnostics.Process.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a TerraFX.Interop.Windows, .\TerraFX.Interop.Windows.dll, Version=10.0.20348.0, PublicKeyToken=35b01b53313a6f7e PaintDotNet.SystemLayer, .\PaintDotNet.SystemLayer.dll, Version=4.307.8039.30451 System.Runtime.InteropServices.RuntimeInformation, .\System.Runtime.InteropServices.RuntimeInformation.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.InteropServices, .\System.Runtime.InteropServices.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.SystemLayer.Native.x64, .\PaintDotNet.SystemLayer.Native.x64.dll, Version=4.307.8039.30451 System.Threading, .\System.Threading.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Extensions, .\System.Runtime.Extensions.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.CompilerServices.VisualC, .\System.Runtime.CompilerServices.VisualC.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections.NonGeneric, .\System.Collections.NonGeneric.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Intrinsics, .\System.Runtime.Intrinsics.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 PaintDotNet.Core, .\PaintDotNet.Core.dll, Version=4.307.8039.30451 System.Private.Uri, .\System.Private.Uri.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ComponentModel.Primitives, .\System.ComponentModel.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a WindowsBase, .\WindowsBase.dll, Version=6.0.1.0, PublicKeyToken=31bf3856ad364e35 System.Windows.Forms.Primitives, .\System.Windows.Forms.Primitives.dll, Version=6.0.1.0, PublicKeyToken=b77a5c561934e089 PresentationFramework, .\PresentationFramework.dll, Version=6.0.1.0, PublicKeyToken=31bf3856ad364e35 System.Drawing.Primitives, .\System.Drawing.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Xaml, .\System.Xaml.dll, Version=6.0.1.0, PublicKeyToken=b77a5c561934e089 System.ComponentModel, .\System.ComponentModel.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Diagnostics.TraceSource, .\System.Diagnostics.TraceSource.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections, .\System.Collections.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Threading.Thread, .\System.Threading.Thread.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Text.Encoding.CodePages, .\System.Text.Encoding.CodePages.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Microsoft.Win32.Primitives, .\Microsoft.Win32.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Resources, .\PaintDotNet.Resources.dll, Version=4.307.8039.30451 Newtonsoft.Json, .\Newtonsoft.Json.dll, Version=13.0.0.0, PublicKeyToken=30ad4fe6b2a6aeed System.Configuration.ConfigurationManager, .\System.Configuration.ConfigurationManager.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Linq.Expressions, .\System.Linq.Expressions.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections.Specialized, .\System.Collections.Specialized.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ComponentModel.TypeConverter, .\System.ComponentModel.TypeConverter.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ObjectModel, .\System.ObjectModel.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Xml.ReaderWriter, .\System.Xml.ReaderWriter.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Private.Xml, .\System.Private.Xml.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Net.WebClient, .\System.Net.WebClient.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Runtime.Numerics, .\System.Runtime.Numerics.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ComponentModel.EventBasedAsync, .\System.ComponentModel.EventBasedAsync.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Data, .\PaintDotNet.Data.dll, Version=4.307.8039.30451 System.Memory, .\System.Memory.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Text.Encoding.Extensions, .\System.Text.Encoding.Extensions.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Framework, .\PaintDotNet.Framework.dll, Version=4.307.8039.30451 Microsoft.Win32.SystemEvents, .\Microsoft.Win32.SystemEvents.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 Microsoft.Win32.Registry, .\Microsoft.Win32.Registry.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Drawing.Common, .\System.Drawing.Common.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Linq, .\System.Linq.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Threading.ThreadPool, .\System.Threading.ThreadPool.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections.Immutable, .\System.Collections.Immutable.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PresentationCore, .\PresentationCore.dll, Version=6.0.1.0, PublicKeyToken=31bf3856ad364e35 System.Collections.Concurrent, .\System.Collections.Concurrent.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a DirectWriteForwarder, .\DirectWriteForwarder.dll, Version=6.0.1.0, PublicKeyToken=31bf3856ad364e35 System.Diagnostics.Debug, .\System.Diagnostics.Debug.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Serialization.Primitives, .\System.Runtime.Serialization.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a UIAutomationTypes, .\UIAutomationTypes.dll, Version=6.0.1.0, PublicKeyToken=31bf3856ad364e35 System.Diagnostics.FileVersionInfo, .\System.Diagnostics.FileVersionInfo.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Effects, .\PaintDotNet.Effects.dll, Version=4.307.8039.30451 Accessibility, .\Accessibility.dll, Version=4.0.0.0, PublicKeyToken=31bf3856ad364e35 System.Numerics.Vectors, .\System.Numerics.Vectors.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Crc32.NET, .\Crc32.NET.dll, Version=1.0.0.0, PublicKeyToken=dc0b95cf99bf4e99 System.Security.Cryptography.Primitives, .\System.Security.Cryptography.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Threading.Tasks.Parallel, .\System.Threading.Tasks.Parallel.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.IO.Packaging, .\System.IO.Packaging.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Reflection.MetadataLoadContext, .\System.Reflection.MetadataLoadContext.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Diagnostics.Tracing, .\System.Diagnostics.Tracing.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Reflection.Metadata, .\System.Reflection.Metadata.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Loader, .\System.Runtime.Loader.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.IO.MemoryMappedFiles, .\System.IO.MemoryMappedFiles.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a ABRFileType, .\FileTypes\ABRFileType.dll, Version=1.3.0.0 PaintShopProFiletype, .\FileTypes\PaintShopProFiletype.dll, Version=1.0.2.0 Jpeg2000Filetype, .\FileTypes\Jpeg2000Filetype.dll, Version=1.0.1.0 RawFileType, .\FileTypes\RawFileType.dll, Version=1.2.2.0 Base64FileType, .\FileTypes\Base64FileType.dll, Version=1.0.0.8 AnimGIF, .\FileTypes\AnimGIF.dll, Version=2.4.4119.28305 PatternFileType, .\FileTypes\PatternFileType.dll, Version=1.0.5.0 OptimizedJPEG, .\FileTypes\OptimizedJPEG.dll, Version=1.0.2.0 TileImageFileType, .\FileTypes\TileImageFileType.dll, Version=1.0.0.1 FSHfiletype, .\FileTypes\FSHfiletype.dll, Version=1.2.4.0 mscorlib, .\mscorlib.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089 System, .\System.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089 System.Drawing, .\System.Drawing.dll, Version=6.0.1.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Serialization.Formatters, .\System.Runtime.Serialization.Formatters.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a DdsFileTypePlus, .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, Version=1.10.10.0 AvifFileType, .\Bundled\AvifFileType\AvifFileType.dll, Version=1.1.17.0 WebPFileType, .\Bundled\WebPFileType\WebPFileType.dll, Version=1.3.7.0 System.Core, .\System.Core.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089 Mono.Cecil, .\Mono.Cecil.dll, Version=0.11.4.0, PublicKeyToken=50cebf1cceb9d05e netstandard, .\netstandard.dll, Version=2.1.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.CodeDom, .\System.CodeDom.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Security.Claims, .\System.Security.Claims.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a XYCoords, .\Effects\XYCoords.dll, Version=1.0.0.0 System.Console, .\System.Console.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a xmario_cut_color_en, .\Effects\xmario_cut_color_en.dll, Version=1.0.3769.28056 System.Text.RegularExpressions, .\System.Text.RegularExpressions.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a X Rainbow bars, .\Effects\X Rainbow bars.dll, Version=1.0.3536.37632 WhichSymbolPlus, .\Effects\WhichSymbolPlus.dll, Version=1.0.0.0 WhichSymbol, .\Effects\WhichSymbol.dll, Version=2.0.3112.39397 WetFloor, .\Effects\WetFloor.dll, Version=1.1.0.0 Burninate, .\Effects\Burninate.dll, Version=4.6.7358.31797 ColorBalance, .\Effects\ColorBalance.dll, Version=4.7.7401.17173 BandWPlus, .\Effects\BandWPlus.dll, Version=1.3.7359.317 WaveTextSUI, .\Effects\WaveTextSUI.dll, Version=1.2.4415.33440 PaintDotNet.Plugins.Compatibility, .\PaintDotNet.Plugins.Compatibility.dll, Version=4.307.8039.30451 Alpha2Gray, .\Effects\Alpha2Gray.dll, Version=4.5.6832.21862 Curves+, .\Effects\Curves+.dll, Version=4.0.4642.26561 WaveText, .\Effects\WaveText.dll, Version=1.2.4415.32811 Waves, .\Effects\Waves.dll, Version=1.1.0.0 WaterReflection, .\Effects\WaterReflection.dll, Version=1.1.0.0 CombinedAdjustments, .\Effects\CombinedAdjustments.dll, Version=1.1.7358.40688 Volutes, .\Effects\Volutes.dll, Version=1.1.0.0 Dream, .\Effects\Dream.dll, Version=4.6.7358.35004 EdHarvey.Effects, .\Effects\EdHarvey.Effects.dll, Version=4.0.5120.42730 System.Windows.Forms.Legacy, .\System.Windows.Forms.Legacy.dll, Version=0.1.1.0 Vignette1, .\Effects\Vignette1.dll, Version=1.0.3538.14367 System.Runtime.CompilerServices.Unsafe, .\System.Runtime.CompilerServices.Unsafe.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Design, .\System.Design.dll, Version=6.0.1.0, PublicKeyToken=b03f5f7f11d50a3a System.Windows.Forms.Design, .\System.Windows.Forms.Design.dll, Version=6.0.1.0, PublicKeyToken=b77a5c561934e089 Vibrato, .\Effects\Vibrato.dll, Version=1.1.0.0 Vibration, .\Effects\Vibration.dll, Version=1.0.4407.34043 FillFromClipboard, .\Effects\FillFromClipboard.dll, Version=4.7.7358.36519 EditableText, .\Effects\EditableText.dll, Version=1.0.1.0 FillFromFile, .\Effects\FillFromFile.dll, Version=4.7.7358.36581 Vandermotten.PaintDotNetEffects.ObjectAlign, .\Effects\Vandermotten.PaintDotNetEffects.ObjectAlign.dll, Version=3.8.0.0 Vandermotten.PaintDotNetEffects, .\Effects\Vandermotten.PaintDotNetEffects.dll, Version=3.8.0.0 System.Xml, .\System.Xml.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089 Gray2Alpha, .\Effects\Gray2Alpha.dll, Version=4.5.6826.36897 Vandermotten.PaintDotNetEffects.Monochromes, .\Effects\Vandermotten.PaintDotNetEffects.Monochromes.dll, Version=3.8.0.0 Vandermotten.PaintDotNetEffects, .\Effects\Vandermotten.PaintDotNetEffects.dll, Version=3.8.0.0 System.Diagnostics.StackTrace, .\System.Diagnostics.StackTrace.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a FloydSteinbergDithering, .\Effects\FloydSteinbergDithering.dll, Version=4.6.7358.37110 Vandermotten.PaintDotNetEffects.Grid, .\Effects\Vandermotten.PaintDotNetEffects.Grid.dll, Version=3.8.0.0 Vandermotten.PaintDotNetEffects, .\Effects\Vandermotten.PaintDotNetEffects.dll, Version=3.8.0.0 Vandermotten.PaintDotNetEffects.Gradient, .\Effects\Vandermotten.PaintDotNetEffects.Gradient.dll, Version=3.8.0.0 Vandermotten.PaintDotNetEffects, .\Effects\Vandermotten.PaintDotNetEffects.dll, Version=3.8.0.0 Vandermotten.PaintDotNetEffects.FadeEdge, .\Effects\Vandermotten.PaintDotNetEffects.FadeEdge.dll, Version=3.8.0.0 Vandermotten.PaintDotNetEffects, .\Effects\Vandermotten.PaintDotNetEffects.dll, Version=3.8.0.0 HSVGradients, .\Effects\HSVGradients.dll, Version=4.5.6832.41864 Vandermotten.PaintDotNetEffects.Duotones, .\Effects\Vandermotten.PaintDotNetEffects.Duotones.dll, Version=3.8.0.0 Vandermotten.PaintDotNetEffects, .\Effects\Vandermotten.PaintDotNetEffects.dll, Version=3.8.0.0 HueSatPlus, .\Effects\HueSatPlus.dll, Version=4.6.7359.209 CustomBrushesMini, .\Effects\CustomBrushesMini.dll, Version=2.2.5286.39584 Vandermotten.PaintDotNetEffects.DropShadow, .\Effects\Vandermotten.PaintDotNetEffects.DropShadow.dll, Version=3.8.0.0 Vandermotten.PaintDotNetEffects, .\Effects\Vandermotten.PaintDotNetEffects.dll, Version=3.8.0.0 Vandermotten.PaintDotNetEffects.ColorAccent, .\Effects\Vandermotten.PaintDotNetEffects.ColorAccent.dll, Version=3.8.0.0 Vandermotten.PaintDotNetEffects, .\Effects\Vandermotten.PaintDotNetEffects.dll, Version=3.8.0.0 Vandermotten.PaintDotNetEffects.Blurs, .\Effects\Vandermotten.PaintDotNetEffects.Blurs.dll, Version=3.8.0.0 Vandermotten.PaintDotNetEffects, .\Effects\Vandermotten.PaintDotNetEffects.dll, Version=3.8.0.0 SBCommon, .\Effects\SBCommon.dll, Version=3.0.0.0 Landscape, .\Effects\Landscape.dll, Version=4.6.7358.37463 Unblend v1, .\Effects\Unblend.dll, Version=1.0.5176.26202 TwoToneThreshold, .\Effects\TwoToneThreshold.dll, Version=1.0.0.0 LevelHorizon, .\Effects\LevelHorizon.dll, Version=4.6.7358.37589 TwoPointPerspective, .\Effects\TwoPointPerspective.dll, Version=1.6.0.0 TwistZ, .\Effects\TwistZ.dll, Version=1.1.2.0 ObjectTools, .\Effects\ObjectTools.dll, Version=5.0.7502.21624 Twist, .\Effects\Twist.dll, Version=4.0.4642.26767 Tweaktrans2, .\Effects\Tweaktrans2.dll, Version=2.0.4252.27152 Tweaktrans4, .\Effects\Tweaktrans.dll, Version=1.0.4193.41856 Tweakedges, .\Effects\Tweakedges.dll, Version=1.0.4252.39711 TwainablePlus, .\Effects\TwainablePlus.dll, Version=1.0.0.2 TubeOblique, .\Effects\TubeOblique.dll, Version=1.0.0.0 TRsZigZag, .\Effects\TRsZigZag.dll, Version=1.1.4929.6773 TRsTreeMaker, .\Effects\TRsTreeMaker.dll, Version=1.0.3.0 TRsTiltShift, .\Effects\TRsTiltShift.dll, Version=1.0.4957.12341 TRsTiledPixels, .\Effects\TRsTiledPixels.dll, Version=1.2.4942.13226 TRsThirdDimension, .\Effects\TRsThirdDimension.dll, Version=1.7.13.38717 TRsTeslaCoil, .\Effects\TRsTeslaCoil.dll, Version=1.0.4935.18219 TRsStrobeMotion, .\Effects\TRsStrobeMotion.dll, Version=1.2.4962.30523 TRsStrangeAttractor, .\Effects\TRsStrangeAttractor.dll, Version=1.1.4.0 TRsStr8Edge, .\Effects\TRsStr8Edge.dll, Version=1.1.5045.31905 TRsStarFilter, .\Effects\TRsStarFilter.dll, Version=1.0.4930.9612 TRsSplineMaster, .\Effects\TRsSplineMaster.dll, Version=1.4.2.18310 TRsSphereCuber, .\Effects\TRsSphereCuber.dll, Version=1.0.1.0 TRsSnowFlakeMaker, .\Effects\TRsSnowFlakeMaker.dll, Version=1.0.1.1701 TRsSmudger, .\Effects\TRsSmudger.dll, Version=2.2.0.0 TRsSelfeez, .\Effects\TRsSelfeez.dll, Version=1.0.2.0 TRsRetouch, .\Effects\TRsRetouch.dll, Version=1.0.5684.16160 TRsRadialExtruder, .\Effects\TRsRadialExtruder.dll, Version=1.2.5609.8244 TRsPSnap, .\Effects\TRsPSnap.dll, Version=1.2.0.0 TRsPlasmatix, .\Effects\TRsPlasmatix.dll, Version=1.0.5220.31660 TRsPixelSharp, .\Effects\TRsPixelSharp.dll, Version=2.0.5467.31590 TRsPixelPuller, .\Effects\TRsPixelPuller.dll, Version=1.1.4994.29625 TRsPasteWarp, .\Effects\TRsPasteWarp.dll, Version=1.0.0.0 TRsPasteFrame, .\Effects\TRsPasteFrame.dll, Version=1.3.20.9613 TRsMonolithic, .\Effects\TRsMonolithic.dll, Version=1.0.4.12960 TRsKaboom, .\Effects\TRsKaboom.dll, Version=1.0.5118.21464 TRsIsopleth, .\Effects\TRsIsopleth.dll, Version=1.0.3.10995 TRsiPollock, .\Effects\TRsIPollock.dll, Version=1.0.3.11944 TRsIntensityWarp, .\Effects\TRsIntensityWarp.dll, Version=1.3.0.0 TRsIntenseFilteration, .\Effects\TRsIntenseFilteration.dll, Version=1.3.5390.22367 TRsHDRish, .\Effects\TRsHDRish.dll, Version=1.0.5198.19546 TRsHalfTone, .\Effects\TRsHalfTone.dll, Version=1.0.4937.7773 TRsGlassVignette, .\Effects\TRsGlassVignette.dll, Version=1.1.5239.30797 TRsFuego, .\Effects\TRsFuego.dll, Version=1.0.5.0 TRsFireWorks, .\Effects\TRsFireWorks.dll, Version=1.2.0.0 TRsFilmStripPlgIn, .\Effects\TRsFilmStripPlgIn.dll, Version=1.0.2.0 PasteAlpha, .\Effects\PasteAlpha.dll, Version=4.6.7358.38804 TRsFilmStock, .\Effects\TRsFilmStock.dll, Version=1.2.0.0 Pastel, .\Effects\Pastel.dll, Version=4.6.7358.38877 TRsFilaments, .\Effects\TRsFilaments.dll, Version=1.0.15.11399 TRsExportSelection, .\Effects\TRsExportSelection.dll, Version=1.0.5668.9645 TRsDrumSkin, .\Effects\TRsDrumSkin.dll, Version=1.4.5199.15427 PhotoAdjustments, .\Effects\PhotoAdjustments.dll, Version=4.6.7358.38979 RemoveDust, .\Effects\RemoveDust.dll, Version=4.5.6826.37862 Polygon, .\Effects\Polygon.dll, Version=4.5.6828.38648 TRsDodgeBurn, .\Effects\TRsDodgeBurn.dll, Version=1.4.0.33503 Scribble, .\Effects\Scribble.dll, Version=1.0.1.0 SelectionInnerContour, .\Effects\SelectionInnerContour.dll, Version=0.0.0.0 SeamCarving, .\Effects\SeamCarving.dll, Version=4.6.7358.39596 TRsDodgeBurn.resources, .\Effects\TRsDodgeBurn.resources.dll, Version=1.3.26.12436, Culture=zh-CN CustomControls, .\Effects\CustomControls.dll, Version=0.0.0.0 GpcDotNet.Interface, .\Effects\GpcDotNet.Interface.dll, Version=0.0.0.0 Shape3D, .\Effects\Shape3D.dll, Version=1.2.6.0 TRsCustomRandomFill, .\Effects\TRsCustomRandomFill.dll, Version=1.5.1.31287 GpcDotNet.AMD64, .\Effects\GpcDotNet.AMD64.dll, Version=0.0.0.0 SelectionTools, .\Effects\SelectionTools.dll, Version=5.0.7502.22140 SoftProofing, .\Effects\SoftProofing.dll, Version=1.1.0.1 TRsCustomPaletteMatch, .\Effects\TRsCustomPaletteMatch.dll, Version=1.0.5.0 TRsCroquis, .\Effects\TRsCroquis.dll, Version=1.4.5634.10354 TRsCoquin, .\Effects\TRsCoquin.dll, Version=1.0.4960.31131 TRsContourFiller, .\Effects\TRsContourFiller.dll, Version=1.5.2.0 Temperature, .\Effects\Temperature.dll, Version=4.6.7358.39746 Transparency, .\Effects\Transparency.dll, Version=4.6.7358.39871 TRsColorReducer, .\Effects\TRsColorReducer.dll, Version=1.0.2.0 TRsMorpher, .\Effects\TRsMorpher.dll, Version=1.1.2.15085 TRsCloudControl, .\Effects\TRsCloudControl.dll, Version=2.0.4968.34489 2dImageFilter, .\Effects\2dImageFilter-r25b.dll, Version=1.0.0.30 AA's_Assistant, .\Effects\AA's_Assistant.dll, Version=1.1.4329.33034 TRsBWPhoto, .\Effects\TRsBWPhoto.dll, Version=1.0.4949.38907 VignettePlus, .\Effects\VignettePlus.dll, Version=4.6.7358.40027 Aardvark, .\Effects\Aardvark.dll, Version=1.0.6.0 Add Depth, .\Effects\Add Depth.dll, Version=1.0.4247.30168 TRsBrushStrokes, .\Effects\TRsBrushStrokes.dll, Version=1.0.6.11937 Add-Remove Watermark, .\Effects\Add-Remove Watermark.dll, Version=1.0.3138.19150 AdvancedRotate, .\Effects\AdvancedRotate.dll, Version=1.0.3663.28009 advcolorrep, .\Effects\advcolorrep.dll, Version=1.3.3303.27314 TRsBokeh, .\Effects\TRsBokeh.dll, Version=2.0.5457.42261 AdvGrey, .\Effects\AdvGrey.dll, Version=0.0.0.0 Alias, .\Effects\Alias.dll, Version=2.0.3167.14578 AlignPlugin, .\Effects\AlignPlugin.dll, Version=1.5.1.0 TRsAlphaMapper, .\Effects\TRsAlphaMapper.dll, Version=1.0.1.0 Alpha Transform, .\Effects\Alpha Transform.dll, Version=1.1.3545.21589 Alpha-Displacement Mask, .\Effects\Alpha-Displacement Mask.dll, Version=1.4.1.1 AlphaContrast, .\Effects\AlphaContrast.dll, Version=1.0.3813.18307 TRsAlphaCutter, .\Effects\TRsAlphaCutter.dll, Version=3.0.4.0 AlphaMask, .\Effects\AlphaMask.dll, Version=2.0.3574.41943 AlphaMaskBrush, .\Effects\AlphaMaskBrush.dll, Version=1.5.0.0 AlphaSpace, .\Effects\AlphaSpace.dll, Version=1.0.0.0 TRs Scatter, .\Effects\TRs Scatter.dll, Version=1.3.4949.23250 AlphaThreshold, .\Effects\AlphaThreshold.dll, Version=1.0.1.0 AlphaToDots, .\Effects\AlphaToDots.dll, Version=1.0.4675.19955 AlphaTransform, .\Effects\AlphaTransform.dll, Version=1.2.0.0 Alpha_to_255, .\Effects\Alpha_to_255.dll, Version=1.0.4452.22782 Untitled, .\Effects\TriangularGradient.dll, Version=1.0.3733.28856 AnimationEffect, .\Effects\AnimationEffect.dll, Version=1.0.0.10 Alpha_to_0, .\Effects\Alpha_to_0.dll, Version=1.0.4452.22746 Apply Color, .\Effects\Apply Color.dll, Version=1.0.4406.25220 Apply Texture, .\Effects\Apply Texture.dll, Version=1.0.0.1 ArgusPDN.Barcode, .\Effects\ArgusPDN.Barcode.dll, Version=1.0.0.0 TreeGen, .\Effects\TreeGen.dll, Version=1.1.0.0 ArgusPDN.EdgeDetect, .\Effects\ArgusPDN.EdgeDetect.dll, Version=1.0.0.0 Antialias, .\Effects\Antialias_v1.5.8.0.dll, Version=0.0.0.0 ArgusPDN.Unblend, .\Effects\ArgusPDN.Unblend.dll, Version=1.0.0.0 Arrows, .\Effects\Arrows.dll, Version=1.0.0.0 ArtyThing, .\Effects\ArtyThing.dll, Version=1.0.5.0 Asmageddon_Alpha works, .\Effects\Asmageddon_Alpha works.dll, Version=0.0.0.0 TransparencyRGB, .\Effects\TransparencyRGB.dll, Version=1.0.1.0 Asmageddon_Channel_Shift, .\Effects\Asmageddon_Channel_Shift.dll, Version=0.0.0.0 ArgusPDN.FFTEffects, .\Effects\ArgusPDN.FFTEffects.dll, Version=1.0.0.0 Asmageddon_Channel_Works_Plus, .\Effects\Asmageddon_Channel_Works_Plus.dll, Version=0.0.0.0 Asmageddon_Color_Percentage_Plus, .\Effects\Asmageddon_Color_Percentage_Plus.dll, Version=0.0.0.0 Asmageddon_From P to S Grey, .\Effects\Asmageddon_From P to S Grey.dll, Version=0.0.0.0 Asmageddon_From P to S, .\Effects\Asmageddon_From P to S.dll, Version=0.0.0.0 Asmageddon_HSV inversion, .\Effects\Asmageddon_HSV inversion.dll, Version=0.0.0.0 Asmageddon_Channel multiplier, .\Effects\Asmageddon_Channel multiplier.dll, Version=0.0.0.0 Transitional Brush, .\Effects\Transitional Brush.dll, Version=1.0.0.0 Asmageddon_Hue Red Psychodelic, .\Effects\Asmageddon_Hue Red Psychodelic.dll, Version=0.0.0.0 Asmageddon_Image coder, .\Effects\Asmageddon_Image coder.dll, Version=0.0.0.0 Asmageddon_Inverto_pushing, .\Effects\Asmageddon_Inverto_pushing.dll, Version=0.0.0.0 Asmageddon_Inverto_pushing_Caleidoscope, .\Effects\Asmageddon_Inverto_pushing_Caleidoscope.dll, Version=0.0.0.0 Asmageddon_Inverto_pushing_plus, .\Effects\Asmageddon_Inverto_pushing_plus.dll, Version=0.0.0.0 Asmageddon_Multiplo uniqua, .\Effects\Asmageddon_Multiplo uniqua.dll, Version=0.0.0.0 Asmageddon_PS Mega, .\Effects\Asmageddon_PS Mega.dll, Version=0.0.0.0 Asmageddon_PS Only, .\Effects\Asmageddon_PS Only.dll, Version=0.0.0.0 Asmageddon_Hue Channeling multiply, .\Effects\Asmageddon_Hue Channeling multiply.dll, Version=0.0.0.0 trail3d, .\Effects\trail3d.dll, Version=1.0.3902.32071 Asmageddon_Quadro disorter B, .\Effects\Asmageddon_Quadro disorter B.dll, Version=0.0.0.0 Asmageddon_Quadro disorter, .\Effects\Asmageddon_Quadro disorter.dll, Version=0.0.0.0 Asmageddon_Render-Border, .\Effects\Asmageddon_Render-Border.dll, Version=0.0.0.0 Asmageddon_Render-Quadro bumperoo, .\Effects\Asmageddon_Render-Quadro bumperoo.dll, Version=0.0.0.0 Asmageddon_Render-Quadro inverto, .\Effects\Asmageddon_Render-Quadro inverto.dll, Version=0.0.0.0 Asmageddon_Render-Quadro sharper, .\Effects\Asmageddon_Render-Quadro sharper.dll, Version=0.0.0.0 Asmageddon_RGB tricks, .\Effects\Asmageddon_RGB tricks.dll, Version=0.0.0.0 Asmageddon_Pseudo water, .\Effects\Asmageddon_Pseudo water.dll, Version=0.0.0.0 Asmageddon_Strange_Bulger Kaleidoscope, .\Effects\Asmageddon_Strange_Bulger Kaleidoscope.dll, Version=0.0.0.0 AutoChrome, .\Effects\AutoChrome.dll, Version=1.2.0.0 Trail, .\Effects\Trail.dll, Version=4.0.4642.26791 AutoChromeNoise, .\Effects\AutoChromeNoise.dll, Version=1.0.3847.37353 AverageColorHSL, .\Effects\AverageColorHSL.dll, Version=1.0.3601.21265 AveragedColorBlur, .\Effects\AveragedColorBlur.dll, Version=1.1.1.0 AverageEdgeBlur, .\Effects\AverageEdgeBlur.dll, Version=1.0.3991.32409 AverageSelectionColor, .\Effects\AverageSelectionColor.dll, Version=1.1.3256.33886 Barcode, .\Effects\Barcode.dll, Version=1.5.0.0 Bars, .\Effects\Bars.dll, Version=1.1.0.0 BasicAntialias11, .\Effects\BasicAntialias.dll, Version=0.0.0.0 BasicPhotoAdjustments, .\Effects\BasicPhotoAdjustments.dll, Version=2.0.3854.18994 Untitled, .\Effects\Asmageddon_Strange Bulger.dll, Version=1.0.3326.10720 BevelObject, .\Effects\BevelObject.dll, Version=1.0.1.0 TR'sColorizerHMS, .\Effects\TR'sColorizerHMS.dll, Version=1.0.4937.30626 Bevel, .\Effects\Bevel_v1.4.0.0.dll, Version=0.0.0.0 Bezncurve, .\Effects\Bezncurve.dll, Version=1.0.0.0 Bizarro-Negation, .\Effects\Bizarro-Negation.dll, Version=1.0.4617.21771 BlackAndWhiteConverter, .\Effects\Black and White Converter.dll, Version=1.1.3472.36275 BlackandAlpha+, .\Effects\BlackandAlpha+.dll, Version=1.2.4329.272 BlackAndWhite, .\Effects\BlackAndWhite.dll, Version=1.2.3526.15024 BlurFill, .\Effects\BlurFill.dll, Version=1.5.1.0 Border, .\Effects\Border.dll, Version=0.0.0.0 Borders N' Shapes, .\Effects\Borders N' Shapes.dll, Version=4.0.4642.26476 Boutons, .\Effects\Boutons.dll, Version=1.1.0.0 BBOutlinedGradientText, .\Effects\BBOutlinedGradientText.dll, Version=4.6.7358.38713 BulletinBoardTrim, .\Effects\BulletinBoardTrim.dll, Version=1.0.0.0 TR's Pixel Push, .\Effects\TR's Pixel Push.dll, Version=1.0.4954.37564 BumpChecker, .\Effects\BumpChecker.dll, Version=1.4.4399.25606 Calendar, .\Effects\Calendar.dll, Version=4.6.7358.32649 CalliColour, .\Effects\CalliColour.dll, Version=1.0.1.0 CameraTrouserFlareV3, .\Effects\CameraTrouserFlareV3.dll, Version=1.1.4600.41268 Cartoonize, .\Effects\Cartoonize.dll, Version=1.0.4629.37393 CellMaker, .\Effects\CellMaker.dll, Version=0.0.0.0 CellTexture, .\Effects\CellTexture.dll, Version=1.1.0.0 CenterLines, .\Effects\CenterLines.dll, Version=1.1.1.0 Channel Swap, .\Effects\Channel Swap.dll, Version=1.0.4602.41418 ChannelMixer, .\Effects\ChannelMixer.dll, Version=1.0.3493.40525 Bullet, .\Effects\Bullet.dll, Version=1.0.0.0 ChartWhiteBalance, .\Effects\ChartWhiteBalance.dll, Version=1.0.0.0 Checkboard, .\Effects\Checkboard.dll, Version=1.0.0.0 Toon, .\Effects\Toon.dll, Version=0.0.0.0 ChessFEN, .\Effects\ChessFEN.dll, Version=1.0.3116.32335 ChromaKeyPlugin, .\Effects\ChromaKeyPlugin.dll, Version=1.0.0.2 CircleText, .\Effects\CircleText.dll, Version=1.4.4415.32488 ClampedGaussianBlur, .\Effects\ClampedGaussianBlur.dll, Version=2.1.0.0 Clarifaction+, .\Effects\Clarifaction+.dll, Version=1.0.4406.25898 Clarify, .\Effects\Clarify.dll, Version=1.0.4349.19613 CleanTransparent, .\Effects\CleanTransparent.dll, Version=1.0.0.0 ClipWarpNew, .\Effects\ClipWarpNew.dll, Version=1.0.1.0 CloudEffect, .\Effects\CloudEffect.dll, Version=1.1.0.0 CMY Ghost, .\Effects\CMY Ghost.dll, Version=1.0.4909.35063 Channels, .\Effects\Channels.dll, Version=2.0.0.0 CodeLab, .\Effects\CodeLab.dll, Version=1.8.4305.21282 Microsoft.VisualBasic, .\Microsoft.VisualBasic.dll, Version=10.1.0.0, PublicKeyToken=b03f5f7f11d50a3a dfgj, .\Effects\Color Balance Mix.dll, Version=2.5.3502.26787 Color Clearer 1, .\Effects\Color Clearer 1.1.dll, Version=1.1.6010.17371 Color Dimmer, .\Effects\Color Dimmer.dll, Version=1.0.4658.40889 Color Match, .\Effects\Color Match.dll, Version=4.0.4642.26532 coloraberation, .\Effects\coloraberation.dll, Version=1.0.3859.18981 ColorCount, .\Effects\ColorCount.dll, Version=1.0.0.0 ColorExchange, .\Effects\ColorExchange.dll, Version=1.1.5002.19815 ColorHarmonies.Effect, .\Effects\ColorHarmonies.Effect.dll, Version=0.7.0.155 OptionBasedLibrary v0.7.3, .\Effects\OptionBasedLibrary v0.7.3.dll, Version=0.7.0.229 Cobweb, .\Effects\Cobweb.dll, Version=1.0.1.0 ColorMixer, .\Effects\ColorMixer.dll, Version=1.3.0.0 Microsoft.VisualBasic.Forms, .\Microsoft.VisualBasic.Forms.dll, Version=6.0.1.0, PublicKeyToken=b03f5f7f11d50a3a ColorModulo, .\Effects\ColorModulo.dll, Version=0.0.0.0 ColorRamp, .\Effects\ColorRamp.dll, Version=1.0.0.0 ColorRange, .\Effects\ColorRange.dll, Version=1.2.1.0 ColorRange_en, .\Effects\ColorRange_en.dll, Version=1.0.0.0 ColorSketch, .\Effects\ColorSketch.dll, Version=1.1.1.0 ColorSketch_en, .\Effects\ColorSketch_en.dll, Version=1.0.0.0 ColorStretchV10, .\Effects\ColorStretchV10.dll, Version=1.0.3116.21703 ColorTargetV13, .\Effects\ColorTarget.dll, Version=1.3.3116.21867 ColorMatrix.Effect, .\Effects\ColorMatrix.Effect.dll, Version=1.1.0.22 OptionBasedLibrary v0.7.9, .\Effects\OptionBasedLibrary v0.7.9.dll, Version=0.7.9.1561 TJacksonEffects, .\Effects\TJacksonEffects.dll, Version=1.0.0.0 ColorTrimming, .\Effects\ColorTrimming.dll, Version=1.0.3167.14623 ColorZoomBlur, .\Effects\ColorZoomBlur.dll, Version=1.1.3873.36417 Colour Distort2, .\Effects\Colour Distort.dll, Version=1.0.3564.18753 colourblindsim, .\Effects\colourblindsim.dll, Version=1.0.3891.486 colourchop3, .\Effects\colourchop3.dll, Version=1.3.3877.4590 coltoalphaadv, .\Effects\coltoalphaadv.dll, Version=1.0.3100.18431 Compotool, .\Effects\Compotool.dll, Version=1.0.1.0 ConditionalEffects, .\Effects\ConditionalEffects.dll, Version=1.3.3919.30824 ConditionalPen, .\Effects\ConditionalPen.dll, Version=1.1.0.0 Contour, .\Effects\Contour.dll, Version=1.0.1.0 mycontour42, .\Effects\contour42.dll, Version=1.0.4013.31152 CoordinatePlanePoints, .\Effects\CoordinatePlanePoints.dll, Version=1.1.6846.29158 CopyAlpha, .\Effects\CopyAlpha.dll, Version=1.0.0.0 CreateImageMap, .\Effects\CreateImageMap.dll, Version=1.0.0.0 CreatePattern, .\Effects\CreatePattern.dll, Version=1.0.0.0 ColorToAlpha, .\Effects\ColorToAlpha.dll, Version=2.3.0.0 CreativeTextPro, .\Effects\CreativeTextPro.dll, Version=1.1.7358.34307 Tint-Splitter, .\Effects\Tint-Splitter.dll, Version=1.0.4636.5475 LightningCurve, .\Effects\CurlyLines.dll, Version=1.0.0.0 CycleHSV, .\Effects\CycleHSV.dll, Version=1.0.4909.35068 DHShapeMaker, .\Effects\DHShapeMaker.dll, Version=1.0.5.40717 Diagonal Lines, .\Effects\Diagonal Lines.dll, Version=2.5.3543.22117 Diffuse, .\Effects\Diffuse.dll, Version=1.0.3254.27766 Dimensions, .\Effects\Dimensions.dll, Version=1.3.6826.38472 DirectionalBlur, .\Effects\DirectionalBlur.dll, Version=0.0.0.0 Displacement, .\Effects\Displacement.dll, Version=1.1.0.0 DispMap, .\Effects\DispMap.dll, Version=2.0.4919.36181 Dissolve, .\Effects\Dissolve.dll, Version=1.0.0.0 DistortingMirror, .\Effects\DistortingMirror.dll, Version=1.0.4281.30602 DistortThis, .\Effects\DistortThis.dll, Version=2.9.0.0 Donut, .\Effects\Donut.dll, Version=1.0.4354.32246 Dot, .\Effects\Dot.dll, Version=1.0.4673.202 DotAtCenter2, .\Effects\DotAtCenter2.1.dll, Version=0.0.0.0 dpyColorBalance, .\Effects\dpyColorBalance.dll, Version=1.1.4330.37850 DraganEffect, .\Effects\DraganEffect.dll, Version=1.1.1.0 Tiles, .\Effects\Tiles.dll, Version=1.1.1.0 DragFrom, .\Effects\DragFrom.dll, Version=1.1.0.0 Droste, .\Effects\Droste.dll, Version=1.0.0.0 DrPrepper, .\Effects\DrPrepper.dll, Version=1.4.4399.25637 Dryad, .\Effects\Dryad.dll, Version=1.0.1.0 Dull, .\Effects\Dull.dll, Version=1.0.3314.38674 DynamicContrast, .\Effects\DynamicContrast.dll, Version=1.1.1.0 EarthsAndGreys, .\Effects\EarthsAndGreys.dll, Version=1.0.1.0 EasyWatermark1, .\Effects\EasyWatermark1.dll, Version=1.0.0.0 EdgeFader, .\Effects\EdgeFader.dll, Version=5.3.5.0 edgemaster, .\Effects\edgemaster.dll, Version=1.0.3880.5859 EdHarvey.FastFx, .\Effects\EdHarvey.FastFx.dll, Version=0.1.3426.11348 Egalize, .\Effects\Egalize.dll, Version=1.0.0.0 EigenBlur, .\Effects\EigenBlur.dll, Version=1.3.3555.24648 EliminateBlack, .\Effects\EliminateBlack.dll, Version=1.0.5618.24761 EliminateDarkLight, .\Effects\EliminateDarkLight.dll, Version=1.1.1.0 EliminateWhite, .\Effects\EliminateWhite.dll, Version=1.0.5618.24771 Emboss+, .\Effects\Emboss+.dll, Version=1.2.1.0 Threshold, .\Effects\Threshold.dll, Version=1.0.0.0 EngraveEmboss, .\Effects\EngraveEmboss.dll, Version=2.0.2.0 EnhanceDetails, .\Effects\EnhanceDetails.dll, Version=1.0.3581.22689 EOEffects, .\Effects\EOEffects.dll, Version=1.8.1.12 Erode, .\Effects\Erode.dll, Version=1.0.0.0 ErodeDilate, .\Effects\ErodeDilate_v0.2.dll, Version=1.0.0.0 ExtendBorder, .\Effects\ExtendBorder.dll, Version=1.3.0.0 ExtractColor, .\Effects\ExtractColor.dll, Version=1.0.0.0 Eyeshine, .\Effects\Eyeshine.dll, Version=1.0.3700.25905 Facet, .\Effects\Facet.dll, Version=1.0.3.0 FibonacciFill, .\Effects\FibonacciFill.dll, Version=1.1.6139.28851 Film, .\Effects\Film.dll, Version=4.0.4642.26607 FilmNoir, .\Effects\FilmNoir.dll, Version=1.0.0.0 FindEdges, .\Effects\FindEdges.dll, Version=1.2.0.0 Fire, .\Effects\Fire.dll, Version=1.0.0.0 Fisheye, .\Effects\Fisheye.dll, Version=2.2.5533.12794 Flip, .\Effects\Flip.dll, Version=4.6.7358.36953 FloydSteinbergEffect, .\Effects\FloydSteinbergEffect.dll, Version=1.0.0.0 ThreadsMarker, .\Effects\ThreadsMarker.dll, Version=0.0.0.0 IniFile, .\Effects\IniFile.dll, Version=2.0.2.0 MyScript, .\Effects\FlySwatter.dll, Version=0.0.0.0 Fractal, .\Effects\Fractal.dll, Version=1.0.0.0 Frames, .\Effects\Frame.dll, Version=1.1.0.0 FSPost, .\Effects\FSPost.dll, Version=1.0.4913.8979 FurBlur, .\Effects\FurBlur.dll, Version=1.0.1.0 FuzzyEdgeDetect, .\Effects\FuzzyEdgeDetect.dll, Version=1.0.5885.38970 GaussianBlurPlus, .\Effects\GaussianBlurPlus.dll, Version=4.2.5691.27401 Gears, .\Effects\Gears.dll, Version=1.0.2.0 GenTree, .\Effects\GenTree.dll, Version=0.1.0.0 Gingham, .\Effects\Gingham.dll, Version=1.1.0.0 Gossamer, .\Effects\Gossamer.dll, Version=1.0.1.0 Gradient Bars, .\Effects\Gradient Bars.dll, Version=4.0.5152.23084 Gradient Blocks, .\Effects\Gradient Blocks.dll, Version=4.0.4642.26658 GradientBlur, .\Effects\Gradient Blur.dll, Version=1.0.0.0 Gradient Mapping, .\Effects\Gradient Mapping.dll, Version=4.0.4642.26687 GradientsGalore, .\Effects\GradientsGalore.dll, Version=1.0.5.0 ThermalHeatMapEffect, .\Effects\ThermalHeatMapEffect.dll, Version=1.0.0.0 Grain, .\Effects\Grain.dll, Version=1.0.3854.25523 Gralpha, .\Effects\Gralpha.dll, Version=1.0.3684.31203 GraphPaper, .\Effects\GraphPaper.dll, Version=2.1.0.0 OptionBasedLibrary v0.7.9, .\Effects\OptionBasedLibrary v0.7.9.dll, Version=0.7.9.1561 Gravity, .\Effects\Gravity.dll, Version=1.1.0.0 GreenTintReduction, .\Effects\GreenTintReduction.dll, Version=1.0.6484.29238 Grid Warp, .\Effects\Grid Warp.dll, Version=4.0.5149.26776 GridCheckerboard, .\Effects\GridCheckerboard.dll, Version=4.5.6828.36789 GridMaker, .\Effects\GridMaker.dll, Version=4.0.0.0 GrimColorReaper, .\Effects\GrimColorReaper.dll, Version=1.2.4299.5808 HaarTransform, .\Effects\HaarTransform.dll, Version=1.1.4083.41831 Heightmap plugin v1, .\Effects\Heightmap.dll, Version=1.3.4172.23550 Helix, .\Effects\Helix.dll, Version=1.0.1.0 HexaGrid, .\Effects\HexaGrid.dll, Version=1.2.0.0 Highlight, .\Effects\Highlight.dll, Version=1.0.1.0 HighPass, .\Effects\HighPass.dll, Version=1.2.3903.27501 HotMetalGlow 1, .\Effects\HotMetalGlow.dll, Version=1.2.5986.8090 ThatOtherApp, .\Effects\ThatOtherApp.dll, Version=2.2.0.0 SBCommon, .\Effects\SBCommon.dll, Version=3.0.0.0 Hue_Saturation+, .\Effects\Hue_Saturation+.dll, Version=1.0.3277.32208 Illuminate, .\Effects\Illuminate.dll, Version=0.0.0.0 IncreaseLocalContrast, .\Effects\IncreaseLocalContrast.dll, Version=1.2.0.0 InkSketch+, .\Effects\InkSketch+.dll, Version=1.0.4629.39900 InputToOutput+, .\Effects\InputToOutput+.dll, Version=1.0.4548.20355 InsetBoxShadow, .\Effects\InsetBoxShadow.dll, Version=1.2.0.0 IntenColor, .\Effects\IntenColor.dll, Version=1.0.0.0 IntensityRGB, .\Effects\IntensityRGB.dll, Version=1.0.1.0 Interlace, .\Effects\Interlace.dll, Version=1.0.0.5 invert channels, .\Effects\invert channels.dll, Version=1.0.3509.14656 InvertAlpha, .\Effects\InvertAlpha.dll, Version=1.0.3040.33378 invert_around_primcol, .\Effects\invert_around_primcol.dll, Version=1.1.3402.30348 iPhoneTabbarIconMaker, .\Effects\iPhoneTabbarIconMaker.dll, Version=1.0.3659.22550 isolate, .\Effects\isolate.dll, Version=1.0.3303.3202 IsolateChannel, .\Effects\IsolateChannel.dll, Version=1.0.0.0 IsometricCuboid, .\Effects\IsometricCuboid.dll, Version=1.6.0.0 IsolateWhiteBlack, .\Effects\IsolateWhiteBlack.dll, Version=1.3.3676.24989 TextWindow, .\Effects\TextWindow.dll, Version=1.4.0.0 PDNPI_IndirectUI, .\Effects\jchunn.dll, Version=1.0.0.0 JigsawPuzzle, .\Effects\JigsawPuzzle.dll, Version=2.3.0.0 Jitter, .\Effects\Jitter.dll, Version=4.0.4642.26986 Texturize, .\Effects\Texturize.dll, Version=1.0.0.0 JPEGEffect, .\Effects\JPEGEffect.dll, Version=1.0.0.0 KaleidoGen, .\Effects\KaleidoGen.dll, Version=1.2.0.0 Kaleidoscope, .\Effects\Kaleidoscope.dll, Version=1.3.0.0 TextPlus, .\Effects\Textplus.dll, Version=1.0.0.0 Kill Color Keeper, .\Effects\Kill Color Keeper.dll, Version=1.0.6641.13453 KillColor, .\Effects\KillColor.dll, Version=1.0.3498.8108 KlumpNoiz, .\Effects\KlumpNoiz.dll, Version=1.1.0.0 Tattersall, .\Effects\Tattersall.dll, Version=1.1.0.0 Kuwahara, .\Effects\Kuwahara.dll, Version=1.0.0.0 LaplacianPyramidFilter, .\Effects\LaplacianPyramidFilter.dll, Version=1.0.0.1 LavEnt.Effects.Mosaic, .\Effects\LavEnt.Effects.Mosaic.dll, Version=1.1.0.0 Tartan, .\Effects\Tartan.dll, Version=1.5.1.0 LavEnt.Effects.RoundedRectangle, .\Effects\LavEnt.Effects.RoundedRectangle.dll, Version=1.3.0.0 LensFlare, .\Effects\LensFlare.dll, Version=1.1.0.0 LensFlareV4, .\Effects\LensFlareV4.dll, Version=1.0.4598.31112 SubtractColor, .\Effects\SubtractColor.dll, Version=1.0.4679.26877 Lightning, .\Effects\Lightning.dll, Version=1.1.3896.32593 LightRays, .\Effects\LightRays.dll, Version=1.3.0.0 Line Tracer, .\Effects\Line Tracer.dll, Version=1.0.4911.29141 SubLCD, .\Effects\SubLCD.dll, Version=1.2.1.0 LinesGrid, .\Effects\LinesGrid.dll, Version=1.2.1.0 LinesGrid, .\Effects\LinesGrid_en.dll, Version=1.1.0.0 Linocut, .\Effects\Linocut.dll, Version=1.1.1.0 StringAndPin, .\Effects\StringAndPin.dll, Version=1.0.1.0 Linocut_en, .\Effects\Linocut_en.dll, Version=1.0.0.0 LocalContrast, .\Effects\LocalContrast.dll, Version=1.2.0.0 LocalNoise, .\Effects\LocalNoise.dll, Version=1.0.4674.29909 Liquify, .\Effects\Liquify.dll, Version=4.0.5873.25113 Magnifier, .\Effects\Magnifier.dll, Version=1.1.0.0 Majority, .\Effects\Majority.dll, Version=1.1.0.0 MakeTransparent, .\Effects\MakeTransparent.dll, Version=1.0.0.0 Manual Color Correction, .\Effects\ManualColorCorrection.dll, Version=1.0.4314.41440 Matrice, .\Effects\Matrice.dll, Version=1.0.3810.11744 MemeMaker, .\Effects\MemeMaker.dll, Version=4.5.6828.38061 Metallize, .\Effects\Metallize.dll, Version=1.2.4415.32969 Mexican Hat Edge Detect, .\Effects\Mexican Hat Edge Detect.dll, Version=1.0.0.0 MirrorRotate, .\Effects\MirrorRotate.dll, Version=2.0.2.0 IniFile, .\Effects\IniFile.dll, Version=2.0.2.0 MirrorRotateMenu, .\Effects\MirrorRotateMenu.dll, Version=2.0.2.0 IniFile, .\Effects\IniFile.dll, Version=2.0.2.0 Moire, .\Effects\Moire.dll, Version=1.1.0.0 Morphologic, .\Effects\Morphologic.dll, Version=1.0.0.0 MosaicManiac, .\Effects\MosaicManiac.dll, Version=1.0.906.8 MoveSeams, .\Effects\MoveSeams.dll, Version=1.0.0.0 Checker, .\Effects\Stretch.dll, Version=0.0.0.0 MultiColorGradient, .\Effects\MultiColorGradient.dll, Version=1.0.0.0 MultiSpline, .\Effects\MultiSpline.dll, Version=1.0.4.0 MultiThreshold, .\Effects\MultiThreshold.dll, Version=1.1.4330.38982 Nebulous, .\Effects\Nebulous.dll, Version=0.0.0.0 NeonEdges, .\Effects\NeonEdges.dll, Version=1.2.1.0 NeonEdges_en, .\Effects\NeonEdges_en.dll, Version=1.0.0.0 NewtonFractal, .\Effects\NewtonFractal.dll, Version=0.0.0.0 NoiseBleach, .\Effects\NoiseBleach.dll, Version=1.0.4909.35542 NoiseChoice, .\Effects\NoiseChoice.dll, Version=1.0.1.0 Normalize, .\Effects\Normalize.dll, Version=1.0.0.0 Normalizer, .\Effects\Normalizer.dll, Version=1.8.4399.25698 Norm_Render, .\Effects\Norm_Render.dll, Version=7.3.4484.27012 Object2Colour, .\Effects\Object2Colour.dll, Version=1.0.1.0 ObjectEdge, .\Effects\Objectedge.dll, Version=1.0.1.0 ObjectFeather, .\Effects\ObjectFeather.dll, Version=3.5.4315.35085 Oblique, .\Effects\Oblique.dll, Version=1.0.0.0 Offset Alternating Stripes, .\Effects\Offset Alternating Stripes.dll, Version=1.0.6027.1223 Offset Shadow, .\Effects\Offset Shadow.dll, Version=1.0.4247.30184 StrayPixelRemover, .\Effects\StrayPixelRemover.dll, Version=1.0.0.0 Offset, .\Effects\Offset.dll, Version=1.0.4914.19410 OilPaintingPlus, .\Effects\OilPaintingPlus.dll, Version=4.6.7358.38406 Olden, .\Effects\Olden.dll, Version=1.5.0.0 Feather, .\Effects\OldFeather.dll, Version=2.3.4315.37038 OrbGenerator, .\Effects\OrbGenerator.dll, Version=0.0.0.0 OtherFarmColorReplacer, .\Effects\OtherFarmColorReplacer.dll, Version=1.1.3263.11631 Outline Object, .\Effects\Outline Object.dll, Version=4.0.4642.26954 Outline, .\Effects\Outline.dll, Version=1.0.0.0 OutlineSelection, .\Effects\OutlineSelection.dll, Version=1.0.3055.21360 Overblur, .\Effects\Overblur.dll, Version=1.0.1.0 Overliner, .\Effects\Overliner.dll, Version=1.2.3888.29226 PageCurl, .\Effects\PageCurl.dll, Version=1.3.0.0 Panelling, .\Effects\Panelling.dll, Version=1.1.0.0 ParallelLines.Effect, .\Effects\ParallelLines.Effect.dll, Version=1.6.0.575 OptionBasedLibrary v0.7.9, .\Effects\OptionBasedLibrary v0.7.9.dll, Version=0.7.9.1561 PasteFill, .\Effects\PasteFill.dll, Version=2.0.0.0 PdnFF, .\Effects\PdnFF.dll, Version=1.0.3.7 PDNSpriteSheetAnim, .\Effects\PDNSpriteSheetAnim.dll, Version=1.0.0.3 PerlinTexture, .\Effects\PerlinTexture.dll, Version=1.1.3857.30918 Stitch, .\Effects\Stitch.dll, Version=4.0.4642.26808 Perspective, .\Effects\Perspective.dll, Version=2.1.4415.36116 PerspectiveLines, .\Effects\PerspectiveLines.dll, Version=1.0.3676.3747 phips_fill_gaps, .\Effects\phips_fill_gaps.dll, Version=1.0.3307.18956 phips_kill_color, .\Effects\phips_kill_color.dll, Version=1.1.0.0 phips_selective_enhancer, .\Effects\phips_selective_enhancer.dll, Version=1.1.3302.33189 phips_selective_toning, .\Effects\phips_selective_toning.dll, Version=1.0.3304.32827 myPhsycocolour2, .\Effects\Phsycocolour2.dll, Version=1.0.4034.2456 PieChart, .\Effects\PieChart.dll, Version=2.5.0.0 Pixelate+, .\Effects\Pixelate+.dll, Version=4.0.4642.26940 PixelatedFrame, .\Effects\PixelatedFrame.dll, Version=1.0.0.0 PixelLab, .\Effects\PixelLab.dll, Version=1.0.0.0 Planetoid, .\Effects\Planetoid.dll, Version=1.0.0.0 PlugInData, .\Effects\PlugInData.dll, Version=1.4.0.0 PNG Preprocessor, .\Effects\PNG_Preprocessor.dll, Version=1.0.3876.32360 PointBlur, .\Effects\PointBlur.dll, Version=1.0.0.0 Polar, .\Effects\Polar.dll, Version=1.1.1.0 PolariodFrame, .\Effects\PolariodFrame.dll, Version=1.0.3171.27990 PolarRect, .\Effects\PolarRect.dll, Version=0.0.0.0 StewienFilters, .\Effects\StewienFilters.dll, Version=1.2.0.0 PolyGlitch.Effects, .\Effects\PolyGlitch.Effects.dll, Version=1.4.0.0 Polygon Tool, .\Effects\Polygon Tool.dll, Version=1.0.0.0 Polygones, .\Effects\Polygones.dll, Version=1.1.0.0 PostageStamp, .\Effects\PostageStamp.dll, Version=1.1.0.0 posterize+, .\Effects\posterize+.dll, Version=1.0.4629.2600 PosterizeHSV, .\Effects\PosterizeHSV.dll, Version=1.0.3258.3285 PowerStretch20Beta, .\Effects\PowerStretch.dll, Version=1.9.3045.14671 PrimColOnly, .\Effects\PrimColOnly.dll, Version=0.0.0.0 PrinterPlus, .\Effects\PrinterPlus.dll, Version=1.5.0.0 PSEmboss, .\Effects\PSEmboss.dll, Version=1.0.0.0 Psychocolour, .\Effects\Psychocolour.dll, Version=1.0.1.0 pxEexpansion, .\Effects\pxEexpansion.dll, Version=1.0.4437.36287 System.Resources.Extensions, .\System.Resources.Extensions.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 QuadrilateralCorrection, .\Effects\QuadrilateralCorrection.dll, Version=1.2.0.0 Quick Gravity, .\Effects\Quick Gravity.dll, Version=1.0.4408.25818 Radialcolors, .\Effects\Radialcolors.dll, Version=1.1.0.0 RadiusFillCorners, .\Effects\RadiusFillCorners.dll, Version=1.6.0.0 rainball, .\Effects\rainball.dll, Version=1.0.4907.41850 rainbow loom, .\Effects\rainbow loom.dll, Version=3.0.3530.27322 Rainbow-Splitter, .\Effects\Rainbow-Splitter.dll, Version=1.0.4639.2372 rainbow3, .\Effects\rainbow3.dll, Version=0.0.0.0 RainbowTwist, .\Effects\RainbowTwist.dll, Version=1.1.0.0 RandDots, .\Effects\Random Dots.dll, Version=1.1.0.0 Random Effect, .\Effects\Random Effect.dll, Version=4.0.4642.26928 RandLines, .\Effects\Random lines.dll, Version=1.1.0.0 RandMaze1, .\Effects\Random Maze1.dll, Version=1.1.0.0 RandMaze2, .\Effects\Random Maze2.dll, Version=1.1.0.0 Random Shape Fill, .\Effects\Random Shape Fill.dll, Version=4.0.4642.26910 RecolourChoice, .\Effects\RecolourChoice.dll, Version=1.0.1.0 Recover Watermark, .\Effects\Recover Watermark.dll, Version=1.0.3138.19404 RedEyeQuickFix, .\Effects\RedEyeQuickFix.dll, Version=1.1.3161.39688 RefocusingSDe, .\Effects\RefocusingSDe.dll, Version=1.0.3760.21016 RemoveBrightDark, .\Effects\RemoveBrightDark.dll, Version=1.1.3063.36415 RemoveTransparency, .\Effects\RemoveTransparency.dll, Version=1.0.0.0 RenderColorWheel, .\Effects\RenderColorWheel.dll, Version=1.1.3258.28607 Reticulation, .\Effects\Reticulation.dll, Version=1.4.1.0 ReverseColors, .\Effects\ReverseColors.dll, Version=1.0.4121.15722 ReverseFisheye, .\Effects\ReverseFisheye35.dll, Version=1.0.5146.25956 RGB2CMYK, .\Effects\RGB2CMYK.dll, Version=0.0.0.0 RGB_Remap4, .\Effects\RGB_Remap4.dll, Version=1.0.3538.24311 Rosaces, .\Effects\Rosaces.dll, Version=1.1.0.0 System.Reflection.Emit.ILGeneration, .\System.Reflection.Emit.ILGeneration.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a RotateText, .\Effects\RotateText.dll, Version=1.1.4415.32628 RotateTextSUI, .\Effects\RotateTextSUI.dll, Version=1.1.4415.32713 Rotate_Zoom+, .\Effects\Rotate_Zoom+.dll, Version=1.11.5237.17779 RotationBilinear, .\Effects\RotationBilinear.dll, Version=1.1.3594.29946 RubberStamp, .\Effects\RubberStamp.dll, Version=1.0.0.0 Ruler, .\Effects\Ruler.dll, Version=1.0.6846.37263 SaturationRGB, .\Effects\SaturationRGB.dll, Version=1.2.1.0 SaturationRGB_en, .\Effects\SaturationRGB_en.dll, Version=1.0.5395.16586 SaveForWebRIOT, .\Effects\SaveForWebRIOT.dll, Version=1.0.7.0 Scintillate, .\Effects\Scintillate.dll, Version=1.0.1.0 System.Reflection.Emit, .\System.Reflection.Emit.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Microsoft.GeneratedCode, «empty», Version=1.0.0.0 ScratchArt, .\Effects\ScratchArt.dll, Version=1.2.1.0 ScreenPixel, .\Effects\ScreenPixel.dll, Version=1.1.6846.39497 SeamlessHelper, .\Effects\SeamlessHelper.dll, Version=0.0.0.0 SeamlessMove, .\Effects\SeamlessMove.dll, Version=1.0.4690.40795 SeamlessTextureMaker, .\Effects\SeamlessTextureMaker.dll, Version=1.0.0.0 SegmentImage, .\Effects\SegmentImage.dll, Version=1.1.3674.15788 Selection2Clear, .\Effects\Selection2Clear.dll, Version=1.0.1.0 SelectionObscure, .\Effects\SelectionObscure.dll, Version=1.1.4602.34476 Self-Negation, .\Effects\Self-Negation.dll, Version=1.1.4591.7662 ShadowHighlight, .\Effects\ShadowHighlight.dll, Version=2.2.0.0 Shapes, .\Effects\Shapes.dll, Version=1.4.0.0 Shape_umabob, .\Effects\Shape_umabob.dll, Version=3.4.0.0 Sharpen+, .\Effects\Sharpen+.dll, Version=3.1.0.0 EffectsPluginTemplate2, .\Effects\Shatters_0.55beta.dll, Version=1.0.0.0 System.Reflection.Primitives, .\System.Reflection.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a silhouetteplus, .\Effects\silhouetteplus.dll, Version=1.1.3131.17586 SimulateColorDepth, .\Effects\SimulateColorDepth.dll, Version=1.0.4211.27729 SinWaves, .\Effects\SinWaves.dll, Version=1.1.0.0 SmartSharpen, .\Effects\SmartSharpen.dll, Version=1.0.1.1 Smooth, .\Effects\Smooth.dll, Version=2.0.2.0 IniFile, .\Effects\IniFile.dll, Version=2.0.2.0 Smudge, .\Effects\Smudge.dll, Version=4.0.4642.26844 Sound wave, .\Effects\Sound wave.dll, Version=2.1.3542.36435 Sparkles, .\Effects\Sparkles.dll, Version=1.1.0.0 Specular, .\Effects\Specular.dll, Version=1.0.3254.27778 SpeechBubble, .\Effects\SpeechBubble.dll, Version=2.1.4445.42029 SpiralText, .\Effects\SpiralText.dll, Version=1.4.4415.32775 Spiral, .\Effects\Spiral.dll, Version=1.1.0.0 SpiritLevel.Effect, .\Effects\SpiritLevel.Effect.dll, Version=1.0.0.40 SpiroGraph, .\Effects\SpiroGraph.dll, Version=1.1.0.0 SpiroShapes, .\Effects\SpiroShapes.dll, Version=1.4.0.0 Splashes, .\Effects\Splashes.dll, Version=1.1.1.0 Stencil2Eye, .\Effects\Stencil2Eye.dll, Version=1.0.5009.601 Splatter, .\Effects\Splatter.dll, Version=4.0.4642.26829 SpokedWheel, .\Effects\SpokedWheel.dll, Version=1.1.6846.37336 Sponge, .\Effects\Sponge.dll, Version=1.3.1.0 Sponge_en, .\Effects\Sponge_en.dll, Version=1.0.0.0 Squirkle, .\Effects\Squirkle.dll, Version=1.0.1.0 SquirkleWarp, .\Effects\SquirkleWarp.dll, Version=1.0.1.0 SR, .\Effects\SR.dll, Version=1.0.3371.38258 StarGlow, .\Effects\StarGlow.dll, Version=1.0.3839.21249 Starry, .\Effects\Starry.dll, Version=0.0.0.0 Stars, .\Effects\Stars.dll, Version=1.0.0.0 System.IO.FileSystem, .\System.IO.FileSystem.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Text.Json, .\System.Text.Json.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Reflection.Emit.Lightweight, .\System.Reflection.Emit.Lightweight.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Text.Encodings.Web, .\System.Text.Encodings.Web.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 EdHarvey.FastFx, .\Effects\EdHarvey.FastFx.dll, Version=0.1.3426.11348 System.IO.Compression, .\System.IO.Compression.dll, Version=6.0.0.0, PublicKeyToken=b77a5c561934e089 Native modules: .\paintdotnet.exe, version=4.307.8039.30451 C:\WINDOWS\SYSTEM32\ntdll.dll, version=10.0.19041.1023 (WinBuild.160101.0800) C:\WINDOWS\System32\KERNEL32.DLL, version=10.0.19041.1348 (WinBuild.160101.0800) C:\WINDOWS\System32\KERNELBASE.dll, version=10.0.19041.1348 (WinBuild.160101.0800) C:\WINDOWS\System32\USER32.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\System32\win32u.dll, version=10.0.19041.1387 (WinBuild.160101.0800) C:\WINDOWS\System32\GDI32.dll, version=10.0.19041.1202 (WinBuild.160101.0800) C:\WINDOWS\System32\gdi32full.dll, version=10.0.19041.1387 (WinBuild.160101.0800) C:\WINDOWS\System32\msvcp_win.dll, version=10.0.19041.789 (WinBuild.160101.0800) C:\WINDOWS\System32\ucrtbase.dll, version=10.0.19041.789 (WinBuild.160101.0800) C:\WINDOWS\System32\SHELL32.dll, version=10.0.19041.964 (WinBuild.160101.0800) C:\WINDOWS\System32\ADVAPI32.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\System32\msvcrt.dll, version=7.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\System32\sechost.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\System32\RPCRT4.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\System32\IMM32.DLL, version=10.0.19041.546 (WinBuild.160101.0800) .\hostfxr.dll, version=6,0,121,56705 @Commit: 3a25a7f1cc446b60678ed25c9d829420d6321eba .\hostpolicy.dll, version=6,0,121,56705 @Commit: 3a25a7f1cc446b60678ed25c9d829420d6321eba .\coreclr.dll, version=6,0,121,56705 @Commit: 3a25a7f1cc446b60678ed25c9d829420d6321eba C:\WINDOWS\System32\ole32.dll, version=10.0.19041.1320 (WinBuild.160101.0800) C:\WINDOWS\System32\combase.dll, version=10.0.19041.1320 (WinBuild.160101.0800) C:\WINDOWS\System32\OLEAUT32.dll, version=10.0.19041.985 (WinBuild.160101.0800) C:\WINDOWS\System32\bcryptPrimitives.dll, version=10.0.19041.1415 (WinBuild.160101.0800) .\System.Private.CoreLib.dll, version=6.0.121.56705 .\clrjit.dll, version=6,0,121,56705 @Commit: 3a25a7f1cc446b60678ed25c9d829420d6321eba C:\WINDOWS\SYSTEM32\kernel.appcore.dll, version=10.0.19041.546 (WinBuild.160101.0800) .\paintdotnet.dll, version=4.307.8039.30451 .\System.Runtime.dll, version=6.0.121.56705 C:\WINDOWS\system32\uxtheme.dll, version=10.0.19041.1 (WinBuild.160101.0800) .\System.Windows.Forms.dll, version=6.0.121.56705 .\PaintDotNet.Base.dll, version=4.307.8039.30451 .\System.Diagnostics.Process.dll, version=6.0.121.56705 .\TerraFX.Interop.Windows.dll, version=10.0.20348.0 .\PaintDotNet.SystemLayer.dll, version=4.307.8039.30451 .\System.Runtime.InteropServices.RuntimeInformation.dll, version=6.0.121.56705 .\System.Runtime.InteropServices.dll, version=6.0.121.56705 .\vcruntime140.dll, version=14.30.30704.0 built by: vcwrkspc .\vcruntime140_1.dll, version=14.30.30704.0 built by: vcwrkspc .\msvcp140.dll, version=14.30.30704.0 built by: vcwrkspc .\msvcp140_1.dll, version=14.30.30704.0 built by: vcwrkspc .\msvcp140_2.dll, version=14.30.30704.0 built by: vcwrkspc .\msvcp140_codecvt_ids.dll, version=14.30.30704.0 built by: vcwrkspc .\vcomp140.dll, version=14.30.30704.0 built by: vcwrkspc .\ijwhost.dll, version=6,0,121,56705 @Commit: 3a25a7f1cc446b60678ed25c9d829420d6321eba .\PaintDotNet.SystemLayer.Native.x64.dll, version=4.307.8039.30451 C:\WINDOWS\SYSTEM32\PROPSYS.dll, version=7.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\WindowsCodecs.dll, version=10.0.19041.1151 (WinBuild.160101.0800) C:\WINDOWS\System32\bcrypt.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.19041.1348_none_91a2627ccc89e3fb\gdiplus.dll, version=10.0.19041.1348 (WinBuild.160101.0800) .\System.Threading.dll, version=6.0.121.56705 .\System.Runtime.Extensions.dll, version=6.0.121.56705 .\System.Runtime.CompilerServices.VisualC.dll, version=6.0.121.56705 .\System.Collections.NonGeneric.dll, version=6.0.121.56705 .\System.Runtime.Intrinsics.dll, version=6.0.121.56705 C:\WINDOWS\SYSTEM32\windows.storage.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\Wldp.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\System32\SHCORE.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\System32\shlwapi.dll, version=10.0.19041.1 (WinBuild.160101.0800) .\PaintDotNet.Core.dll, version=4.307.8039.30451 .\System.Private.Uri.dll, version=6.0.121.56705 .\System.ComponentModel.Primitives.dll, version=6.0.121.56705 .\WindowsBase.dll, version=6.0.121.56707 .\System.Windows.Forms.Primitives.dll, version=6.0.121.56705 .\PresentationFramework.dll, version=6.0.121.56707 .\System.Drawing.Primitives.dll, version=6.0.121.56705 .\System.Xaml.dll, version=6.0.121.56707 .\System.ComponentModel.dll, version=6.0.121.56705 .\System.Diagnostics.TraceSource.dll, version=6.0.121.56705 .\System.Collections.dll, version=6.0.121.56705 .\System.Threading.Thread.dll, version=6.0.121.56705 .\System.Text.Encoding.CodePages.dll, version=6.0.121.56705 .\Microsoft.Win32.Primitives.dll, version=6.0.121.56705 .\PaintDotNet.Resources.dll, version=4.307.8039.30451 .\Newtonsoft.Json.dll, version=13.0.1.25517 .\PresentationNative_cor3.dll, version=6,0,21,48001 @Commit: bf6f24c075ff5315d0ec0e5359138ee796b0491c .\System.Configuration.ConfigurationManager.dll, version=6.0.121.56705 .\System.Linq.Expressions.dll, version=6.0.121.56705 .\System.Collections.Specialized.dll, version=6.0.121.56705 .\System.ComponentModel.TypeConverter.dll, version=6.0.121.56705 .\System.ObjectModel.dll, version=6.0.121.56705 .\System.Xml.ReaderWriter.dll, version=6.0.121.56705 .\System.Private.Xml.dll, version=6.0.121.56705 .\System.Runtime.Numerics.dll, version=6.0.121.56705 .\System.Net.WebClient.dll, version=6.0.121.56705 .\System.ComponentModel.EventBasedAsync.dll, version=6.0.121.56705 .\PaintDotNet.Data.dll, version=4.307.8039.30451 .\System.Memory.dll, version=6.0.121.56705 .\System.Text.Encoding.Extensions.dll, version=6.0.121.56705 C:\WINDOWS\SYSTEM32\icu.dll, version=64, 2, 0, 0 (WinBuild.160101.0800) .\PaintDotNet.Framework.dll, version=4.307.8039.30451 .\Microsoft.Win32.SystemEvents.dll, version=6.0.121.56705 .\Microsoft.Win32.Registry.dll, version=6.0.121.56705 .\System.Drawing.Common.dll, version=6.0.121.56705 .\System.Linq.dll, version=6.0.121.56705 .\System.Threading.ThreadPool.dll, version=6.0.121.56705 C:\WINDOWS\System32\MSCTF.dll, version=10.0.19041.1 (WinBuild.160101.0800) .\System.Collections.Immutable.dll, version=6.0.121.56705 C:\WINDOWS\SYSTEM32\dxgi.dll, version=10.0.19041.1266 (WinBuild.160101.0800) .\PresentationCore.dll, version=6.0.121.56707 .\System.Collections.Concurrent.dll, version=6.0.121.56705 .\DirectWriteForwarder.dll, version=6,0,121,56707 @Commit: 0350d04790959e8ebdd3ceab0d34a40f811f019d .\System.Diagnostics.Debug.dll, version=6.0.121.56705 C:\WINDOWS\SYSTEM32\dwrite.dll, version=10.0.19041.1 (WinBuild.160101.0800) .\System.Runtime.Serialization.Primitives.dll, version=6.0.121.56705 .\UIAutomationTypes.dll, version=6.0.121.56707 .\System.Diagnostics.FileVersionInfo.dll, version=6.0.121.56705 .\PaintDotNet.Effects.dll, version=4.307.8039.30451 .\Accessibility.dll, version=6.0.121.56705 C:\WINDOWS\System32\clbcatq.dll, version=2001.12.10941.16384 (WinBuild.160101.0800) C:\WINDOWS\System32\UIAnimation.dll, version=10.0.19041.746 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\version.dll, version=10.0.19041.546 (WinBuild.160101.0800) .\System.Numerics.Vectors.dll, version=6.0.121.56705 C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.19041.1110_none_60b5254171f9507e\comctl32.dll, version=6.10 (WinBuild.160101.0800) .\Crc32.NET.dll, version=1.2.0.5 .\System.Security.Cryptography.Primitives.dll, version=6.0.121.56705 C:\WINDOWS\SYSTEM32\d2d1.dll, version=10.0.19041.1 (WinBuild.160101.0800) .\System.Threading.Tasks.Parallel.dll, version=6.0.121.56705 .\System.IO.Packaging.dll, version=6.0.121.56705 .\System.Reflection.MetadataLoadContext.dll, version=6.0.21.52210 C:\WINDOWS\SYSTEM32\TextShaping.dll, version= .\System.Reflection.Metadata.dll, version=6.0.121.56705 .\System.Diagnostics.Tracing.dll, version=6.0.121.56705 .\System.Runtime.Loader.dll, version=6.0.121.56705 .\ucrtbase.dll, version=10.0.19041.685 (WinBuild.160101.0800) .\System.IO.MemoryMappedFiles.dll, version=6.0.121.56705 .\FileTypes\ABRFileType.dll, version=1.3.0.0 .\FileTypes\PaintShopProFiletype.dll, version=1.0.2.0 .\FileTypes\Jpeg2000Filetype.dll, version=1.0.1.0 .\FileTypes\RawFileType.dll, version=1.2.2.0 .\FileTypes\Base64FileType.dll, version=1.0.0.8 .\FileTypes\AnimGIF.dll, version=2.4.4119.28305 .\FileTypes\PatternFileType.dll, version=1.0.5.0 .\FileTypes\OptimizedJPEG.dll, version=1.0.2.0 .\FileTypes\TileImageFileType.dll, version=1.0.0.1 .\FileTypes\FSHfiletype.dll, version=1.2.4.0 .\mscorlib.dll, version=6.0.121.56705 .\System.dll, version=6.0.121.56705 .\System.Drawing.dll, version=6.0.121.56705 .\System.Runtime.Serialization.Formatters.dll, version=6.0.121.56705 C:\WINDOWS\SYSTEM32\wtsapi32.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\WINSTA.dll, version=10.0.19041.546 (WinBuild.160101.0800) .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, version=1.10.10.0 C:\WINDOWS\SYSTEM32\mfplat.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\System32\cfgmgr32.dll, version=10.0.19041.1151 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\RTWorkQ.DLL, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\d3d11.dll, version=10.0.19041.1202 (WinBuild.160101.0800) .\Bundled\AvifFileType\AvifFileType.dll, version=1.1.17.0 C:\WINDOWS\SYSTEM32\CompPkgSup.DLL, version=10.0.19041.746 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\D3D10Warp.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\UIAutomationCore.dll, version=7.2.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\dxcore.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\Windows\System32\Windows.StateRepositoryPS.dll, version=10.0.19041.844 (WinBuild.160101.0800) .\Bundled\WebPFileType\WebPFileType.dll, version=1.3.7.0 C:\Windows\System32\WinTypes.dll, version=10.0.19041.1320 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\sxs.dll, version=10.0.19041.1 (WinBuild.160101.0800) .\System.Core.dll, version=6.0.121.56705 .\Mono.Cecil.dll, version=0.11.4.0 .\netstandard.dll, version=6.0.121.56705 .\System.CodeDom.dll, version=6.0.121.56705 .\System.Security.Claims.dll, version=6.0.121.56705 C:\WINDOWS\SYSTEM32\dwmapi.DLL, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\system32\dataexchange.dll, version=10.0.19041.1387 (WinBuild.160101.0800) C:\WINDOWS\system32\dcomp.dll, version=10.0.19041.1387 (WinBuild.160101.0800) C:\WINDOWS\system32\twinapi.appcore.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\textinputframework.dll, version=10.0.19041.1387 (WinBuild.160101.0800) C:\WINDOWS\System32\CoreMessaging.dll, version=10.0.19041.746 C:\WINDOWS\System32\WS2_32.dll, version=10.0.19041.1081 (WinBuild.160101.0800) C:\WINDOWS\System32\CoreUIComponents.dll, version=10.0.19041.546 C:\WINDOWS\SYSTEM32\ntmarta.dll, version=10.0.19041.1 (WinBuild.160101.0800) .\Effects\XYCoords.dll, version=1.0.0.0 .\System.Console.dll, version=6.0.121.56705 .\Effects\xmario_cut_color_en.dll, version=1.0.3769.28056 C:\WINDOWS\SYSTEM32\powrprof.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\UMPDC.dll, version= .\System.Text.RegularExpressions.dll, version=6.0.121.56705 .\Effects\X Rainbow bars.dll, version=1.0.3536.37632 .\Effects\WhichSymbolPlus.dll, version=1.0.0.0 .\Effects\WhichSymbol.dll, version=2.0.3112.39397 .\Effects\WetFloor.dll, version=1.1.0.0 C:\WINDOWS\SYSTEM32\amsi.dll, version=10.0.19041.746 (WinBuild.160101.0800) .\Effects\WaveTextSUI.dll, version=1.2.4415.33440 .\PaintDotNet.Plugins.Compatibility.dll, version=4.307.8039.30451 .\Effects\Curves+.dll, version=4.0.4642.26561 .\Effects\WaveText.dll, version=1.2.4415.32811 .\Effects\Waves.dll, version=1.1.0.0 .\Effects\WaterReflection.dll, version=1.1.0.0 .\Effects\Volutes.dll, version=1.1.0.0 .\System.Windows.Forms.Legacy.dll, version=0.1.1.0 .\Effects\Vignette1.dll, version=1.0.3538.14367 .\System.Runtime.CompilerServices.Unsafe.dll, version=6.0.121.56705 .\System.Design.dll, version=6.0.121.56705 .\System.Windows.Forms.Design.dll, version=6.0.121.56705 .\Effects\Vibrato.dll, version=1.1.0.0 .\Effects\Vibration.dll, version=1.0.4407.34043 C:\WINDOWS\SYSTEM32\oleacc.dll, version=7.2.19041.746 (WinBuild.160101.0800) .\Effects\Vandermotten.PaintDotNetEffects.ObjectAlign.dll, version=3.8.0.0 C:\WINDOWS\system32\explorerframe.dll, version=10.0.19041.1 (WinBuild.160101.0800) .\System.Xml.dll, version=6.0.121.56705 .\Effects\Vandermotten.PaintDotNetEffects.Monochromes.dll, version=3.8.0.0 .\System.Diagnostics.StackTrace.dll, version=6.0.121.56705 .\Microsoft.DiaSymReader.Native.amd64.dll, version=14.28.29715.1 built by: vcwrkspc .\Effects\Vandermotten.PaintDotNetEffects.Grid.dll, version=3.8.0.0 C:\WINDOWS\SYSTEM32\winmm.DLL, version=10.0.19041.1 (WinBuild.160101.0800) .\Effects\Vandermotten.PaintDotNetEffects.Gradient.dll, version=3.8.0.0 .\Effects\Vandermotten.PaintDotNetEffects.FadeEdge.dll, version=3.8.0.0 .\Effects\Vandermotten.PaintDotNetEffects.Duotones.dll, version=3.8.0.0 C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5d5c294bb8d17217\nvldumdx.dll, version=30.0.14.7141 C:\WINDOWS\SYSTEM32\msasn1.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\cryptnet.dll, version=10.0.19041.906 (WinBuild.160101.0800) C:\WINDOWS\System32\CRYPT32.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\drvstore.dll, version=10.0.19041.1320 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\devobj.dll, version=10.0.19041.1151 (WinBuild.160101.0800) .\Effects\Vandermotten.PaintDotNetEffects.DropShadow.dll, version=3.8.0.0 C:\WINDOWS\SYSTEM32\cryptbase.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\System32\WINTRUST.DLL, version=10.0.19041.1266 (WinBuild.160101.0800) C:\WINDOWS\System32\imagehlp.dll, version=10.0.19041.1415 (WinBuild.160101.0800) .\Effects\Vandermotten.PaintDotNetEffects.ColorAccent.dll, version=3.8.0.0 C:\WINDOWS\SYSTEM32\CRYPTSP.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\system32\rsaenh.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5d5c294bb8d17217\nvwgf2umx.dll, version=30.0.14.7141 .\Effects\Vandermotten.PaintDotNetEffects.Blurs.dll, version=3.8.0.0 C:\WINDOWS\system32\nvspcap64.dll, version=3.23.0.74 C:\WINDOWS\SYSTEM32\profapi.dll, version=10.0.19041.844 (WinBuild.160101.0800) .\Effects\Unblend.dll, version=1.0.5176.26202 .\Effects\TwoToneThreshold.dll, version=1.0.0.0 .\Effects\TwoPointPerspective.dll, version=1.6.0.0 .\Effects\TwistZ.dll, version=1.1.2.0 .\Effects\Twist.dll, version=4.0.4642.26767 .\Effects\Tweaktrans2.dll, version=2.0.4252.27152 .\Effects\Tweaktrans.dll, version=1.0.4193.41856 .\Effects\Tweakedges.dll, version=1.0.4252.39711 .\Effects\TwainablePlus.dll, version=1.0.0.2 .\Effects\TubeOblique.dll, version=1.0.0.0 .\Effects\TRsZigZag.dll, version=1.1.4929.6773 .\Effects\TRsTreeMaker.dll, version=1.0.3.0 .\Effects\TRsTiltShift.dll, version=1.0.4957.12341 .\Effects\TRsTiledPixels.dll, version=1.2.4942.13226 .\Effects\TRsThirdDimension.dll, version=1.7.13.38717 .\Effects\TRsTeslaCoil.dll, version=1.0.4935.18219 .\Effects\TRsStrobeMotion.dll, version=1.2.4962.30523 .\Effects\TRsStrangeAttractor.dll, version=1.1.4.0 .\Effects\TRsStr8Edge.dll, version=1.1.5045.31905 .\Effects\TRsStarFilter.dll, version=1.0.4930.9612 .\Effects\TRsSplineMaster.dll, version=1.4.2.18310 .\Effects\TRsSphereCuber.dll, version=1.0.1.0 .\Effects\TRsSnowFlakeMaker.dll, version=1.0.1.1701 .\Effects\TRsSmudger.dll, version=2.2.0.0 .\Effects\TRsSelfeez.dll, version=1.0.2.0 .\Effects\TRsRetouch.dll, version=1.0.5684.16160 .\Effects\TRsRadialExtruder.dll, version=1.2.5609.8244 .\Effects\TRsPSnap.dll, version=1.2.0.0 .\Effects\TRsPlasmatix.dll, version=1.0.5220.31660 .\Effects\TRsPixelSharp.dll, version=2.0.5467.31590 .\Effects\TRsPixelPuller.dll, version=1.1.4994.29625 .\Effects\TRsPasteWarp.dll, version=1.0.0.0 .\Effects\TRsPasteFrame.dll, version=1.3.20.9613 .\Effects\TRsMonolithic.dll, version=1.0.4.12960 .\Effects\TRsKaboom.dll, version=1.0.5118.21464 .\Effects\TRsIsopleth.dll, version=1.0.3.10995 .\Effects\TRsIPollock.dll, version=1.0.3.11944 .\Effects\TRsIntensityWarp.dll, version=1.3.0.0 .\Effects\TRsIntenseFilteration.dll, version=1.3.5390.22367 .\Effects\TRsHDRish.dll, version=1.0.5198.19546 .\Effects\TRsHalfTone.dll, version=1.0.4937.7773 .\Effects\TRsGlassVignette.dll, version=1.1.5239.30797 .\Effects\TRsFuego.dll, version=1.0.5.0 .\Effects\TRsFireWorks.dll, version=1.2.0.0 .\Effects\TRsFilmStripPlgIn.dll, version=1.0.2.0 .\Effects\TRsFilmStock.dll, version=1.2.0.0 .\Effects\TRsFilaments.dll, version=1.0.15.11399 .\Effects\TRsExportSelection.dll, version=1.0.5668.9645 .\Effects\TRsDrumSkin.dll, version=1.4.5199.15427 .\Effects\TRsDodgeBurn.dll, version=1.4.0.33503 .\Effects\Scribble.dll, version=1.0.1.0 .\Effects\SelectionInnerContour.dll, version=0.0.0.0 .\Effects\TRsDodgeBurn.resources.dll, version=1.3.26.12436 .\Effects\CustomControls.dll, version=0.0.0.0 .\Effects\Shape3D.dll, version=1.2.6.0 .\Effects\TRsCustomRandomFill.dll, version=1.5.1.31287 .\Effects\GpcDotNet.AMD64.dll, version= C:\WINDOWS\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9625_none_08e1c10da83fbc83\MSVCR90.dll, version=9.00.30729.9625 C:\WINDOWS\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9625_none_08e1c10da83fbc83\msvcm90.dll, version=9.00.30729.9625 C:\WINDOWS\SYSTEM32\mscoree.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscoreei.dll, version=4.8.4180.0 built by: NET48REL1LAST_B .\Effects\SoftProofing.dll, version=1.1.0.1 .\Effects\TRsCustomPaletteMatch.dll, version=1.0.5.0 C:\Windows\Microsoft.NET\Framework64\v2.0.50727\mscorwks.dll, version=2.0.50727.9151 (WinRelRS6.050727-9100) C:\WINDOWS\WinSxS\amd64_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.9672_none_88e266cb2fac7c0d\MSVCR80.dll, version=8.00.50727.9672 .\Effects\TRsCroquis.dll, version=1.4.5634.10354 C:\WINDOWS\assembly\NativeImages_v2.0.50727_64\mscorlib\95ce4e7117457677f847d9f26c3bdf0b\mscorlib.ni.dll, version=2.0.50727.9151 (WinRelRS6.050727-9100) .\Effects\TRsCoquin.dll, version=1.0.4960.31131 C:\Windows\Microsoft.NET\Framework64\v2.0.50727\mscorjit.dll, version=2.0.50727.9149 (WinRelRS6.050727-9100) .\Effects\TRsContourFiller.dll, version=1.5.2.0 .\Effects\TRsColorReducer.dll, version=1.0.2.0 .\Effects\TRsMorpher.dll, version=1.1.2.15085 .\Effects\TRsCloudControl.dll, version=2.0.4968.34489 .\Effects\2dImageFilter-r25b.dll, version=1.0.0.30 .\Effects\AA's_Assistant.dll, version=1.1.4329.33034 .\Effects\TRsBWPhoto.dll, version=1.0.4949.38907 .\Effects\Aardvark.dll, version=1.0.6.0 .\Effects\Add Depth.dll, version=1.0.4247.30168 .\Effects\TRsBrushStrokes.dll, version=1.0.6.11937 .\Effects\Add-Remove Watermark.dll, version=1.0.3138.19150 .\Effects\AdvancedRotate.dll, version=1.0.3663.28009 .\Effects\advcolorrep.dll, version=1.3.3303.27314 .\Effects\TRsBokeh.dll, version=2.0.5457.42261 .\Effects\AdvGrey.dll, version=0.0.0.0 .\Effects\Alias.dll, version=2.0.3167.14578 .\Effects\AlignPlugin.dll, version=1.5.1.0 .\Effects\TRsAlphaMapper.dll, version=1.0.1.0 .\Effects\Alpha Transform.dll, version=1.1.3545.21589 .\Effects\Alpha-Displacement Mask.dll, version=1.4.1.1 .\Effects\AlphaContrast.dll, version=1.0.3813.18307 .\Effects\TRsAlphaCutter.dll, version=3.0.4.0 .\Effects\AlphaMask.dll, version=2.0.3574.41943 .\Effects\AlphaMaskBrush.dll, version=1.5.0.0 .\Effects\AlphaSpace.dll, version=1.0.0.0 .\Effects\TRs Scatter.dll, version=1.3.4949.23250 .\Effects\AlphaThreshold.dll, version=1.0.0.0 .\Effects\AlphaToDots.dll, version=1.0.4675.19955 .\Effects\AlphaTransform.dll, version=1.2.0.0 .\Effects\Alpha_to_255.dll, version=1.0.4452.22782 .\Effects\TriangularGradient.dll, version=1.0.3733.28856 .\Effects\AnimationEffect.dll, version=1.0.0.10 .\Effects\Alpha_to_0.dll, version=1.0.4452.22746 .\Effects\Apply Color.dll, version=1.0.4406.25220 .\Effects\Apply Texture.dll, version=1.0.0.0 .\Effects\ArgusPDN.Barcode.dll, version=1.0.0.0 .\Effects\TreeGen.dll, version=1.1.0.0 .\Effects\ArgusPDN.EdgeDetect.dll, version=1.0.0.0 .\Effects\Antialias_v1.5.8.0.dll, version=0.0.0.0 .\Effects\ArgusPDN.Unblend.dll, version=1.0.0.0 .\Effects\Arrows.dll, version=1.0.0.0 .\Effects\ArtyThing.dll, version=1.0.5.0 .\Effects\Asmageddon_Alpha works.dll, version=0.0.0.0 .\Effects\TransparencyRGB.dll, version=1.0.1.0 .\Effects\Asmageddon_Channel_Shift.dll, version=0.0.0.0 .\Effects\ArgusPDN.FFTEffects.dll, version=1.0.0.0 .\Effects\Asmageddon_Channel_Works_Plus.dll, version=0.0.0.0 .\Effects\Asmageddon_Color_Percentage_Plus.dll, version=0.0.0.0 .\Effects\Asmageddon_From P to S Grey.dll, version=0.0.0.0 .\Effects\Asmageddon_From P to S.dll, version=0.0.0.0 .\Effects\Asmageddon_HSV inversion.dll, version=0.0.0.0 .\Effects\Asmageddon_Channel multiplier.dll, version=0.0.0.0 .\Effects\Transitional Brush.dll, version=1.0.0.0 .\Effects\Asmageddon_Hue Red Psychodelic.dll, version=0.0.0.0 .\Effects\Asmageddon_Image coder.dll, version=0.0.0.0 .\Effects\Asmageddon_Inverto_pushing.dll, version=0.0.0.0 .\Effects\Asmageddon_Inverto_pushing_Caleidoscope.dll, version=0.0.0.0 .\Effects\Asmageddon_Inverto_pushing_plus.dll, version=0.0.0.0 .\Effects\Asmageddon_Multiplo uniqua.dll, version=0.0.0.0 .\Effects\Asmageddon_PS Mega.dll, version=0.0.0.0 .\Effects\Asmageddon_PS Only.dll, version=0.0.0.0 .\Effects\Asmageddon_Hue Channeling multiply.dll, version=0.0.0.0 .\Effects\trail3d.dll, version=1.0.3902.32071 .\Effects\Asmageddon_Quadro disorter B.dll, version=0.0.0.0 .\Effects\Asmageddon_Quadro disorter.dll, version=0.0.0.0 .\Effects\Asmageddon_Render-Border.dll, version=0.0.0.0 .\Effects\Asmageddon_Render-Quadro bumperoo.dll, version=0.0.0.0 .\Effects\Asmageddon_Render-Quadro inverto.dll, version=0.0.0.0 .\Effects\Asmageddon_Render-Quadro sharper.dll, version=0.0.0.0 .\Effects\Asmageddon_RGB tricks.dll, version=0.0.0.0 .\Effects\Asmageddon_Pseudo water.dll, version=0.0.0.0 .\Effects\Asmageddon_Strange_Bulger Kaleidoscope.dll, version=0.0.0.0 .\Effects\AutoChrome.dll, version=1.2.0.0 .\Effects\Trail.dll, version=4.0.4642.26791 .\Effects\AutoChromeNoise.dll, version=1.0.3847.37353 .\Effects\AverageColorHSL.dll, version=1.0.3601.21265 .\Effects\AveragedColorBlur.dll, version=1.1.1.0 .\Effects\AverageEdgeBlur.dll, version=1.0.3991.32409 .\Effects\AverageSelectionColor.dll, version=1.1.3256.33886 .\Effects\Barcode.dll, version=1.5.0.0 .\Effects\Bars.dll, version=1.1.0.0 .\Effects\BasicAntialias.dll, version=0.0.0.0 .\Effects\BasicPhotoAdjustments.dll, version=2.0.3854.18994 .\Effects\Asmageddon_Strange Bulger.dll, version=1.0.3326.10720 .\Effects\BevelObject.dll, version=1.0.1.0 .\Effects\TR'sColorizerHMS.dll, version=1.0.4937.30626 .\Effects\Bevel_v1.4.0.0.dll, version=0.0.0.0 .\Effects\Bezncurve.dll, version=1.0.0.0 .\Effects\Bizarro-Negation.dll, version=1.0.4617.21771 .\Effects\Black and White Converter.dll, version=1.1.0.0 .\Effects\BlackandAlpha+.dll, version=1.2.4329.272 .\Effects\BlackAndWhite.dll, version=1.2.3526.15024 .\Effects\BlurFill.dll, version=1.5.1.0 .\Effects\Border.dll, version=0.0.0.0 .\Effects\Borders N' Shapes.dll, version=4.0.4642.26476 .\Effects\Boutons.dll, version=1.1.0.0 .\Effects\BBOutlinedGradientText.dll, version=4.6.7358.38713 .\Effects\BulletinBoardTrim.dll, version=1.0.0.0 .\Effects\TR's Pixel Push.dll, version=1.0.4954.37564 .\Effects\BumpChecker.dll, version=1.4.4399.25606 .\Effects\Calendar.dll, version=4.6.7358.32649 .\Effects\CalliColour.dll, version=1.0.1.0 .\Effects\CameraTrouserFlareV3.dll, version=1.1.4600.41268 .\Effects\Cartoonize.dll, version=1.0.4629.37393 .\Effects\CellMaker.dll, version=0.0.0.0 .\Effects\CellTexture.dll, version=1.0.0.0 .\Effects\CenterLines.dll, version=1.1.1.0 .\Effects\Channel Swap.dll, version=1.0.4602.41418 .\Effects\ChannelMixer.dll, version=1.0.3493.40525 .\Effects\Bullet.dll, version=1.0.0.0 .\Effects\ChartWhiteBalance.dll, version=1.0.0.0 .\Effects\Checkboard.dll, version=1.0.0.0 .\Effects\Toon.dll, version=0.0.0.0 .\Effects\ChessFEN.dll, version=1.0.3116.32335 .\Effects\ChromaKeyPlugin.dll, version=1.0.0.2 .\Effects\CircleText.dll, version=1.4.4415.32488 .\Effects\ClampedGaussianBlur.dll, version=2.1.0.0 .\Effects\Clarifaction+.dll, version=1.0.4406.25898 .\Effects\Clarify.dll, version=1.0.4349.19613 .\Effects\CleanTransparent.dll, version=1.0.0.0 .\Effects\ClipWarpNew.dll, version=1.0.1.0 .\Effects\CloudEffect.dll, version=1.1.0.0 .\Effects\CMY Ghost.dll, version=1.0.4909.35063 .\Effects\Channels.dll, version=2.0.0.0 .\Effects\CodeLab.dll, version=1.8.4305.21282 .\Microsoft.VisualBasic.dll, version=6.0.121.56705 .\Effects\Color Balance Mix.dll, version=2.5.3502.26787 .\Effects\Color Clearer 1.1.dll, version=1.1.6010.17371 .\Effects\Color Dimmer.dll, version=1.0.4658.40889 .\Effects\Color Match.dll, version=4.0.4642.26532 .\Effects\coloraberation.dll, version=1.0.3859.18981 .\Effects\ColorCount.dll, version=1.0.0.0 .\Effects\ColorExchange.dll, version=1.1.5002.19815 .\Effects\ColorHarmonies.Effect.dll, version=0.7.0.155 .\Effects\Cobweb.dll, version=1.0.1.0 .\Effects\ColorMixer.dll, version=1.3.0.0 .\Microsoft.VisualBasic.Forms.dll, version=6.0.121.56705 .\Effects\ColorModulo.dll, version=0.0.0.0 .\Effects\ColorRamp.dll, version=1.0.0.0 .\Effects\ColorRange.dll, version=1.2.1.0 .\Effects\ColorRange_en.dll, version=1.0.0.0 .\Effects\ColorSketch.dll, version=1.1.1.0 .\Effects\ColorSketch_en.dll, version=1.0.0.0 .\Effects\ColorStretchV10.dll, version=1.0.3116.21703 .\Effects\ColorTarget.dll, version=1.3.3116.21867 .\Effects\ColorMatrix.Effect.dll, version=1.1.0.22 .\Effects\TJacksonEffects.dll, version=1.0.0.0 .\Effects\ColorTrimming.dll, version=1.0.3167.14623 .\Effects\ColorZoomBlur.dll, version=1.1.3873.36417 .\Effects\Colour Distort.dll, version=1.0.3564.18753 .\Effects\colourblindsim.dll, version=1.0.3891.486 .\Effects\colourchop3.dll, version=1.3.3877.4590 .\Effects\coltoalphaadv.dll, version=1.0.3100.18431 .\Effects\Compotool.dll, version=1.0.1.0 .\Effects\ConditionalEffects.dll, version=1.3.3919.30824 .\Effects\ConditionalPen.dll, version=1.1.0.0 .\Effects\Contour.dll, version=1.0.1.0 .\Effects\contour42.dll, version=1.0.4013.31152 .\Effects\CoordinatePlanePoints.dll, version=1.1.6846.29158 .\Effects\CopyAlpha.dll, version=1.0.0.0 .\Effects\CreateImageMap.dll, version=1.0.0.0 .\Effects\CreatePattern.dll, version=1.0.0.0 .\Effects\ColorToAlpha.dll, version=2.3.0.0 .\Effects\CreativeTextPro.dll, version=1.1.7358.34307 .\Effects\Tint-Splitter.dll, version=1.0.4636.5475 .\Effects\CurlyLines.dll, version=1.0.0.0 .\Effects\CycleHSV.dll, version=1.0.4909.35068 .\Effects\DHShapeMaker.dll, version=1.0.5.40717 .\Effects\Diagonal Lines.dll, version=2.5.3543.22117 .\Effects\Diffuse.dll, version=1.0.3254.27766 .\Effects\Dimensions.dll, version=1.3.6826.38472 .\Effects\DirectionalBlur.dll, version=0.0.0.0 .\Effects\Displacement.dll, version=1.1.0.0 .\Effects\DispMap.dll, version=2.0.4919.36181 .\Effects\Dissolve.dll, version=1.0.0.0 .\Effects\DistortingMirror.dll, version=1.0.4281.30602 .\Effects\DistortThis.dll, version=2.9.0.0 .\Effects\Donut.dll, version=1.0.4354.32246 .\Effects\Dot.dll, version=1.0.4673.202 .\Effects\DotAtCenter2.1.dll, version=0.0.0.0 .\Effects\dpyColorBalance.dll, version=1.1.4330.37850 .\Effects\DraganEffect.dll, version=1.1.1.0 .\Effects\Tiles.dll, version=1.1.1.0 .\Effects\DragFrom.dll, version=1.1.0.0 .\Effects\Droste.dll, version=1.0.0.0 .\Effects\DrPrepper.dll, version=1.4.4399.25637 .\Effects\Dryad.dll, version=1.0.1.0 .\Effects\Dull.dll, version=1.0.3314.38674 .\Effects\DynamicContrast.dll, version=1.1.1.0 .\Effects\EarthsAndGreys.dll, version=1.0.1.0 .\Effects\EasyWatermark1.dll, version=1.0.0.0 .\Effects\EdgeFader.dll, version=5.3.5.0 .\Effects\edgemaster.dll, version=1.0.3880.5859 .\Effects\EdHarvey.FastFx.dll, version=0.1.3426.11348 .\Effects\Egalize.dll, version=1.0.0.0 .\Effects\EigenBlur.dll, version=1.3.3555.24648 .\Effects\EliminateBlack.dll, version=1.0.5618.24761 .\Effects\EliminateDarkLight.dll, version=1.1.1.0 .\Effects\EliminateWhite.dll, version=1.0.5618.24771 .\Effects\Emboss+.dll, version=1.2.1.0 .\Effects\Threshold.dll, version=1.0.0.0 .\Effects\EngraveEmboss.dll, version=2.0.2 .\Effects\EnhanceDetails.dll, version=1.0.3581.22689 .\Effects\EOEffects.dll, version=1.8.1.12 .\Effects\Erode.dll, version=1.0.0.0 .\Effects\ErodeDilate_v0.2.dll, version=1.0.0.0 .\Effects\ExtendBorder.dll, version=1.3.0.0 .\Effects\ExtractColor.dll, version=1.0.0.0 .\Effects\Eyeshine.dll, version=1.0.3700.25905 .\Effects\Facet.dll, version=1.0.3.0 .\Effects\FibonacciFill.dll, version=1.1.6139.28851 .\Effects\Film.dll, version=4.0.4642.26607 .\Effects\FilmNoir.dll, version=1.0.0.0 .\Effects\FindEdges.dll, version=1.2.0.0 .\Effects\Fire.dll, version=1.0.0.0 .\Effects\Fisheye.dll, version=2.2.5533.12794 .\Effects\Flip.dll, version=4.6.7358.36953 .\Effects\FloydSteinbergEffect.dll, version=1.0.0.0 .\Effects\ThreadsMarker.dll, version=0.0.0.0 .\Effects\IniFile.dll, version=2.0.2 .\Effects\FlySwatter.dll, version=0.0.0.0 .\Effects\Fractal.dll, version=1.0.0.0 .\Effects\Frame.dll, version=1.1.0.0 .\Effects\FSPost.dll, version=1.0.4913.8979 .\Effects\FurBlur.dll, version=1.0.1.0 .\Effects\FuzzyEdgeDetect.dll, version=1.0.5885.38970 .\Effects\GaussianBlurPlus.dll, version=4.2.5691.27401 .\Effects\Gears.dll, version=1.0.2.0 .\Effects\GenTree.dll, version=0.1.0.0 .\Effects\Gingham.dll, version=1.1.0.0 .\Effects\Gossamer.dll, version=1.0.1.0 .\Effects\Gradient Bars.dll, version=4.0.5152.23084 .\Effects\Gradient Blocks.dll, version=4.0.4642.26658 .\Effects\Gradient Blur.dll, version=1.0.0.0 .\Effects\Gradient Mapping.dll, version=4.0.4642.26687 .\Effects\GradientsGalore.dll, version=1.0.5.0 .\Effects\ThermalHeatMapEffect.dll, version=1.0.0.0 .\Effects\Grain.dll, version=1.0.3854.25523 .\Effects\Gralpha.dll, version=1.0.3684.31203 .\Effects\GraphPaper.dll, version=2.1.0.0 .\Effects\Gravity.dll, version=1.1.0.0 .\Effects\GreenTintReduction.dll, version=1.0.6484.29238 .\Effects\Grid Warp.dll, version=4.0.5149.26776 .\Effects\GridCheckerboard.dll, version=4.5.6828.36789 .\Effects\GridMaker.dll, version=4.0.0.0 .\Effects\GrimColorReaper.dll, version=1.2.4299.5808 .\Effects\HaarTransform.dll, version=1.1.4083.41831 .\Effects\Heightmap.dll, version=1.3.4172.23550 .\Effects\Helix.dll, version=1.0.1.0 .\Effects\HexaGrid.dll, version=1.2.0.0 .\Effects\Highlight.dll, version=1.0.1.0 .\Effects\HighPass.dll, version=1.2.3903.27501 .\Effects\HotMetalGlow.dll, version=1.2.5986.8090 .\Effects\ThatOtherApp.dll, version=2.2.0.0 .\Effects\Hue_Saturation+.dll, version=1.0.3277.32208 .\Effects\Illuminate.dll, version=0.0.0.0 .\Effects\IncreaseLocalContrast.dll, version=1.2.0.0 .\Effects\InkSketch+.dll, version=1.0.4629.39900 .\Effects\InputToOutput+.dll, version=1.0.4548.20355 .\Effects\InsetBoxShadow.dll, version=1.2.0.0 .\Effects\IntenColor.dll, version=1.0.0.0 .\Effects\IntensityRGB.dll, version=1.0.1.0 .\Effects\Interlace.dll, version=1.0.0.5 .\Effects\invert channels.dll, version=1.0.3509.14656 .\Effects\InvertAlpha.dll, version=1.0.3040.33378 .\Effects\invert_around_primcol.dll, version=1.1.3402.30348 .\Effects\iPhoneTabbarIconMaker.dll, version=1.0.3659.22550 .\Effects\isolate.dll, version=1.0.3303.3202 .\Effects\IsolateChannel.dll, version=1.0.0.0 .\Effects\IsometricCuboid.dll, version=1.6.0.0 .\Effects\IsolateWhiteBlack.dll, version=1.3.3676.24989 .\Effects\TextWindow.dll, version=1.4.0.0 .\Effects\jchunn.dll, version=1.0.0.0 .\Effects\JigsawPuzzle.dll, version=2.3.0.0 .\Effects\Jitter.dll, version=4.0.4642.26986 .\Effects\Texturize.dll, version=1.0.0.0 .\Effects\JPEGEffect.dll, version=1.0.0.0 .\Effects\KaleidoGen.dll, version=1.2.0.0 .\Effects\Kaleidoscope.dll, version=1.3.0.0 .\Effects\Textplus.dll, version=1.0.0.0 .\Effects\Kill Color Keeper.dll, version=1.0.6641.13453 .\Effects\KillColor.dll, version=1.0.3498.8108 .\Effects\KlumpNoiz.dll, version=1.1.0.0 .\Effects\Tattersall.dll, version=1.1.0.0 .\Effects\Kuwahara.dll, version=1.0.0.0 .\Effects\LaplacianPyramidFilter.dll, version=1.0.0.1 .\Effects\LavEnt.Effects.Mosaic.dll, version=1.1.0.0 .\Effects\Tartan.dll, version=1.5.1.0 .\Effects\LavEnt.Effects.RoundedRectangle.dll, version=1.3.0.0 .\Effects\LensFlare.dll, version=1.1.0.0 .\Effects\LensFlareV4.dll, version=1.0.4598.31112 .\Effects\SubtractColor.dll, version=1.0.4679.26877 .\Effects\Lightning.dll, version=1.1.3896.32593 .\Effects\LightRays.dll, version=1.3.0.0 .\Effects\Line Tracer.dll, version=1.0.4911.29141 .\Effects\SubLCD.dll, version=1.2.1.0 .\Effects\LinesGrid.dll, version=1.2.1.0 .\Effects\LinesGrid_en.dll, version=1.1.0.0 .\Effects\Linocut.dll, version=1.1.1.0 .\Effects\StringAndPin.dll, version=1.0.1.0 .\Effects\Linocut_en.dll, version=1.0.0.0 .\Effects\LocalContrast.dll, version=1.2.0.0 .\Effects\LocalNoise.dll, version=1.0.4674.29909 .\Effects\Liquify.dll, version=4.0.5873.25113 .\Effects\Magnifier.dll, version=1.1.0.0 .\Effects\Majority.dll, version=1.1.0.0 .\Effects\MakeTransparent.dll, version=1.0.0.0 .\Effects\ManualColorCorrection.dll, version=1.0.4314.41440 .\Effects\Matrice.dll, version=1.0.3810.11744 .\Effects\MemeMaker.dll, version=4.5.6828.38061 .\Effects\Metallize.dll, version=1.2.4415.32969 .\Effects\Mexican Hat Edge Detect.dll, version=1.0.0.0 .\Effects\MirrorRotate.dll, version=2.0.2 .\Effects\MirrorRotateMenu.dll, version=2.0.2 .\Effects\Moire.dll, version=1.1.0.0 .\Effects\Morphologic.dll, version=1.0.0.0 .\Effects\MosaicManiac.dll, version=1.0.0906.08 .\Effects\MoveSeams.dll, version=1.0.0.0 .\Effects\Stretch.dll, version=0.0.0.0 .\Effects\MultiColorGradient.dll, version=1.0.0.0 .\Effects\MultiSpline.dll, version=1.0.4.0 .\Effects\MultiThreshold.dll, version=1.1.4330.38982 .\Effects\Nebulous.dll, version=0.0.0.0 .\Effects\NeonEdges.dll, version=1.2.1.0 .\Effects\NeonEdges_en.dll, version=1.0.0.0 .\Effects\NewtonFractal.dll, version=0.0.0.0 .\Effects\NoiseBleach.dll, version=1.0.4909.35542 .\Effects\NoiseChoice.dll, version=1.0.1.0 .\Effects\Normalize.dll, version=1.0.0.0 .\Effects\Normalizer.dll, version=1.8.4399.25698 .\Effects\Norm_Render.dll, version=7.3.4484.27012 .\Effects\Object2Colour.dll, version=1.0.1.0 .\Effects\Objectedge.dll, version=1.0.1.0 .\Effects\ObjectFeather.dll, version=3.5.4315.35085 .\Effects\Oblique.dll, version=1.0.0.0 .\Effects\Offset Alternating Stripes.dll, version=1.0.6027.1223 .\Effects\Offset Shadow.dll, version=1.0.4247.30184 .\Effects\StrayPixelRemover.dll, version=1.0.0.0 .\Effects\Offset.dll, version=1.0.4914.19410 .\Effects\OilPaintingPlus.dll, version=4.6.7358.38406 .\Effects\Olden.dll, version=1.5.0.0 .\Effects\OldFeather.dll, version=2.3.4315.37038 .\Effects\OrbGenerator.dll, version=0.0.0.0 .\Effects\OtherFarmColorReplacer.dll, version=1.1.3263.11631 .\Effects\Outline Object.dll, version=4.0.4642.26954 .\Effects\Outline.dll, version=1.0.0.0 .\Effects\OutlineSelection.dll, version=1.0.3055.21360 .\Effects\Overblur.dll, version=1.0.1.0 .\Effects\Overliner.dll, version=1.2.3888.29226 .\Effects\PageCurl.dll, version=1.3.0.0 .\Effects\Panelling.dll, version=1.1.0.0 .\Effects\ParallelLines.Effect.dll, version=1.6.0.575 .\Effects\PasteFill.dll, version=2.0.0.0 .\Effects\PdnFF.dll, version=1.0.3.7 .\Effects\PDNSpriteSheetAnim.dll, version=1.0.0.3 .\Effects\PerlinTexture.dll, version=1.1.3857.30918 .\Effects\Stitch.dll, version=4.0.4642.26808 .\Effects\Perspective.dll, version=2.1.4415.36116 .\Effects\PerspectiveLines.dll, version=1.0.3676.3747 .\Effects\phips_fill_gaps.dll, version=1.0.3307.18956 .\Effects\phips_kill_color.dll, version=1.1.0.0 .\Effects\phips_selective_enhancer.dll, version=1.1.3302.33189 .\Effects\phips_selective_toning.dll, version=1.0.3304.32827 .\Effects\Phsycocolour2.dll, version=1.0.4034.2456 .\Effects\PieChart.dll, version=2.5.0.0 .\Effects\Pixelate+.dll, version=4.0.4642.26940 .\Effects\PixelatedFrame.dll, version=1.0.0.0 .\Effects\PixelLab.dll, version=1.0.0.0 .\Effects\Planetoid.dll, version=1.0.0.0 .\Effects\PlugInData.dll, version=1.4.0.0 .\Effects\PNG_Preprocessor.dll, version=1.0.3876.32360 .\Effects\PointBlur.dll, version=1.0.0.0 .\Effects\Polar.dll, version=1.1.1.0 .\Effects\PolariodFrame.dll, version=1.0.3171.27990 .\Effects\PolarRect.dll, version=0.0.0.0 .\Effects\StewienFilters.dll, version=1.2.0.0 .\Effects\PolyGlitch.Effects.dll, version=1.4.0.0 .\Effects\Polygon Tool.dll, version=1.0.0.0 .\Effects\Polygones.dll, version=1.1.0.0 .\Effects\PostageStamp.dll, version=1.1.0.0 .\Effects\posterize+.dll, version=1.0.4629.2600 .\Effects\PosterizeHSV.dll, version=1.0.3258.3285 .\Effects\PowerStretch.dll, version=1.9.3045.14671 .\Effects\PrimColOnly.dll, version=0.0.0.0 .\Effects\PrinterPlus.dll, version=1.5.0.0 .\Effects\PSEmboss.dll, version=1.0.0.0 .\Effects\Psychocolour.dll, version=1.0.1.0 .\Effects\pxEexpansion.dll, version=1.0.4437.36287 .\System.Resources.Extensions.dll, version=6.0.121.56705 .\Effects\QuadrilateralCorrection.dll, version=1.2.0.0 .\Effects\Quick Gravity.dll, version=1.0.4408.25818 .\Effects\Radialcolors.dll, version=1.1.0.0 .\Effects\RadiusFillCorners.dll, version=1.6.0.0 .\Effects\rainball.dll, version=1.0.4907.41850 .\Effects\rainbow loom.dll, version=3.0.3530.27322 .\Effects\Rainbow-Splitter.dll, version=1.0.4639.2372 .\Effects\rainbow3.dll, version=0.0.0.0 .\Effects\RainbowTwist.dll, version=1.1.0.0 .\Effects\Random Dots.dll, version=1.1.0.0 .\Effects\Random Effect.dll, version=4.0.4642.26928 .\Effects\Random lines.dll, version=1.1.0.0 .\Effects\Random Maze1.dll, version=1.1.0.0 .\Effects\Random Maze2.dll, version=1.1.0.0 .\Effects\Random Shape Fill.dll, version=4.0.4642.26910 .\Effects\RecolourChoice.dll, version=1.0.1.0 .\Effects\Recover Watermark.dll, version=1.0.3138.19404 .\Effects\RedEyeQuickFix.dll, version=1.1.3161.39688 .\Effects\RefocusingSDe.dll, version=1.0.3760.21016 .\Effects\RemoveBrightDark.dll, version=1.1.3063.36415 .\Effects\RemoveTransparency.dll, version=1.0.0.0 .\Effects\RenderColorWheel.dll, version=1.1.3258.28607 .\Effects\Reticulation.dll, version=1.4.1.0 .\Effects\ReverseColors.dll, version=1.0.4121.15722 .\Effects\ReverseFisheye35.dll, version=1.0.5146.25956 .\Effects\RGB2CMYK.dll, version=0.0.0.0 .\Effects\RGB_Remap4.dll, version=1.0.3538.24311 .\Effects\Rosaces.dll, version=1.1.0.0 .\System.Reflection.Emit.ILGeneration.dll, version=6.0.121.56705 .\Effects\RotateText.dll, version=1.1.4415.32628 .\Effects\RotateTextSUI.dll, version=1.1.4415.32713 .\Effects\Rotate_Zoom+.dll, version=1.11.5237.17779 .\Effects\RotationBilinear.dll, version=1.1.3594.29946 .\Effects\RubberStamp.dll, version=1.0.0.0 .\Effects\Ruler.dll, version=1.0.6846.37263 .\Effects\SaturationRGB.dll, version=1.2.1.0 .\Effects\SaturationRGB_en.dll, version=1.0.5395.16586 .\Effects\SaveForWebRIOT.dll, version=1.0.7.0 .\Effects\Scintillate.dll, version=1.0.1.0 .\System.Reflection.Emit.dll, version=6.0.121.56705 .\Effects\ScratchArt.dll, version=1.2.1.0 .\Effects\ScreenPixel.dll, version=1.1.6846.39497 .\Effects\SeamlessHelper.dll, version=0.0.0.0 .\Effects\SeamlessMove.dll, version=1.0.4690.40795 .\Effects\SeamlessTextureMaker.dll, version=1.0.0.0 .\Effects\SegmentImage.dll, version=1.1.3674.15788 .\Effects\Selection2Clear.dll, version=1.0.1.0 .\Effects\SelectionObscure.dll, version=1.1.4602.34476 .\Effects\Self-Negation.dll, version=1.1.4591.7662 .\Effects\ShadowHighlight.dll, version=2.2.0.0 .\Effects\Shapes.dll, version=1.4.0.0 .\Effects\Shape_umabob.dll, version=3.4.0.0 .\Effects\Sharpen+.dll, version=3.1.0.0 .\Effects\Shatters_0.55beta.dll, version=1.0.0.0 .\System.Reflection.Primitives.dll, version=6.0.121.56705 .\Effects\silhouetteplus.dll, version=1.1.3131.17586 .\Effects\SimulateColorDepth.dll, version=1.0.4211.27729 .\Effects\SinWaves.dll, version=1.1.0.0 .\Effects\SmartSharpen.dll, version=1.0.1.1 .\Effects\Smooth.dll, version=2.0.2 .\Effects\Smudge.dll, version=4.0.4642.26844 .\Effects\Sound wave.dll, version=2.1.3542.36435 .\Effects\Sparkles.dll, version=1.1.0.0 .\Effects\Specular.dll, version=1.0.3254.27778 .\Effects\SpeechBubble.dll, version=2.1.4445.42029 .\Effects\SpiralText.dll, version=1.4.4415.32775 .\Effects\Spiral.dll, version=1.1.0.0 .\Effects\SpiritLevel.Effect.dll, version=1.0.0.40 .\Effects\SpiroGraph.dll, version=1.1.0.0 .\Effects\SpiroShapes.dll, version=1.4.0.0 .\Effects\Splashes.dll, version=1.1.1.0 .\Effects\Stencil2Eye.dll, version=1.0.5009.601 .\Effects\Splatter.dll, version=4.0.4642.26829 .\Effects\SpokedWheel.dll, version=1.1.6846.37336 .\Effects\Sponge.dll, version=1.3.1.0 .\Effects\Sponge_en.dll, version=1.0.0.0 .\Effects\Squirkle.dll, version=1.0.1.0 .\Effects\SquirkleWarp.dll, version=1.0.1.0 .\Effects\SR.dll, version=1.0.3371.38258 .\Effects\StarGlow.dll, version=1.0.3839.21249 .\Effects\Starry.dll, version=0.0.0.0 .\Effects\Stars.dll, version=1.0.0.0 .\System.IO.FileSystem.dll, version=6.0.121.56705 C:\WINDOWS\SYSTEM32\MsftEdit.DLL, version=10.0.19041.1 (WinBuild.160101.0800) C:\Windows\System32\Windows.Globalization.dll, version=10.0.19041.1 (WinBuild.160101.0800) C:\Windows\System32\bcp47mrm.dll, version=10.0.19041.1266 (WinBuild.160101.0800) C:\Windows\System32\Bcp47Langs.dll, version=10.0.19041.1266 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\globinputhost.dll, version=10.0.19041.546 (WinBuild.160101.0800) .\System.Text.Json.dll, version=6.0.121.56705 .\System.Reflection.Emit.Lightweight.dll, version=6.0.121.56705 .\System.Text.Encodings.Web.dll, version=6.0.121.56705 .\System.IO.Compression.dll, version=6.0.121.56705 C:\WINDOWS\System32\setupapi.DLL, version=10.0.19041.1 (WinBuild.160101.0800) ------------------------------------------------------------------------------ pencil Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted January 6, 2022 Share Posted January 6, 2022 Looks like FastFx was using some internal functionality that it shouldn't have been using. I may be able to fix that up for 4.3.8, but I don't yet have a plan for if there will be a 4.3.8 release before the bigger 4.4 update that's coming down the pipeline (several months). Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
otuncelli Posted January 7, 2022 Share Posted January 7, 2022 (edited) 7 hours ago, Rick Brewster said: Looks like FastFx was using some internal functionality that it shouldn't have been using. I've got this plugin working on 4.3.7 by replacing those calls with Environment.ProcessorCount but I'm not sure if it'd be appropriate to share it. The author seems recently logged in. Maybe he can fix it soon. Also, there is another bug I've encountered. It crashes if the width equal to or smaller than 180px. (It crashes for the original plugin dll on PDN 4.2.16 as well, not related to my fix) Exception details: System.DivideByZeroException: Attempted to divide by zero. at EdHarvey.FastFX.FastBlurBgra.ApplyVerticalBlur(Surface src, Surface dst, Int32 radius, Rectangle blurBounds) at EdHarvey.FastFX.FastBlurBgra.Blur(Surface src, Surface scratch, Int32 radius, Rectangle bounds) at EdHarvey.FastFX.FastBlur2Effect.OnRender(Rectangle[] renderRects, Int32 startIndex, Int32 length) at PaintDotNet.Effects.Effect`1.Render(EffectConfigToken parameters, RenderArgs dstArgs, RenderArgs srcArgs, Rectangle[] rois, Int32 startIndex, Int32 length) in D:\src\pdn\src_4_3_x\Effects\Effect`1.cs:line 98 at PaintDotNet.Effects.BackgroundEffectRenderer.RenderWithClipMask(Effect effect, EffectConfigToken token, RenderArgs dstArgs, RenderArgs srcArgs, RectInt32[] rois, Result`1 lazyClipMaskRenderer) in D:\src\pdn\src_4_3_x\PaintDotNet\Effects\BackgroundEffectRenderer.cs:line 192 at PaintDotNet.Effects.BackgroundEffectRenderer.RendererContext.RenderTile(EffectConfigToken token, Int32 tileIndex) in D:\src\pdn\src_4_3_x\PaintDotNet\Effects\BackgroundEffectRenderer.cs:line 170 at PaintDotNet.Effects.BackgroundEffectRenderer.RendererContext.RenderNextTile(EffectConfigToken token) in D:\src\pdn\src_4_3_x\PaintDotNet\Effects\BackgroundEffectRenderer.cs:line 163 at PaintDotNet.Effects.BackgroundEffectRenderer.RendererContext.RenderNextTileProc(Object token) in D:\src\pdn\src_4_3_x\PaintDotNet\Effects\BackgroundEffectRenderer.cs:line 143 at PaintDotNet.Effects.BackgroundEffectRenderer.<>c__DisplayClass31_1.<ThreadFunction>b__0() in D:\src\pdn\src_4_3_x\PaintDotNet\Effects\BackgroundEffectRenderer.cs:line 283 at PaintDotNet.Effects.EffectRendererWorkItemQueue.OnExecuteNextWorkItem() in D:\src\pdn\src_4_3_x\PaintDotNet\Effects\EffectRendererWorkItemQueue.cs:line 124 at PaintDotNet.Threading.MultithreadedWorkItemDispatcher.WorkThreadProc(Object context) in D:\src\pdn\src_4_3_x\Core\Threading\MultithreadedWorkItemDispatcher.cs:line 495 at System.Threading.Thread.StartHelper.Callback(Object state) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state) --- End of stack trace from previous location --- at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.Thread.StartCallback() Edited January 7, 2022 by otuncelli Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted January 7, 2022 Share Posted January 7, 2022 Okay it's maybe not a good idea to try and save it then, if it's just going to crash anyway. @Ed Harvey would be the best one to make a decision about publishing an update, but I haven't seen anything from him since August. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted February 9, 2022 Share Posted February 9, 2022 Paint.NET v4.3.8 will have a compatibility fix for the FastFX Pencil Sketch plugin 1 Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
